CANADA Canada
Old 05-14-2013, 11:05 PM   #1
Greg_Di
Drives: Scion FRS
Dent :( Will paintless dent removal be able to get this out?
Unfortunately I caught a curb at work. Front made it out fine, but the back caught the curb.
Was only going about 10-15 km/hr as I was pulling out from work, they just put in new larger sized curbs :-/
This is on the rocker panel / side skirt just by the passenger side door
I was wondering if a paintless dent removal shop could get this out or would I have to go to a body shop?
To late to call around now (will call around tomorrow) but I wanted to know what my options were if anybody knows
Greg_Di is offline   Reply With Quote
Old 05-14-2013, 11:21 PM   #2
BioRage
Drives: ~_~
Body Shop from the looks of it.
You will probably have to replace that whole piece, and by the whole piece that's a big piece.
One of our ESC members actually had his damaged from a snow bank. He replaced it, but it cost quite a bit.
If I recall correctly that piece goes all the way back to your rear quarter panel. (one piece)
I attached a highlight piece of what I mean by "1 piece"
However this is all an assumption based on previous story of our ESC member, and your 2 photos. I would get it checked out.
Join us! @ EightSixClub
BioRage is offline   Reply With Quote
Old 05-15-2013, 12:30 AM   #3
Greg_Di
Drives: Scion FRS
damn, didn't know it was one big piece. Looks like this might get pricey. Will definitely have it checked out tomorrow
Thanks
Old 05-15-2013, 12:36 AM   #4
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
That panel can not be replaced, it is actually part of the vehicles frame/chassis.
Best picture I could find but you get the idea.
Flat Black VW is offline   Reply With Quote
Old 05-15-2013, 12:40 AM   #5
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Talk to the body shop and ask if they can use a Steck (?) Pull. They drill a few small holes, insert a curved rod to get behind the dent; sort of a reverse pounding and then lead the holes in and paint. That would be a lot cheaper than replacing the panel.
whaap is offline   Reply With Quote
Old 05-15-2013, 12:48 AM   #6
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Keep us updated! Best of luck man! If this is the case, if i'm about to get into an accident, fender it is!
joergasm is offline   Reply With Quote
Old 05-15-2013, 12:49 AM   #7
joergasm
joergasm's Avatar
aw man didn't you just get her too? the worst! I scraped the bottom of my front bumper in the first week. </3
Old 05-15-2013, 01:13 AM   #8
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
.p
I bet PDA could fix that, as long as they can getva repair rod in there, they should be able ti push it out. There are rocker panel holes for the door sill plates and I also see possible access holes on the inside of this area near the back kf the door opening. So you might be in luck. Those guys are magic!
smbrm is offline   Reply With Quote
Old 05-15-2013, 03:09 AM   #9
Greg_Di
Drives: Scion FRS
Yeah picked her up May 1.....when I heard the dreaded scrape I knew I was in trouble
Thanks to everyone else for suggestions, going to make a few phone calls and will definitely update as soon as I find out
Old 05-15-2013, 08:16 AM   #10
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
I hhavee a similar, but smaller dent near the same spot. I don't recall hitting anything and I assume someone hit my car with some sort of cart or something.
Since my was smaller I was just thinking of sanding and painting it.
Chinadian is offline   Reply With Quote
Old 05-15-2013, 08:19 AM   #11
Burrcold
Drives: Subaru BRZ Limited
PDR will absolutely be able to get it out. Just because the dent is on a unibody portion of the car means nothing. They will just suck it out, and tap it back down.
I had to get a similar repair done right above my b pillar, and the guy didn't have to go inside the panel at all. Looks perfect now.
Basically anything that doesn't have a sharp crease to it, shouldn't be a problem.
Old 05-15-2013, 09:14 AM   #12
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Hope you get that fixed soon
I scraped the bottom of front lip a few times too workplace's parking lot to the road is like a dip/ramp, If I exit the lot too fast (8km/h+) I'll scratch the bottom of the lip, at least I can't see it but when I feel down there FWP with low cars.
Myv is offline   Reply With Quote
Old 05-15-2013, 09:40 AM   #13
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Gotta take them at an ugly/embarrassing angle. Also, even though it's counter-intuitive, a tap of gas just before you hit the incline will make things smoother, as it will take weight off the front suspension (raise up the front end slightly) whereas braking will do the opposite.
In nearly 6 months, I haven't ground the bottom of the FR-S once yet. The C6 I had before the FR-S (on the same DD routine) was both lower and longer in the nose, and that thing scraped so many times that a chunk of plastic underneath had to be replaced once, and the replacement was dangling again by the time I traded the car in.
thorlius is offline   Reply With Quote
Old 05-15-2013, 01:42 PM   #14
Greg_Di
Drives: Scion FRS
Well phoned a couple places and emailed a few. Some PDR places said they could not do it and a few others said they could.
Chipmaster in Markham quotes me the following
" 1) Repair dents / scratches on right lower rocker panel
2) Prep rocker for refinish
3) Re apply stone guard
4) Blend base coat for perfect colour match
5) Refinish repairs"
They have pretty good reviews so I think I will take it there. Price will be approx 350-400
Paintless Dent Repair (PDR) in SoCal 996garage Southern California 13 09-30-2013 05:39 PM
Any paintless dent repair guys in socal? YDNA Southern California 16 03-20-2013 04:42 PM
Paintless dent removal? recomendations? HATED1 Northwest 1 11-10-2012 11:53 PM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 06:38 PM
Paintless dent repair near Roswell/Alpharetta xwd Southeast 2 08-19-2012 12:30 PM
