Old 05-13-2013, 11:02 PM   #15
swift996
swift996's Avatar
Video - Drive: The 450 HP Crawford Performance Turbo BRZ - TUNED
[ame="http://www.youtube.com/watch?v=oLP-HCcX9as"]The 450 HP Crawford Performance Turbo BRZ - TUNED - YouTube[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 2 Users Say Thank You to swift996 For This Useful Post:
86BRZ (05-15-2013), supragoods (05-13-2013)
Old 05-13-2013, 11:13 PM   #16
Xdragonxb0i
Drives: ex500r
is the engine acting up the engine not getting enough fuel? as described by Don@Accelerated?
Xdragonxb0i is offline   Reply With Quote
Old 05-13-2013, 11:18 PM   #17
supragoods
Drives: Ravenfire
there is hope for you yet boxer!
supragoods is offline   Reply With Quote
Old 05-13-2013, 11:24 PM   #18
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
This looks awesome, but this is too much power, more specifically too much torque...at least for the street.
The Crawford guy said that he really only uses 25% of the power (in the modified version) on the street, while in the stock car he'd be at 110%.
This leads me to believe that there needs to be a middle ground...250-300hp would be perfect for this chassis.
The car sounds pretty good, and it looks like the trans (sans clutch) is holding up fine at these power levels.
Anyway I love these series by Farrah.
86'd is offline   Reply With Quote
Old 05-14-2013, 01:57 AM   #19
Dezoris
Dezoris's Avatar
Great to see the development but file this under, (No one can afford)
Old 05-14-2013, 02:30 AM   #20
Indokid
Drives: scion frs
so its a whole new motor thats worth 5k (without turbo), that u can tune by adding turbo and other shiett to reach that 450hp and 500 lbs of torque?...goddamn the cost would be off the chart ...sigh
Indokid is offline   Reply With Quote
Old 05-14-2013, 10:37 AM   #21
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Quirt Crawford said they overheated it and it was acting up because of that. Idk if he's telling the truth or not.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 05-14-2013, 10:52 AM   #22
EL7
EL7's Avatar
Drives: 13 BRZ Limited 6MT SWP
Originally Posted by kkakonn View Post
Can't imagine how much this would cost.
I did read that Crawford was planning on releasing a consumer grade set up sometime next month
kkakonn, do you have a source for this? I was curious about the same thing and can't find any reference to a kit availability.
EL7 is offline   Reply With Quote
Old 05-14-2013, 11:02 AM   #23
DarkSunrise
DarkSunrise's Avatar
Seems like heat is a major problem with these aftermarket FI kits. Shows the advantages of going with a factory-built car like the GT500, which not only has a better p/w ratio and factory warranty, but was also designed not to overheat under harsh track conditions. Just wish Ford would slash 1000 lbs off its weight and cut its size/height.
2022 BRZ Build
2013 FR-S Build
Old 05-14-2013, 11:17 AM   #24
HeubergerMotors
HeubergerMotors's Avatar
Drives: 2006 WRX TR
Location: 1080 Motor City Drive , Colorado Springs 80905
HAHA Love it!
HeubergerMotors is offline   Reply With Quote
Old 05-14-2013, 11:19 AM   #25
kkakonn
Drives: Frs
http://drive.jalopnik.com/heres-what...baru-504748463
Matt Farah mentions it in the comments section:
"They are coming out with a consumer-grade Turbo setup next month, and will release pricing then. This car is currently on ebay with a starting bid at $60k, and Quirt told me that they plan to get 'a little bit less out of it than they have into it.' Granted, this was the first one, so it's probably a lot, but I wouldn't be surprised if $15k got you this exact setup once it's available for sale."
kkakonn is offline   Reply With Quote
The Following User Says Thank You to kkakonn For This Useful Post:
EL7 (05-14-2013)
Old 05-15-2013, 10:20 AM   #26
kilrb
Drives: '13 Black BRZ
Agreed. Having that kind of power with relatively narrow tires and the low gearing these cars have is crazy for anything other than just a hard, straight-line pull. And that's kind of the exact opposite of why 95% of us bought our FR-S/BRZ. It's neat, but I think it would actually reduce the fun factor. I agree that 250-300whp would be awesome for this car, and would be plenty of power without impacting the fun factor...
kilrb is offline   Reply With Quote
The Following 2 Users Say Thank You to kilrb For This Useful Post:
Ganthrithor (05-15-2013), SuperDave (06-10-2013)
Old 05-15-2013, 10:55 AM   #27
KevinBRZ
Even though this is really nice, the cost is too much to justify putting into a new car for most people. After you do the block, head, turbo, exhaust, bigger tires, transmission, cooling to make this all work together, you would probably be in another $30K at the minimum. It would make more sense to spend the $50-$60k on a new car with the power like DarkSunrise said.
Now if you want to take an old car like an S14 and put $30K in, that's different.
KevinBRZ is offline   Reply With Quote
Old 05-15-2013, 11:00 AM   #28
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Isn't this the car that was damaged when it had the encounter with the McLaren? So $60K for a once wrecked, often tracked, overheating and abused car. Sounds like a bargain to me!
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Matt Farah tests out the Crawford Subaru BRZ SmsAlSuwaidi Forced Induction 67 05-17-2013 01:36 PM
Crawford Performance BRZ (450hp) Mandy BRZ Photos, Videos, Wallpapers, Gallery Forum 7 05-13-2013 06:09 PM
Video: Comparison between Scion FR-S and a Modded version by Matt Farah carbonBLUE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 41 12-31-2012 09:03 PM
Crawford Performance Turbo BRZ ! Visconti Forced Induction 57 10-12-2012 07:45 AM
FR-S Review by Matt Farah Mari0 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 08-07-2012 01:42 AM
