Old 05-14-2013, 09:32 PM   #715
jshum
jshum's Avatar
Drives: Scion - FRS
You made a really good point!! mine is from stock and obviously its kinda stretched and I curbed...my right front one when I was parking.....gota watch very carefully with these wheels when tires are stretched. but i am also curious if the rail from car wash will scratch it.
Originally Posted by zoomzoomers View Post
I'll post some pics of her after I get some time to have her washed, but here's a question for you guys running XXR's.
If you're running 18 x 8.75 ET 33 with 225/40/18 like I am you'll notice that there is a tiny bit of stretch to the tires on the wheels. Basically, there's no protection of the rim by the tires due to the small amount of stretch. Have any of you guys had any problems/issues with taking your car to a car wash? Most car washes, whether hand wash or machine wash, use those rails to pull the car through the wash line. I'm a little worried that the rail will scratch up my wheels. Any input/advice on this?
BTW, the this car really needs better tires. The tires bring the car alive. If I thought the car handled well before, well with the new shoes the car feels more planted than planted. Almost to the point you have to work to get the car to break traction. It's awesome!
jshum is offline   Reply With Quote
Old 05-15-2013, 03:27 AM   #716
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Over here they have a ruber/dontaskmewhat protection on the rail, which worked well on my previous car that had a slightly streched tire. However, most carwashes do also "align" the car with the inside of the wheels, not the outside. Cant comment on the itself XXR as I'm running 245 and not using any automatic carwash anymore with the GT86
Killerbee is offline   Reply With Quote
Old 05-15-2013, 03:42 AM   #717
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Called a rim protector
GeeTee86 is offline   Reply With Quote
The Following User Says Thank You to GeeTee86 For This Useful Post:
zoomzoomers (05-15-2013)
Old 05-15-2013, 06:20 AM   #718
evil_1998
evil_1998's Avatar
Drives: GT86
Originally Posted by WolfSongX View Post
Anyone know what size center caps the XXR's take in inches or mm?
I'm not a big fan of the shape of mine so I was going to look for something with a bit lower profile that I could put one of those domed stickers from eBay on.
55mm if you want to replace the hub sticker.
PROJECTGT86
evil_1998 is offline   Reply With Quote
Old 05-15-2013, 10:28 AM   #719
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Thanks, but I was actually looking for the diameter of the hole in the wheel to replace the center cap that came with the car for something lower profile. I hope to find some Subaru center cap stickers to put on them that are similar to the stock center caps, but matching the bigger diameter of the low profile center cap.
I don't want to try to pry out the center cap and risk scratching/denting the material while it's on the car, and really didn't want to have to remove the wheel just to take the measurement. I've been recently put on Insulin by my doctor and it's been messing with my body chemistry pretty badly in the evenings. I have all these big plans to do stuff after work and then don't really feel well enough to do it when the time comes.
It's no big deal if someone doesn't know, because I'll be doing my springs this weekend and when the wheel is off, then I can easily pop out the center cap and check. I think I have a set of calipers to measure the bore precisely.
The main reason I'm posting the question is that if someone already knew the diameter then I could order the parts now and have them here a few days earlier.
Based on what I was looking at on a few vendor websites, the 530's are only compatible with a few of the center caps that XXR sells.
So if someone does know, or has a set they can measure, I'd appreciate it.
Thanks
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 05-15-2013, 07:57 PM   #720
zoomzoomers
zoomzoomers's Avatar
Where in the world did you get that???
Old 05-15-2013, 11:37 PM   #721
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
For those with 17x8.25 +35 offset 527/530's, how much do the front poke on stock suspension, if at all? From the photos in this thread, I can't really tell if they do or not.
enouf is offline   Reply With Quote
Old 05-16-2013, 01:54 AM   #722
evil_1998
evil_1998's Avatar
Drives: GT86
Sent u PM
Sent from my GT-I9300 using Tapatalk 2
PROJECTGT86
Old 05-19-2013, 06:29 PM   #723
GregV
Drives: Kia Stinger GT2
2nd page bump... got to see what my wheels look like in motion for the first time today
GregV is offline   Reply With Quote
The Following 5 Users Say Thank You to GregV For This Useful Post:
Jetscape (06-04-2013), polarstorm (05-20-2013), trigger happy (10-27-2013), Wes (05-20-2013), YW-Slayer (05-20-2013)
Old 05-19-2013, 06:45 PM   #724
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
how did you do that??
Dispect is offline   Reply With Quote
Old 05-19-2013, 06:57 PM   #725
GregV
It's a rig setup...
Old 05-19-2013, 07:53 PM   #726
Dispect
Dispect's Avatar
It's a rig setup...
and you photoshopped the top parts out??
Old 05-19-2013, 08:09 PM   #727
GregV
Yes
Old 05-19-2013, 08:27 PM   #728
HATED1
HATED1's Avatar
Drives: 86
Yes
Looks good! 17's or 18's? specs?
HATED1 is offline   Reply With Quote
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
