Old 05-19-2013, 03:13 AM   #29
wootwoot
Drives: FRS
you still need the adapter cusco provides unless you can machine your own. It is usually best to just bite the bullet and buy the kit.
Old 05-19-2013, 03:36 PM   #30
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I bet a cheaper version could be done using 2014 (edited) Forester XT parts. It has a factory oil cooler, assuming because it is turbo.
No Limit Motorsport is offline   Reply With Quote
Old 05-19-2013, 04:37 PM   #31
scraejtp
Drives: 2013 Subaru BRZ
Originally Posted by No Limit Motorsport View Post
I bet a cheaper version could be done using 2013 Forester XT parts. It has a factory oil cooler, assuming because it is turbo.
*2014. Didn't come to mind for some reason. I can't find a parts list online (2013 and older only), but if someone could pull up costs for the cooler and associated lines that'd be great.
scraejtp is offline   Reply With Quote
The Following User Says Thank You to scraejtp For This Useful Post:
No Limit Motorsport (05-19-2013)
Old 05-19-2013, 08:28 PM   #32
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by SkullWorks View Post
I would prefer a system like this on a DD car, many people do not realize the danger in OVER cooling the oil in their cars.
Oil needs to get hot enough to boil out the fuel and water tat accumulates, not to mention operating temp dictates viscosity...blah blah blah...
This and a Koyo radiator sound like a winner to me (pending actual cooling data).
Right on,
Combining both of these together seems to equal RobiSpecs Radiator and oil cooler.
Which uses a LARGE radiator with an oil cooler,
and a sandwich plate oil adapter.
This will warm the oil faster.
Aswell as keeping oil temps on par to coolant temp.
Coolant temp would be more stable due to the increased capacity and efficiency.
No worries of over cooling.
Two Birds, One Stone.
I'm in no way affiliated with Robispec.
Just think this is THE way to go.
http://www.ft86club.com/forums/showp...75&postcount=5
http://www.ft86club.com/forums/showt...light=Robispec
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 05-19-2013, 08:40 PM   #33
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I actually bought his cooler, we agreed he sent me the cooler that was running on his car because he was not able get new cores for when I needed it. Unfortunately, the brackets to hold the radiator to the frame did not match the holes. Same thing with the brackets to hold the Evaporator to the radiator. I ended up returning it for a full refund and will wait for a different solution later on.
Old 05-19-2013, 08:47 PM   #34
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
did you consider the Koyo ?
Old 05-19-2013, 08:51 PM   #35
Floggin Tires
Seem he did/is.
ZC6-CBS, is home
Old 05-19-2013, 08:54 PM   #36
Sportsguy83
Drives: Limited BRZ
Seem he did/is.
Yes, next best option for me is the Koyo radiator with some Oil cooler that is not front mounted.
Old 05-19-2013, 08:57 PM   #37
Floggin Tires
Would you go back to robispec pending fitment issues?
ZC6-CBS, is home
Old 05-19-2013, 09:06 PM   #38
SmsAlSuwaidi
Boosted
whoops, missed that.
NLM full-blown build that just started has a koyo with a small front mounted cooler, i wonder how it would function
Old 05-19-2013, 10:27 PM   #39
Sportsguy83
Drives: Limited BRZ
Honestly, no. Although I do agree the best solution is to cool the oil with coolant and have a bigger radiator, it is too big. If this was a track ONLY car, then yes, I would go for it and hack away whatever is needed to fit it and other nearby components. But the radiator being so big, introduces other limitations like for example not being able to run a CAI like Perrin's because the radiator is not only thicker but taller and the CAI tube would not fit.
Old 05-20-2013, 02:53 AM   #40
Nothing
Drives: FRS
Originally Posted by charged86 View Post
This is how my 1.8t cools itself. I can build a air cooled oil cooler for loads less than 650. Setrab makes an sandwich plate. http://www.setrabusa.com/oilfilteradapters.html
I have a 13 row oil cooler and can get the lines made in the length I need. But I need a sadwich plate. Do any of the ones listed at that setrabusa site work or does anyone know where I can get one that fits our car? Thanks!
Nothing is offline   Reply With Quote
Old 05-20-2013, 07:19 AM   #41
Sportsguy83
Drives: Limited BRZ
Mocal FRS/BRZ/86 Oil Cooler sandwich plate http://www.racerpartswholesale.com/p...andwich_Plates
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
charged86 (05-20-2013), Nothing (05-20-2013)
Old 05-20-2013, 09:08 AM   #42
Nothing
Drives: FRS
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
New Cusco oil cooler ahaghshenas Engine, Exhaust, Transmission 11 04-02-2013 10:48 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
