Old 05-14-2013, 01:24 AM   #29
ft_sjo
Drives: GT86
I occasionally get popping back in the intake manifold during the cat light cycle. No DTC's though.
Old 05-14-2013, 04:04 AM   #30
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
for interest Toyota South Africa has loaded a software upgrade to our 86, which is to prevent this problem.
you may want to look into this code ZA1JA01G
The upgrade also eliminates the idle drop issue.
hope this means something for you guys.
Ryan86 is offline   Reply With Quote
Old 05-14-2013, 04:39 AM   #31
ft_sjo
Drives: GT86
Which problem? The popping back in the inlet manifold or leaky injectors?
Old 05-14-2013, 05:42 AM   #32
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Mine had that same pop yesterday. First time ever but definitely the same pop. And it happened just once...
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 05-14-2013, 05:44 AM   #33
D1cker
Drives: B9 S4/ND2
this frightens me, I keep getting P300 and P302 codes.
D1cker is offline   Reply With Quote
Old 05-14-2013, 07:37 AM   #34
mad_sb
Drives: 2013 Asphalt FR-S
P0300 is random multiple cylinder missfire, P0302 is cylinder #2. I'm guessing yours may be the cranks sensor shim issue issue since you are getting P0300.
Old 05-14-2013, 03:01 PM   #35
Ryan86
Road Warrior
Ryan86's Avatar
What's the heading of the thread wiseass.......
The SW upgrade prevents the injector issue with the seals, evens out the spray evidently.
Look it up....
Old 05-14-2013, 03:15 PM   #36
mad_sb
Look it up....
Umm, so far there are several issue being discussed in this thread so a little clarification won't hurt....
Old 05-14-2013, 03:30 PM   #37
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Look it up....
Do you have more info on that update? I searched the code but didn't really come up with much. Is that an update for cars globally or just south africa?
Sevs753 is offline   Reply With Quote
Old 05-14-2013, 05:48 PM   #38
Carwhisperer
Drives: A lot of supercars.
21k miles on the car, Perrin CAI is only modification under the hood atm.
This being the 2nd time back to the dealer ship for another DI leaking. [ame="http://www.youtube.com/watch?feature=player_embedded&v=VnFa2IvNs9g"]Frs popping noise when given throttle free revving or cruising, rolling on throttle to pass. - YouTube[/ame] is what mine does in only low-mid rpms 50%> throttle or in N.
Only had 1 CEL, p0351 back a month ago Right before I got the firecracker noise from the bay. This past week I got the noise again with no CEL. Dealer said it was my other DI.
So now they're replacing all of them, with yes completely new DI Injectors straight from Japan, not from the warehouse where the first one was shipped from. I was told today by the GM ( a good friend of mine) in person that I am going to be the first one with these new DI's that should be a "permanent" fix.
I'll post more info when I know more from said above.
Carwhisperer is offline   Reply With Quote
Old 05-14-2013, 07:16 PM   #39
OrbitalEllipses
Drives: Attitude
Is there a superseded P/N?
Old 05-14-2013, 07:52 PM   #40
mad_sb
^ This..
Also, it may help if people who have had seal failure post the build date of their car...
I've pinged epifan to see if he has a copy of the updated rom mentioned above yet. If he does I should be able to compare maps and see what they changed, assuming the changes are in a defined table.
I know on cold start the ignition timing goes to -15 degrees and assume injection timing is retarded as well to intentionally get a portion of the combustion happening in the exhaust to light the cat off....
I wounder if this is some how melting the seals... or if it is simply an installation issue... the manual is very clear about not scratching or damaging the seal during install. Guess it could also be a design issue... a new part number would certainly suggest the latter
Old 05-14-2013, 08:44 PM   #41
Carwhisperer
Will have one soon. Rep couldn't give me much details, he just knows it was shipped and on the way to my dealership. I'll know more once it arrives and watch the mechanic do the install.
I'll check the build date as well.
I got mine June 1st, watching them take it off the truck. It had a "#1" in the top left corner of the windshield, which meant it was the 1st one shipped in my dealers SE region.
The Following User Says Thank You to Carwhisperer For This Useful Post:
Lonewolf (05-14-2013)
Old 05-14-2013, 10:44 PM   #42
OrbitalEllipses
Drives: Attitude
Sometimes it doesn't pay to be first :-/
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
