Old 12-05-2011, 11:54 AM   #519
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
Originally Posted by serialk11r View Post
As far as the Miata is concerned, that thing is pretty expensive, but then I am not into convertibles so I guess I can't appreciate that aspect.
MSRP yes, OTD no. You can get them OTD for $22-23k. An FRS will be 26k OTD starting and BRZ would be $28k OTD(assuming you can get it down)
WRX which can be had for $27xxx OTD.
Genesis Coupe 2.OT Rspec/Track can be had $22-23OTD.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 12-05-2011, 07:09 PM   #520
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by fatoni View Post
when you say things like weight is overemphasized, it makes me wonder what you think isnt overemphasized. and those rules you spoke of cant be broken. i mean i kinda understand what you are saying but i disagree
With enough money you can break those rules except the tires I guess.
The thing is this: I think weight is important from a philosophical standpoint. However most people who talk about low weight don't actually care about the advantages it provides; I see people saying "it's a sports car, it only needs to get 20mpg and I'll be happy". (similarly, people who whine that it's not lighter than a Miata, more powerful than a Porsche, etc.) These kinds of people clearly only care about performance, not practicality and cost of ownership. It's perfectly possible to have a heavy car feel "connected to the driver", and everyone knows how easy it is to make a heavy car fast. Want relative good mpg cheap? Use super long 6th gear ala Mustang.
Old 12-05-2011, 09:02 PM   #521
fatoni
once again an internet disagreement boils down to semantics. once i realized you were talking about the people who buy coilovers and then proceed to use mismatched worn out all season tires, i knew what you meant...even though i still kinda disagree on the importance of the boxer engine and maybe some other things but thats a different topic
Old 12-05-2011, 09:43 PM   #522
serialk11r
As far as the boxer engine goes, you can argue whether it's important or not, but I think it's fairly accurate to say the boxer engine is one of the defining features of the car. If Nissan releases a Silvia replacement for example, or if Honda releases a competitor, then this car will have the "advantage" of the boxer engine.
Old 12-05-2011, 09:57 PM   #523
fatoni
ill give you the fact that its the defining feature but i see it as more of a quirk (even if it does actually contribute to lowering cog). saying that it has a lower cog because of its motor design is like saying it has inferior handling because of its suspension design. conversely, i wouldnt say that v10s have an advantage because the lfa has a lower cog than the frs or even that inline 4s have an advantage because my miata has a lower cog than the frs.
i guess the point is i really wish there was some data as to how much this car benefits from the boxer
Old 12-05-2011, 11:43 PM   #524
PAImportTuner
Drives: U Mad?
You know what would of served better? A Renesis 13b, smooth torque, nice top end, beautiful sound, lightweight and small to give a better weight distribution and CoG. It could of met 30mpg with the low weight of the chassis.
Old 12-05-2011, 11:46 PM   #525
fatoni
i think that 30 mpg is a bit optimistic to say the least. if rotary didnt have any significant flaws i think that there would be more cars with them
Old 12-05-2011, 11:47 PM   #526
Dimman
Kuruma Otaku
Dimman's Avatar
But then you'd have a rotary... And the sound is... un-natural.
The boxer is an interesting issue. It can lower the CoG, but I think it also limits how far back the center of mass can be moved because of its width.
Because titanium.
Old 12-05-2011, 11:47 PM   #527
val_lixembeau
Drives: Acura RSX-S
Yeah, especially since it comes with some drawbacks as well. Since it's wider than an in-line engine, that's probably why they couldn't get it as far back as we'd like. Same goes for only having enough space for struts instead of wishbones. And it will be hard to ever get any more displacement since there is less room to increase stroke.
That and boxer fours sound terrible to me.
val_lixembeau is offline   Reply With Quote
Old 12-05-2011, 11:50 PM   #528
fatoni
with all the talk about the width of the boxer keeping it forward i think its pretty important to remember that the engine is also only 2 cylinders long as opposed to 4
Old 12-06-2011, 01:54 AM   #529
Dark
Elite Padawan
Dark's Avatar
How comes rotary and nissan talks are in Gen Coupe VS FR-S?
Dark
Dark is offline   Reply With Quote
Old 12-07-2011, 07:36 PM   #530
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by Driftster View Post
These phrases "a more traditional sports car" carry about as much merit as kids who say "This car is much more refined"
I respectfully disagree.
I'm sorry that you can't get enjoyment out of an automobile but need an extremely limited amount of criteria in order to have a thrilling and fulfilling experience, it must suck to be stuck viewing things in such a narrow view.
Not enjoying something as much as someone else != Unable to get enjoyment out of something
Different priorities != Narrow view
To each his own.
Deslock is offline   Reply With Quote
Old 12-07-2011, 08:30 PM   #531
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
You are confusing a 2800# with 200hp versus a 2200# car with 200hp
That's why some people wrote the car off, power not weight. WEIGHT is only a factor when power is low as in this case. If the car was 2200# and 200hp then guess what, 90% of those guys who wrote the car off wouldn't of.
If anybody really thought this car was going to be 2200 lbs then they are gullible as hell. Everybody knew it was going to be between 2500-2800 lbs because of similar modern vehicles being close in size and having FWD. 2801 lbs is not heavy.
SUB-FT86 is offline   Reply With Quote
Old 12-08-2011, 02:42 AM   #532
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
And these priorities are obviously...Direct injection......And useless back seats...
Right, obviously great handling and low weight are merely coincidental results that weren't intended to satisfy the enthusiast's demand for a hard top miata.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
FR-S/Subie Coupe fantasy Maxim Scion FR-S / Toyota 86 GT86 General Forum 23 06-10-2011 01:25 PM
new Kia coupe Ground N Pound Other Vehicles & General Automotive Discussions 22 12-29-2009 02:04 PM
