Old 05-14-2013, 02:07 AM   #1
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
u hauled anyone.
has anyone transported their stock suspension frs on a uhaul car transport or the 2 wheel tow dolly/
I dont want to go rent it just to not able to put it in? I have another car that is low, and i always have to remove front bumper....
njccmd2002 is offline   Reply With Quote
Old 05-14-2013, 03:26 AM   #2
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
the manual says dont do the dingy tow so it says use a full trailer if you need to transport it
mrlewistan is offline   Reply With Quote
The Following User Says Thank You to mrlewistan For This Useful Post:
HotLeopardMama (05-14-2013)
Old 05-14-2013, 04:43 AM   #3
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
^^^^ Exactly! Do NOT use the two-wheel trailer (dinghy) towing method. That is only safe with FWD vehicles. If you need to tow it, put it on a flatbed of some sort.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 05-14-2013, 04:06 PM   #4
NedVargar
Drives: 2013 Scion FR-S Firestorm
I read the U-Haul manual for the two wheel trailer. It says you can pull a RWD car, but you have to disconnect the drive shaft.
Best go with the full trailer, but it weighs a lot more. Wanted to pull my car with a van but the 4 wheel trailer + car went over my towing capacity.
NedVargar is offline   Reply With Quote
Old 05-14-2013, 04:23 PM   #5
leon78
leon78's Avatar
Drives: 13 Whiteout
Full trailer is only 10 bucks more....save the hassle and do it right...use boards if you have clearance issues.
Sent from my yotaru
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 05-14-2013, 09:06 PM   #6
THA STI GUY
DRIFT BUILD
THA STI GUY's Avatar
Drives: 2013 FRS
Ive put mine on my trailer which sits higher than a uhaul trailer and i did just fine if anything find a couple boards for extra ramp clearance but you should be fine.
THA STI GUY is offline   Reply With Quote
Old 05-14-2013, 09:41 PM   #7
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I put mine right on a UHaul Trailer after I got it to get it home. Front bumper is a close fit on clearance but it just makes it.
Shneegle is offline   Reply With Quote
Old 05-17-2013, 06:47 PM   #8
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
I am dropped on Tein S tech springs and i needed boards to get the bumper over that front metal part and the sides were super close too.
Stock height you will be perfectly fine, shouldnt need boards to get up or to get over the bar. I drove it accross the country from WI to AZ.
FR-Shadow is offline   Reply With Quote
Old 05-21-2013, 01:46 PM   #9
Drftfan
Drives: Argento FR-S
Don't use Uhaul ever. Period. Do some research on their crash/death rates. Especially with their trailers. They are the only rental company that will rent trailers to tow behind normal everyday cars. The other companies won't do it. There, rant over.
Drftfan is offline   Reply With Quote
