Old 05-15-2013, 04:07 AM   #1
suaveflooder
FINALLY joined the red tail light crew (my project inside)
I've been wanting to do this for awhile. LOVE how the red looks and I fully agree that this is how it should have come from the factory. Anyway, I can't get them on until tomorrow as they are still wet, but here you go.....
My day
The paint:
The test of color
The "work shop":
The project:
All painted. They look pretty damn good even without a gloss.
Time for clear. I went a little different rout. I learned this "trick" a couple years ago for headlights. What I like about it is that it can be built up and it buffs out REALLY well. Mix 50% gloss wood clear with 50% mineral spirits to thin it out. It basically self levels. You have to "work" it more than a traditional spray paint clear, but I am happy with the results.
Clear prep
"applicator" (the light in the background is finished. I was getting ready for the second)
You can see the difference between "cleared" and "uncleared"
And DONE!!!!
Gonna let everything dry overnight and install the lights at some point tomorrow. I will do my best to get pictures soon. I won't buff them for a couple weeks so the clear is good and hard.
Edit: Found out that I can buff after 24 hours! Thank goodness!! Gonna buff in the next couple days as I get time
suaveflooder is offline   Reply With Quote
The Following 12 Users Say Thank You to suaveflooder For This Useful Post:
boucher (05-17-2013), calis5nest (05-15-2013), Chewie4299 (07-05-2013), itsibarra (05-15-2013), Loki2x (05-16-2013), Lverasky (05-16-2013), MikeM5 (06-27-2013), mrlewistan (05-16-2013), SoCal_86 (07-03-2013), The Tengu (07-24-2013), tracerit (05-15-2013), whataboutbob (05-16-2013)
Old 05-15-2013, 06:14 AM   #2
JDMenrique
DEEEERP
JDMenrique's Avatar
great job.
glad to see someone take another route vs the VHT
JDMenrique is offline   Reply With Quote
The Following User Says Thank You to JDMenrique For This Useful Post:
suaveflooder (05-15-2013)
Old 05-15-2013, 09:40 AM   #3
JDMSushi
JDMSushi's Avatar
Drives: JDM86
Damn man that looks epic. Going to do this now.
Would be awesome to blank out a section for the reflectors... get a similar effect to the Grazio's
JDMSushi is offline   Reply With Quote
The Following User Says Thank You to JDMSushi For This Useful Post:
Old 05-15-2013, 10:15 AM   #4
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Looks nice!! I'm going to do mine soon when I have the time, did you wet sand the red at all?
The Following User Says Thank You to Wes For This Useful Post:
Old 05-15-2013, 10:40 AM   #5
Fast_Freddy
Drives: Passat
Funny how tuners used to buy clear lenses to replace the oem red lenses and now that they give us clear lenses, we paint them red! LOL
Fast_Freddy is offline   Reply With Quote
Old 05-15-2013, 11:48 AM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
realllllly should have sanded those lights prior. the chemical bond is very poor, really needs a mechanical bite for proper adhesion
Old 05-15-2013, 12:12 PM   #7
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
good job...they looks awesome.
The Following User Says Thank You to Lverasky For This Useful Post:
Old 05-15-2013, 12:18 PM   #8
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Great job, i used metal cast on mine as well. i was very pleased. how many coats did you put on there?
BoxRZ_86 is offline   Reply With Quote
Old 05-15-2013, 12:29 PM   #9
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
hahahaha always gotta change something
IG: nabb335
nab335 is offline   Reply With Quote
Old 05-15-2013, 01:12 PM   #10
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
looks great man!
Enraged21 is offline   Reply With Quote
The Following User Says Thank You to Enraged21 For This Useful Post:
Old 05-15-2013, 01:56 PM   #11
suaveflooder
Thanks for all the compliments! It turned out okay! I'm a huge perfectionist, so I see a little room for improvement. I'm hoping it clears up a little more with a buff, but in all honesty, Metal Cast with a professionally done clear would be ideal, I think. Oh well, you live, you learn. It is just slightly off from being completely clear because of the texture of the clear.
@Sanka86, I used 4 coats. Unfortunately, the big chrome piece at the top almost makes the top looks pink, so I was trying to darken it up a bit more.
@spitfire481, I thought about sanding, but the directions on the paint said nothing about it. The paint is designed to adhere to chrome, so I figured I would be fine. Worse case, I just sand it, repaint and re-clear....this time, I will do a professional clear to get it perfect.
All in all, I'm happy. I took these pictures, quickly so sorry for the quality (tilt). I tried to show the "texture" I was talking about as well as getting
FINAL PICS IN POST #29
The Following 2 Users Say Thank You to suaveflooder For This Useful Post:
86WRX (05-15-2013), charged86 (05-18-2013)
Old 05-15-2013, 02:29 PM   #12
86WRX
Drives: Asphalt
Great look awesome way to stand out the whiteness!!
86WRX is offline   Reply With Quote
The Following User Says Thank You to 86WRX For This Useful Post:
Old 05-15-2013, 03:00 PM   #13
suaveflooder
Thanks! I'm happy with the color! The thing I was worried about was whether it would be dark enough or not. It is PERFECT!
Old 05-15-2013, 03:07 PM   #14
suaveflooder
I did not wet sand. I'm going to wet sand and buff the final clear in a week or so. It's ROUGH right now, but that should smooth it out nicely.
The Following User Says Thank You to suaveflooder For This Useful Post:
Wes (05-15-2013)
i just joined the vortech crew. :) charged86 Forced Induction 235 12-30-2013 07:40 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
Anyone personally painted inside of tail light housings? BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 4 03-11-2013 12:44 AM
FS - Light tinted tail light overlays seven Exterior Parts (Aero, Lighting, Etc.) 0 01-26-2013 10:05 PM
Finally joined the ranks! ExWhyZer0 Scion FR-S / Toyota 86 GT86 General Forum 7 10-09-2012 01:09 AM
