Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 12-01-2012, 04:42 PM   #43
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
One thing I'm investigating with my GTS is the addition of RCA inputs to the stock eclipse/Fujitsu Ten HU. I suspect that low level outputs might be available on the headunit, with the plug just not populated with cables. So adding them would be similar to adding an RCA plug for the reverse camera or Aux inputs.
First thing though is figuring out where to mount the switch to enable full function input on the head unit while in motion for phonebook/dialpad etc. That's my current biggest gripe
JP is offline   Reply With Quote
Old 12-01-2012, 10:10 PM   #44
ChocolateNick
Drives: Sonic Blue GTS AT
Originally Posted by st162celica View Post
kept my stock sat nav from the GTS.
Bought 2 separate opposite M/F OEM connectors - repco, other off ebay. Basically ran all my cabling without even having to cut into the oem harness. Can easily pull out the headunit and connect back to stock set up. A bit of a fuss to do, but I guess I like clip plugs and soldering, wires.
I am interested in doing the same thing. What parts did you get? What do I look for? Not too sure what to ask for from repco.
Just relax.
ChocolateNick is offline   Reply With Quote
Old 12-01-2012, 11:18 PM   #45
st162celica
Drives: 86 GTS Manual - Tornado Grey
Well you need the male and female ends.
http://www.ebay.com.au/itm/250947722...#ht_3127wt_992
And
http://www.ebay.com.au/itm/Toyota-19...ht_3266wt_1048
Then other blank plugs from jaycar to make all the cabling work. Does get a bit confusing though. Trying to dig out some of the pics.
PM me if you want a bit more detail, happy to help out.
st162celica is offline   Reply With Quote
The Following User Says Thank You to st162celica For This Useful Post:
ChocolateNick (12-02-2012)
Old 12-02-2012, 04:11 AM   #46
ChocolateNick
A photo would be awesome. I am glad you posed this before I started messing with my wiring.
Just relax.
Old 12-02-2012, 06:08 AM   #47
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Go to this place. http://www.fhrxstudios.com/ @Fhrx
The guy there (Marty) was great to talk to. He know's his sh*t, and is a straight shooter. His passion for it, pretty much inspired me to get off my a$$ and do it myself like I wanted to but was putting it off. @fuddbutter can vouch for this guy. I would def recommend people go there.
Sure can recommend him!
I have know Marty for years, we both used to be judges for MEASQ (CAASQ)
Can highly recommend his work, and his knowledge!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
st162celica (12-02-2012)
Old 05-20-2013, 07:01 AM   #48
axon
Drives: Toyota 86 GTS
Just upgraded my door speakers. Here's a couple picks for sizes. Am looking for a decent underseat sub next.
axon is offline   Reply With Quote
Old 05-20-2013, 07:04 AM   #49
axon
Soz. Ipad won't let me do 2 pics on 1 post
Old 05-20-2013, 07:53 AM   #50
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
You'll have less then 2" of clearance under the seat, less if you want the seat to still move.
Gir is offline   Reply With Quote
The Following User Says Thank You to Gir For This Useful Post:
RAN94A (05-20-2013)
Question with adding a subwoofer Shizuma Electronics | Audio | NAV | Infotainment 128 11-17-2014 01:45 AM
Subwoofer prewiring Nate219BRZ Electronics | Audio | NAV | Infotainment 3 09-09-2013 05:56 PM
OEM Audio Plus Subwoofer K2 Electronics | Audio | NAV | Infotainment 28 12-21-2012 10:28 AM
Subwoofer added mdf4uk Electronics | Audio | NAV | Infotainment 10 06-28-2012 01:37 AM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
