| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
2013 BRZ
#16 |
Drives: 2013 DGM BRZ M/T
Really appreciate all the help thus far guys...
Seems to be between the Michelin PSS or the Goodyear Eagle F1's.. But from 1 review on tirerack.com about the Eagle F1's "just know the rim protector lip is quite pronounced, and in my opinion takes away from the look of the tire. The tire no longer sits flush to the wheel, and I personally don't like the look (you might). Too bad you can't see them on your wheel before making a purchase decision. " Honestly think I'll be going with the PSS's... Not badly priced and the reviews are there to back it up performance wise.. Also, they are actually available. Will be going 225/45/17 as well. Promise to post pics once the wheels come in! Thanks again minasan
#17 |
Drives: Scion FR-S
I have 225/45/17 on the stock rims and the fitment is perfect. Looking at tirerack.com and comparing sizing, I would go for 245/40/17 for your width rim.
This is what min look like: http://www.ft86club.com/forums/showp...1&postcount=46 I'd imagine 245/40/17 on your rims will look the same. |
#18 |
Automatic Hooligan
You absolutely cannot go wrong with the PSS. Fantastic tires.
#19 | |
#20 |
Drives: GT86
#21 |
Care to elaborate ?
#22 |
Drives: GT86
#23 |
#24 |
Did. the 225/45 says its rim width range would be 7-8.5" in... while a 245/40 is 8-9.5" and its meas rim width is 8.5", .5" wider than my rims width. I'm confused =/
#25 |
So then, would the 245/40's provide a more appropriate tire section width?...What I don't get, and this is strictly from reading up on the rim width range on tire rack, if you go wider than the intended rim width range for that specific tire and you increase the tire section width, would that be better? Because the 225/45's are a whole inch wider than the intended rim width range. While the 245/40's are right on the measuring rim, at 8"
Still not sure what meas. rim width means either.
#26 |
Drives: GT86
#27 | ||
Drives: '23 BRZ
Lots of good selection in 245/40-17, so they're worth considering. But they are more $$$, and will have a slight bulge. Not that big a deal, but you might want to pick a tire that is rated highly for responsiveness and cornering stability to compensate for the minor loss of sidewall stability from running a tire on its minimum recommended wheel width. |
#28 | |
| Some advice | zoomzoomers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-22-2013 05:16 PM |
| TIRES, TIRES, TIRES! @ Pure Automotive Performance | Pure Automotive | Wheels and Tires | 1 | 02-04-2013 02:32 PM |
| Advice | EDCOVEY | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 12-10-2012 08:16 AM |
| FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped | apexsti46 | Wheels and Tires | 6 | 09-05-2012 02:54 AM |
