Old 05-16-2013, 03:26 AM   #1
NickFRS
Drives: 2013 Asphalt FRS
Header comparison. NO E85
RevWorks header + full nameless exhaust + drop in perrin filter.
FA20CLUB 4-1 Modular Header
E85 only. Waiting for a pump gas dyno
P&L Header Green line is pump gas I guess.
JDL header Only has been tuned on e85... doesn't really count...
Borla UEL header
Nameless Header
Now everyone do me a favor and look at the torque curves.... Look back at the revworks.... Yupp.... thats some awesome. I'll get some better dyno's of the RevWorks header soon. And some comparisons. Everyones thoughts?
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-16-2013, 03:52 AM   #2
ft_sjo
Drives: GT86
Originally Posted by NickFRS View Post
Everyones thoughts?
My thoughts are the only dyno graph that looks remotely realistic is the P&L one. Since when did changing an exhaust component give you a proportionate increase in torque across the range? (ignoring the remap tweaking in the torque dip).
Old 05-16-2013, 04:03 AM   #3
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I thought the P&L green line was pump gas too. Only difference was the red line was no tune and green line was Visconte pump base tune.
JimmyMac is offline   Reply With Quote
Old 05-16-2013, 07:07 AM   #4
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
If you guys want to Paypal me some money for the dyno, I will go back and dyno my JDL UEL Header on pump gas.
I think it will look very similar, just a little less peak power compared to e85.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 05-16-2013, 07:29 AM   #5
Ryan1JZ
Drives: AE93, JZZ30, ZN6
id love to see the results of the SARD headers... anyone thinking of buying them??
Ryan1JZ is offline   Reply With Quote
Old 05-16-2013, 07:32 AM   #6
ft_sjo
Drives: GT86
Simmons
I'd chip in $5 towards that. I'd want to see all the data that goes with it though, including atmospherics, dyno settings etc.
Old 05-16-2013, 07:39 AM   #7
xjohnx
Grip>Slip
xjohnx's Avatar
No comparison really until you get them all on the same dyno, otherwise the variance in dyno readings could just as easily impact the results as the actual performance of the header.
Look at the scaling on the revworks dyno graph, for instance. The scale covers from 50-450 ft/lbs, of course a torque curve on that graph is going to look flatter than one on a graph scaled to cover 75-200 ft/lbs.
Old 05-16-2013, 07:43 AM   #8
mad_sb
Drives: 2013 Asphalt FR-S
Ignore the darker line. That's with E85. The light line is on pump.
You got this one wrong. THe light colored lines are pump gas but they DO NOT include the header.
Originally Posted by FA20Club.com View Post
nope baseline was with 93 octane, fa20club cai & fa20club ecutek tune
Also, the P&L Green line IS pump gas with visconti map.
So, my thought is...
"You bought the wrong one silly"
LOL, just messing with you....
Most of the headers do allow for dip removal with tuning. stock cam timing around the dip is not optimal with a header since it is setup to try and get around the limitation of the stock header.
Your plot look great btw where did they put the temp probe and what correction factory do they use?
Old 05-16-2013, 07:44 AM   #9
mad_sb
And data logs from the car with a proper tuning tool like ecutek or brzedit, sample rate for the torque app is terrible.
Old 05-16-2013, 07:54 AM   #10
Captain Insano
What he said.
I do like the attempt to compare without E85 though since a lot of the dynos we are seeing are skewed by using E85, but most of us can't or won't use E85 for our cars.
Captain Insano is offline   Reply With Quote
Old 05-16-2013, 08:34 AM   #11
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Wait a few more months when there are more headers in the wild and pay attention to meets with dyno days. Those will best illustrate the comparisons. Nice power with the revworks though, pity you didn't get a baseline.
That nameless dyno shouldn't be there at all. It's not a product we can buy...let alone independently test at this time.
industrial is offline   Reply With Quote
Old 05-16-2013, 08:52 AM   #12
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Once i get my jdl uel ill get my car on the dyno as a 3rd party with 93
Lee358 is offline   Reply With Quote
Old 05-16-2013, 09:08 AM   #13
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Good start for a header comparison. A few things to consider.
Each car is different, each dyno is different, conditions (temp, humidity, etc.) so all data must be normalized. A baseline run needs to be done which I don't see on the Revworks dyno, so the delta (in percent) cannot be calculated nor compared to the others. Consider adding notes such as UEL (typically uncatted) and EL (catted I'm assuming), which tunes they were running, and all known mods.
@Simmons I plan on getting a tune sometime, but with news of the furlough I'm not sure when that will happen now. Whenever it does happen thou, I'd be glad to share the graphs.
hyper4mance is offline   Reply With Quote
Old 05-16-2013, 09:19 AM   #14
Visconti
Drives: 05 STi
edit
I like the P&L and JDL header
Visconti is offline   Reply With Quote
Comparison with 944 taosracer FR-S / BRZ vs.... 51 06-10-2016 04:55 PM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ RiskyTrousers Engine, Exhaust, Transmission 155 08-16-2013 09:05 PM
Header comparison itwillboost Engine, Exhaust, Transmission 1 03-19-2013 12:58 AM
fun comparison of the day: the BRZ is the new BMW E30 M3 torquemada FR-S / BRZ vs.... 56 11-30-2012 04:55 AM
