Old 12-08-2011, 04:44 AM   #15
Mitch
form follows function
Drives: RIP '13 BRZ
Originally Posted by carbonBLUE View Post
all that for 25whp? i got 35 from I/H/E/ highflow cat/ tune on my 1.8 celica
a correct IM for my car yields 15 whp alone
throttle body give my engine another 4
lager exhaust gives about 8% on top of that
cams gave a nother 8% gain in hp -2% loss in tq
(isnt my car but pulls about the same) love my 35mpg
The engine is already at 100hp/L. There really just isn't a lot of headroom on that with bolt-ons.
Mitch is offline   Reply With Quote
Old 12-08-2011, 04:46 AM   #16
serialk11r
Drives: '06 AM V8V Coupe
In the video the car has 8500rpm redline, maybe that's how?
Old 12-08-2011, 05:09 AM   #17
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
its just higher strung, tq sucks though but the car only weighs 2500 lbs...
you do realize the 2zz-ge 1.8 im my car puts out 107bhp/L in the JDM off the lot
im putting down about 101whp/L right now and i still get around 35 mpg if i just cruise back n fourth to work, but valve lift wont be allowed soon in many parts of the world because of emmisions sad day
but without lift the ft-86 does pretty good performance wise and mpg, so hats off to subaru and toyota
EDIT(added this)
Originally Posted by Midnight Run View Post
how did you know your celica gained that many hp with those mods? was it strapped on the roller? what was the base fwhp?
yes strapped to rollers,
when i said 35hp i mean crank hp from mods im pushing(guesstamated ricer math) 215 to the crank from the stock 181 my car came with
stock dyno my car came in at a healthy 162 whp (some have gotten more or less) and 185whp after my mods and a conservative tune(to retain my mpgs)
other numbers are just from reading celica forums
cant find DD intake manifold dyno charts but it yields some retardedly good gains by itself and a tune
carbonBLUE is offline   Reply With Quote
Old 12-08-2011, 11:15 AM   #18
RegisBou
Drives: Scion xA, Toyota MkI Mr2 (Sold)
I am glad to see that your 1.8 was able to squeeze that much power from basic mods.
Do not forget that we are also talking about a boxer engine, which seems to be less efficient NA and I was trying to be conservative so people wouldnt get toooooo excited! haha
Your celica on the other hand is quite impressive...
RegisBou is offline   Reply With Quote
Old 12-08-2011, 11:38 AM   #19
serialk11r
Boxer engine doesn't have a problem, in fact they can have a bit less loss since they don't need counterweights but...Subaru engines tend to be not so good in the efficiency department compared to their Japanese bretheren
Old 12-08-2011, 11:38 AM   #20
arghx7
Drives: car
I would only expect to pick up noticeable power from messing with the cats. Everything else is already optimized.
Old 12-08-2011, 11:47 AM   #21
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I/E/H/T= ~20bhp. If the tune really is chocking this mill then ~40hp?
chulooz is offline   Reply With Quote
Old 12-08-2011, 11:57 AM   #22
3scapist
Argues nekkid
3scapist's Avatar
Drives: 08 E92 M3
Lets not forget lightweight pulley's and a more efficient intake manifold ie pnp. I don't care how optimized a company SAYS their product is. There's ALWAYS room for improvement.
3scapist is offline   Reply With Quote
Old 12-08-2011, 12:08 PM   #23
arghx7
Drives: car
Uh huh. Port and polish a plastic/composite intake manifold. Big gains to be had there.
Old 12-08-2011, 12:16 PM   #24
3scapist
Argues nekkid
3scapist's Avatar
Drives: 08 E92 M3
Holy crap the IM on this car is made out of plastic?! What kind of ghetto shit is that?..Welp that just opens the door for another option which was a more efficient IM.
Old 12-08-2011, 12:55 PM   #25
djdnz
1337
Drives: 2013 BRZ WRB S/C
I/H/E/T I wouldn't count on more than 25hp.
I/E/T will be somewhere closer to 15-20hp.
N/A mods suck, and don't forget that getting a tune on this thing may take quite a while given the complexity of the heads as well as having to crack the ECU.
djdnz is offline   Reply With Quote
Old 12-08-2011, 01:50 PM   #26
Levi
Drives: Toyota
C 63 AMG can get 30 HP just with tuned ECU, because the engine is detuned. If the FA20 also is detuned, then you easily get 15 PS just with tune. With bolt-ons and tune you can get 30 PS. With big modification, you can get 250 PS, with race modification you can come close to 300 PS. Well, but for a while we do not know what is the engine capable of.
Levi is offline   Reply With Quote
Old 12-08-2011, 02:55 PM   #27
carbonBLUE
Reverse Burnouts
not sure if i read somewhere if it was aluminum and it was coated in a plastic resin to avoid heat soaking the IM
Old 12-08-2011, 03:10 PM   #28
ryude
Drives: Volkswagen GTI
The s197 has a plastic IM and some guys pnped it with impressive gains, but its also a v8...
ryude is offline   Reply With Quote
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 07:04 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 07:11 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 12:58 PM
