Old 05-17-2013, 10:31 PM   #575
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
I already did to try and adjust the boost controller with this new actuator. I need to ask John to raise the Overboost protection which is currently sitting at 13 psi. I adjusted it until I'm hitting 10-11 psi. Feels so effing awesome!
Yes oh yes it does
killerkid08 is offline   Reply With Quote
The Following User Says Thank You to killerkid08 For This Useful Post:
Sportsguy83 (05-17-2013)
Old 05-17-2013, 10:32 PM   #576
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by whitefrs View Post
Lol u win me to it lol
Do you have any pic of urs?
Well yeah, if you cut the line currently connected to the bottom port of the WG and add the Perrin MBC in line you will be good to go.
Little bit of brain fart on my side.
Edit: Just make sure you connect it with proper orientation.
Old 05-17-2013, 10:33 PM   #577
Sportsguy83
Drives: Limited BRZ
Originally Posted by killerkid08 View Post
Yes oh yes it does
Are you the one JV set up with boost controlled via ECUtek?
It is either you or Drver I think..
Old 05-17-2013, 10:36 PM   #578
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
My car is tunes good i think.
Im running 7.5 psi at 11.2 afr
My next step will be add the mBC and raise the boost to 9-9.5 psi and do data logs for @Visconti right?
Will 9-9.5 be safe for DD?
Sorry for theeadjacking
Old 05-17-2013, 10:38 PM   #579
Sportsguy83
Drives: Limited BRZ
Its all in the tune. JV will send you a map good to DD at 9-10 psi.
Read the instructions of the MBC carefully. When ready to install, make sure you see 5 lines and pay attention to a little hole which will guide you to see how much turns you are giving. Give just 1 turn to start, as that is supposed to raise your boost by 1.5 psi and go from there. Lastly, to add boost the turn is clockwise, pushing it IN.
Old 05-17-2013, 10:42 PM   #580
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thanks for your help bud
But do inhave to ask for the map first or raise the boost first?
Old 05-17-2013, 10:46 PM   #581
Sportsguy83
Drives: Limited BRZ
I would get in contact with John first probably via ticket and tell him what you plan to do, just to make sure you have his blessing. Better safe then sorry.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
whitefrs (05-17-2013)
Old 05-17-2013, 10:47 PM   #582
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Dude
Thanks very much for your help and sorry if i was threadjacking
Old 05-17-2013, 10:48 PM   #583
Sportsguy83
Drives: Limited BRZ
Dude
You welcome and don't worry, no threadjacking. I like all information to be open publicly so anyone can read it and learn a bit. Good luck!!
HotLeopardMama (05-18-2013)
Old 05-17-2013, 11:14 PM   #584
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have a vacuum manifold, so I cut the line near my manifold:
Basically a line comes from the vacuum manifold into the MBC, and then goes down to the side port on the wastegate.
Old 05-17-2013, 11:23 PM   #585
Sportsguy83
Drives: Limited BRZ
@King Tut, more 3rd gear pulls today.
New actuator should arrive Thursday, lets see how it improves this curves.
Old actuator on top vs. new actuator below. Not good comparison, need to do it again properly, poor me... lol.
@King Tut, did some pulls but obviously not properly.... (didn't have enough road). 3rd gear.
Old 05-17-2013, 11:26 PM   #586
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thx bud
I really appreciate your help
Old 05-17-2013, 11:34 PM   #587
killerkid08
Cool Stuff
Drives: Cool Car
I'm running an EBC from GFB. I thought about swapping over to his setup though. I might in the future.
Old 05-18-2013, 12:05 AM   #588
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
One last question
Size:  112.8 KBHere is a pic of the MBC.
Does it matter what way the ports go?
Like + sign nipple goes to wastegate and - sign goes to vacuumm manifold?
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
