Old 05-18-2013, 12:06 AM   #589
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by killerkid08 View Post
Not at all. Think of all the modifications we do and now we can't cut a little out of a some stuff you can't even see!?!?!
Be for real.
lol wut i ment was i think it's stupid that that needs to be done when u would thing they had the sense to just slightly move the inlet. i dont mind it, it's just a fail by crawford
lbroskee is offline   Reply With Quote
Old 05-18-2013, 12:27 AM   #590
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by whitefrs View Post
One last question
Attachment 37585Here is a pic of the MBC.
Does it matter what way the ports go?
Like + sign nipple goes to wastegate and - sign goes to vacuumm manifold?
Per the instructions, - sign to vacuum/boost signal, + sign to WG. If you do it inversely, your WG will not open, happy Overboosting!!
Old 05-18-2013, 12:32 AM   #591
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I'm running an EBC from GFB. I thought about swapping over to his setup though. I might in the future.
How do you like yours? I am pretty happy with my GFB EBC thus far.
Old 05-18-2013, 12:34 AM   #592
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Looks better than your old actuator. You better not let the AVO haters see that you aren't pulling 10 psi till 5500 RPM on that one pull.
Sportsguy83 (05-18-2013)
Old 05-18-2013, 12:41 AM   #593
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I have a vacuum manifold, so I cut the line near my manifold:
Basically a line comes from the vacuum manifold into the MBC, and then goes down to the side port on the wastegate.
may i ask what is the fastturbo with lines ?
Old 05-18-2013, 12:44 AM   #594
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That is the vacuum manifold. It pulls vacuum/boost from the back of the intake manifold where the PCV line normally attaches and then the manifold splits that good reference to my boost gauge, BOV, EBC, EBC solenoid, and wastegate. I am using all 5 ports now.
Old 05-18-2013, 01:01 AM   #595
SmsAlSuwaidi
Boosted
@King Tut basically allows you to connect more lines right ?
Old 05-18-2013, 01:12 AM   #596
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It avoids having to run a bunch of vacuum tees and makes it so each source should see the same vacuum/boost.
Old 05-18-2013, 02:11 AM   #597
Sportsguy83
Drives: Limited BRZ
I'll be lynched!
Old 05-18-2013, 07:44 AM   #598
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Thats what i thought but i always love a second opinion
Thanks bud and again i really appreciate ur help
Old 05-18-2013, 08:19 AM   #599
Sportsguy83
Drives: Limited BRZ
No problem better safe then sorry.
Sent from my HTC One X using Tapatalk 2
Old 05-18-2013, 12:59 PM   #600
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
The g-force 2 is great for what it is. Much better than any mbc could ever be. I love screwing with my boost without having to pull over, and because of the gain and sensitivity settings, I have been able to hit the 11's and only drop into the 10s.
I only wanna know how different running an ebc is vs visconti's ecu based control.
killerkid08 is offline   Reply With Quote
The Following User Says Thank You to killerkid08 For This Useful Post:
Old 05-19-2013, 01:48 PM   #601
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Ok guys one more question and hopefully @King Tut can chime in
(Now with pics)
I know i have to cut the hose that goes from vacuum block to wastegate port but this house has a T that also goes to the BOV.
Do i still cut the hose and add it there?Name:  ImageUploadedByTapatalk1368985568.733595.jpg
Size:  156.2 KBName:  ImageUploadedByTapatalk1368985579.732420.jpg
Size:  106.8 KBName:  ImageUploadedByTapatalk1368985592.099845.jpg
Size:  172.7 KBName:  ImageUploadedByTapatalk1368985617.849495.jpg
Here is a pic
1) wastegate port
2) T connector
3) hose to vacuum block
4) hose to BOV
Old 05-19-2013, 08:14 PM   #602
Sportsguy83
Drives: Limited BRZ
(Now with pics)
Sorry for the late reply. You need to install it AFTER the Tee in that line that goes to the WG. Feel free to get some couplers and extend those lines up to where it is comfortable for you to manipulate it.
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
