Old 05-21-2013, 05:47 PM   #127
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by Hanakuso View Post
Thanks for the confirmation. 13/16 Would be too small? I'm planning on making one but I will only be using 1 U-bolt, so it will need to be 100% snug.
7/8" is a very solid mount. I broke out the calipers and measured before I ordered.
The Following User Says Thank You to neutron256 For This Useful Post:
Hanakuso (05-21-2013)
Old 05-21-2013, 05:59 PM   #128
Hanakuso
Thank you. I will update when I get everything setup. Hopefully within a month
Hanakuso is offline   Reply With Quote
Old 05-22-2013, 05:12 PM   #129
Hanakuso
Originally Posted by Dezoris View Post
The hoses needed:
The intake manifold barb is 1/2"
PCV Valve Barb is 11/32"
So according to Dezoris the hoses need to be these sizes, but what about the barbs/nipples? I notice he is running 0.425 OD and 0.5 OD size barbs. 11/32 which equals to 0.343 vs 0.425 seems to be a pretty big difference.
I'll be buying from Saikou Michi so he can fab up different barb sizes.
Old 05-31-2013, 01:37 PM   #130
Dezoris
Dezoris's Avatar
Using 3/8 Tubing and -6AN two piece 90 Degree Barb for the PCV to inlet will be good going forward and 1/2" for the outlet barb if you are running N/A.
Here is my finished Vortech Dual Can.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
Hanakuso (05-31-2013), TemeCal (05-31-2013)
Old 06-08-2013, 09:57 AM   #131
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Finally Got to installing the dual can solution. Thank you @neutron256 for the mounting idea. It was pretty bang on. I just took it and extended it for dual cans. Let's walk through the transformation
Before
I had a single can attached to a piece of steel that was bent like an L and wedged under the battery. Left room to add a second can. However being steel, it started rusting so I had to do something else.
Entire engine bay before
20130607-RadiumCatchCanNumber2-004 by VictorN07, on Flickr
Closeup of the can. I have a one way check valve on the intake of the catch can. This was recommended by Vortech @Brian@Vortech
20130607-RadiumCatchCanNumber2-008 by VictorN07, on Flickr
You can see the secondary breather hose here. one of my mates had tons of blow by gas go through here after a track day. Kinda stinks that the outlet is all the way at the front of the car.
20130607-RadiumCatchCanNumber2-014 by VictorN07, on Flickr
I like taking pictures. Ended up losing track of time because I had so much fun taking pictures.
20130607-RadiumCatchCanNumber2-016 by VictorN07, on Flickr
Prep
Danbo is helping me today. These are all the parts laid out. Some of the screws and extra hose are missing from this picture
20130607-RadiumCatchCanNumber2-058 by VictorN07, on Flickr
The U-bolts @neutron256 recommended. Not pictured are the nylon lock nuts that come with them. These will slip over the triangle chassis stiffener.
20130607-RadiumCatchCanNumber2-063 by VictorN07, on Flickr
Piece of aluminium that the catch can bracket attaches to.
20130607-RadiumCatchCanNumber2-064 by VictorN07, on Flickr
Cans installed. Note the dipstick is different. Radium changed the design slightly. No more flat mesh filters. The new can has a metal dish scrubber like material (the name eludes me right now)
20130607-RadiumCatchCanNumber2-081 by VictorN07, on Flickr
Fittings installed. The can on the left is my old can I repurposed for the secondary breather. It has 1/2" fittings (-8AN). The can on the right is my new can. The input is a 3/8" fitting (-6AN) and the output is 1/2" (-8AN).
Due to the proximity to the battery I ended up swapping the 90 degree input barb from the secondary breather can to the output of the PCV can.
You'll see this later.
20130607-RadiumCatchCanNumber2-109 by VictorN07, on Flickr
Installed
I actually like how clean this came out. Kind of looks like a pretty girls flowing hair.
20130607-RadiumCatchCanNumber2-117 by VictorN07, on Flickr
You can see the final configuration of the barbs. The secondary can uses only straight barbs. The primary can (PCV) uses 90 degree barbs. The perfectionist in me says to get 90 degree barbs for the second can but at 26 quid each it gets pricey really quick. It works so I think i'll leave it for a while.
20130607-RadiumCatchCanNumber2-126 by VictorN07, on Flickr
Backside of the can. I can reach in with both hands to unscrew the cans without undoing the bracket so it is still easy to maintain.
20130607-RadiumCatchCanNumber2-128 by VictorN07, on Flickr
Another angle of the setup
20130607-RadiumCatchCanNumber2-136-Edit by VictorN07, on Flickr
20130607-RadiumCatchCanNumber2-145-Edit by VictorN07, on Flickr
20130607-RadiumCatchCanNumber2-138 by VictorN07, on Flickr
My favorite picture of the lot
20130607-RadiumCatchCanNumber2-139 by VictorN07, on Flickr
Thanks for viewing
F1point4 is offline   Reply With Quote
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
neutron256 (06-08-2013), TemeCal (06-08-2013)
Old 06-08-2013, 10:28 AM   #132
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Great job as always Victor. Looking forward to checking it out in person. I need to rearrange some stuff inside the bay and will consider a 2nd can especially before taking it to another road course.
PhastekSport is offline   Reply With Quote
The Following User Says Thank You to PhastekSport For This Useful Post:
F1point4 (06-08-2013)
Old 06-17-2013, 03:56 PM   #133
BRZ NA
Drives: WR blue
Here you go about 350 miles of moderate driving, no track days or autox.
29MPG the can is already doing it's job.
I can't imagine how much oil blow by it would see under hard driving.
So far looks like this is an important addition, namely with running 0w20 the oil mist is like water.
Better yet would you want this blow by oil back in the crank case like how Crawford does it?
Wow.really?that much oil already?I made consider one of that then.
BRZ NA is offline   Reply With Quote
Old 09-19-2013, 10:06 AM   #134
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
@Dezoris
Any chance of a pnp kit from a vendor or from Radium directly?
Nolan
pheoxs is offline   Reply With Quote
Old 11-05-2013, 11:38 PM   #135
Dezoris
Dezoris's Avatar
Originally Posted by pheoxs View Post
@Dezoris
Just an update, Radium will have a kit and more in December sometime. Assuming there is no snag in production.
The Following 4 Users Say Thank You to Dezoris For This Useful Post:
normancw (11-05-2013), OICU812 (11-06-2013), pheoxs (11-06-2013), whataboutbob (11-05-2013)
Old 11-05-2013, 11:43 PM   #136
whataboutbob
AutoX-10/10ths every run
Catch can is on my short list. Thanks for the additional info as I am looking to this vendor for my part.
Build thread:Here
Old 11-14-2013, 09:46 PM   #137
akyp
Drives: 2012 86
It seems they are looking for a car to develop the kit.
akyp is offline   Reply With Quote
Old 12-26-2013, 01:42 PM   #138
Brick
Drives: White 2013 FRS
So for those of us with a FI option that removes the stock intake box/tubing where would you put the line from the outlet of the catch can? Would it go on the hot or cold side of the turbo? @Dezoris
Brick is offline   Reply With Quote
Old 12-26-2013, 01:58 PM   #139
Dezoris
Dezoris's Avatar
Hot side pre-intercooler/pre-maf.
Old 12-26-2013, 02:11 PM   #140
Brick
That's what I figured but wanted to make sure, do you need a check valve to keep the catch can from getting pressurized?
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
