Old 05-08-2013, 11:15 PM   #225
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by rbrender View Post
"Edit: it HAS to be torn apart to install. The padding does not allow it to open enough to screw I the two bolts on the passenger side" how do you do this??
It DOESNT HAVE to be taken apart. I did it without opening it.
Old 05-08-2013, 11:18 PM   #226
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
how the hell did u get those 2 screws in then? i cant squeeze them in there with the cushion still attached
lbroskee is offline   Reply With Quote
Old 05-08-2013, 11:20 PM   #227
Sportsguy83
Drives: Limited BRZ
I pushed it out and used a screwdriver. Maybe I installed it in a way where there's more space between the lid and the passenger seat so I can push it further out than normal.
Old 05-08-2013, 11:52 PM   #228
sid325
Drives: Ultramarine FR-S 6MT
Mine installed fine without needing to take it apart too.
sid325 is offline   Reply With Quote
Old 05-09-2013, 05:27 AM   #229
rbrender
Drives: 2012 toyota 86 gts
the caps on the backing of the padding come out, leaving some bolts which can easily be taken out with an allen key. once apart, its super easy to get to those holes
rbrender is offline   Reply With Quote
Old 05-09-2013, 06:43 PM   #230
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
As another member somewhat stated earlier in this thread... No need to remove the cushion.
Before you lay the armrest onto the center console, put those two screws into their respective holes within the armrest frame 1st. They will not drop into the frame holes due to the angle of entry. They will be stuck at an angle. While holding the entire frame in your hand, all you have to do is screw them a few times with your torx screwdriver and they will fall into the frame holes nicely.
Now the 2 screws will already be in the frame holes ready to screw into place for mounting. Easy... no need to remove the cushion.
I just installed mine last night and it looks fantastic! Thank you JPIT! My interior now feels complete.
FYI - My armrest did seem to have a bit of a cosmetic blemish on the center plastic hinge area. The plastic was a sort of rough and a bit more white than black in color at each end of the plastic mould. Since it was just cosmetic and only visible on the passenger side, I didn't really care.
996garage is offline   Reply With Quote
Old 05-20-2013, 07:22 PM   #231
KlafKoon
Drives: 2013 H8R FRS, 03 Miata (Sold)
Finally had time to install mine today! Received it about 2 weeks ago from Nigel. Name:  ImageUploadedByTapatalk 21369091887.172529.jpg
The install was pretty straightforward and easy but I must say that I had some difficulty with the template. Why the 2 pages don't come out of the printer already aligned is strange. I'd suggest to others to just get the initial holes for the studs in the armrest marked out with the template and then using the existing holes in the armrest itself as a guide after getting it lined up. Other than that I couldn't be happier with it! Thanks again Nigel!
Name:  ImageUploadedByTapatalk 21369092122.758370.jpg
Size:  76.3 KBName:  ImageUploadedByTapatalk 21369092143.222012.jpg
KlafKoon is offline   Reply With Quote
The Following User Says Thank You to KlafKoon For This Useful Post:
nigel-jdmparts (05-23-2013)
Old 05-20-2013, 11:28 PM   #232
DIM
Anyone know where we can buy this?
DIM is offline   Reply With Quote
The Following User Says Thank You to DIM For This Useful Post:
ravenblackfrs (09-13-2013)
Old 05-20-2013, 11:43 PM   #233
KlafKoon
Nigel has it on his website. http://nigel-jdmparts.com/toyota-86-front-arm-rest
Old 05-20-2013, 11:59 PM   #234
Hanakuso
Are you sure you printed with the option of "actual size"?
Hanakuso is offline   Reply With Quote
Old 05-21-2013, 01:03 AM   #235
KlafKoon
Ya, I unchecked the "fit to page." The lines on the PDF don't even line up perfectly, you have to shift the 2nd page over a little to line up correctly which was strange to me that it doesn't just line the 2 pages up when printing it out. All in all everything worked out fine though so no real complaints
Old 05-21-2013, 11:39 AM   #236
B L U E S L A T E
Drives: BMW E84
That's because they don't use letter size paper. They use A4 oversea and you'll notice when you print with "actual size" checked, you'll see that some of the top or bottom portion had been cut off. This wouldn't really matter much as long as the dimensions are correct and you can check that by lining up your ruler against the test measurement lines in the center of the template.
B L U E S L A T E is offline   Reply With Quote
Old 05-21-2013, 12:56 PM   #237
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
just ordered! from Chris @ CTP.
Now let the wait begin!
chenshuo is offline   Reply With Quote
Old 05-23-2013, 12:44 AM   #238
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
Thank you
P.S. Still have some IN STOCK and READY TO SHIP.
nigel-jdmparts is offline   Reply With Quote
armrest, jpit
Carsmo Armrest - Short review and quick pics Bleevin CANADA 3 09-27-2014 12:21 PM
new armrest Derrick Cosmetic Modification (Interior/Exterior/Lighting) 3 01-24-2014 10:48 PM
86 Armrest CzechZA AFRICA 30 02-05-2013 06:44 AM
armrest!!! whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 03:16 PM
