Old 05-18-2013, 09:33 PM   #5111
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
I received my EcuTek pro kit a few days ago tried connecting it to the ECU with all software installed correctly, car turned in "On" position and cable green light is on while connected to the OBDII line but could not get a response. Any help would be appreciated...
iketiak is offline
Old 05-18-2013, 09:36 PM   #5112
Cal3000
Drives: Panda FR-S
When you turn the ignition, make it click to time so that all the diagnostic displays are up on you fuel gage and speedometer.
Cal3000 is offline
Old 05-18-2013, 09:38 PM   #5113
Visconti
Drives: 05 STi
If the kit is from me your best bet is to take a look at my support console.. Lots of good info in there. If that doesn't help, submit a support request
-John
Visconti is offline
Old 05-18-2013, 10:54 PM   #5114
iketiak
iketiak's Avatar
Originally Posted by Carwhisperer View Post
Actually happened to me after reflashing a e85 map to pump at 95%.. was pretty scary because I couldn't start my car since it didn't complete the flash and wouldn't reconnect afterwards.
Try using a different USB port. Only 1 works on my alienware mx11 with the cable I got from John.
I have a stock ECU that's never been touched before, I tried using a different laptop with XP as well.
I'm going to give the different USB port a try to see if it does anything.
iketiak is offline
The Following User Says Thank You to iketiak For This Useful Post:
Carwhisperer (05-18-2013)
Old 05-18-2013, 11:04 PM   #5115
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
On my cheap netbook, it has 3 usb ports. I think there is one port that I cannot use because it does not recognize it or the key. That's the one I use for my bluetooth mouse. Might have to do with the comm address that is assigned to that port. I dunno. Just try different ports.
JimmyMac is offline
Old 05-18-2013, 11:46 PM   #5116
iketiak
iketiak's Avatar
Also I've noticed since ive flashed so many times from e85 to stage 1, I Sometimes* have to push the Obd2 plug straight forward, almost bending it slightly for it to connect. I just think I need a new cable all around though.
I just tried all the ports that are available while rotating my license key and still nothing. I think I'm done for tonight, can't seem to get it to work.
iketiak is offline
Old 05-19-2013, 06:11 PM   #5117
troek
troek's Avatar
Drives: 2012 Toyota 86
after my latest run though the mountains with an r32 and subaru s204 ive decided i definitely need more power. tunes here in japan can run close to 2000 dollars especially on a new platform, thats close to FI money. so my question is this: i have full catless from the stock header back , and a drop in filter, would ur stage 1 tune be alright for that, and what octane is it? im running 93 AKI over here. also, my car is JDM spec, what issues would we run into there? if i remember correctly you switch between maps with cruise control, but i dont have that.
troek is offline
Old 05-19-2013, 07:06 PM   #5118
Opposed
Drives: 2013 Asphalt FR-S
Everything you asked has already been answered in this thread. Start by just reading his info on page 1, that should answer some of your questions. The tune will work fine with your mods. And yes, there is a map for 93. I don't know about the JDM versions being different however, you will have to confirm with John or Rich.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 05-19-2013, 09:16 PM   #5119
troek
troek's Avatar
it actually dosnt mention what octane its tuned for, unless e85 specific, nor does it mention UDSM/JDM specific. I kind of expected someone from visconti to chime in, but good job being a typical forum guy and telling someone to read.
troek is offline
Old 05-19-2013, 09:41 PM   #5120
Opposed
A typical forum guy would simply tell you to
I actually gave you some info directly from the tuner.
Here is another large thread of tuning info from Visconti
http://www.ft86club.com/forums/showthread.php?t=21190
Sorry for trying to help.
Opposed is offline
Old 05-19-2013, 09:52 PM   #5121
Nardi330
Nardi330's Avatar
Drives: 86
im running drop in filter, stock header with aftermarket header back. i have stage 1 pump gas tune and the car feels good. you can ask for 98ron and that's what i'm running. our car (australia spec) should be similar to the Japanese spec.
Nardi330 is offline
Old 05-19-2013, 09:57 PM   #5122
troek
troek's Avatar
yeah i re-read your post and realized you actually answered some questions. im at work and busy and read the " read the first page" and got frustrated. my apoligies.
troek is offline
Old 05-19-2013, 10:03 PM   #5123
troek
troek's Avatar
awesome, good to know. you dynoed ur car with that tune yet?
troek is offline
Old 05-19-2013, 10:50 PM   #5124
Opposed
Yep,
This is the latest. Bottom line is stock, top line is E85 tune.
This one was the 93 oct tune only.
Opposed is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
