Old 05-14-2013, 03:29 AM   #351
rx3
While I can see the benefit of a cooler engine bay and the benefit of not losing any temperature (= more velocity/pressure) before the exhaust turbine of a turbocharged engine (since this will deliver more power to the turbo).
I don't quite see the benefit of hotter exhaust gases in the header of an NA-engine, as hotter gases also have a higher viscosity (more friction) and produce more backpressure.
Having said that, exhaust gases are very fast = there's little time for heat exchange. So, any effect (positive or negative) is probably negligible.
rx3 is offline   Reply With Quote
Old 05-14-2013, 03:39 AM   #352
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
If it's worth anything, Gmookher was using a temp gun on the coated vs non coated points of his header/overpipe got almost a 70 degree difference in temps.
http://www.ft86club.com/forums/showp...3&postcount=48
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
xjohnx (05-14-2013)
Old 05-14-2013, 05:01 AM   #353
rx3
I don't doubt that its beneficial to the engine bay temperature, but I doubt that it has a significant effect on the temperature of the exhaust gases (and I doubt that having hotter exhaust gases has a significant effect on power of non-turbo charged engines).
Keep in mind that heat-power can easily be produced with a red-glowing infrared heater with 500 W (if it was placed in a header): http://www.osram.com/osram_com/produ...star/index.jsp
But the 'heat-power' in the exhaust gases is about the same as the mechanical power of the engine, which could be around 150'000 W.
Old 05-14-2013, 07:10 AM   #354
xjohnx
Grip>Slip
xjohnx's Avatar
thanks for the link.
not sure how applicable it is though, since it was probably a protype temp gun on a test version of a coating on a super secret prototype header.
test.
prototype.
Hawaiian (05-14-2013)
Old 05-14-2013, 08:45 AM   #355
Hawaiian
That guy
Hawaiian's Avatar
test.
prototype.
You forget, It was testing for extreme heat in the Arizona desert.
Ultramarine mt FR-S
P&L stage 1 turbo
xjohnx (05-14-2013)
Old 05-15-2013, 09:27 AM   #356
xjohnx
Grip>Slip
xjohnx's Avatar
anyone know if the TRD intake will fit with this header?
Old 05-15-2013, 10:04 AM   #357
Hawaiian
That guy
Hawaiian's Avatar
It should. The vortech kit does, and that has similar dimensions. A local company also recently used my car for a 3d engine bay scan. As you can see there's a lot of room.
And it's oh so sparkly!
Ultramarine mt FR-S
P&L stage 1 turbo
xjohnx (05-15-2013)
Old 05-15-2013, 11:44 AM   #358
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
[ame="http://www.youtube.com/watch?v=sX1Ec8CMJUA"]FRS - YouTube[/ame]
Is this how the header is supposed to sound, with the buzzy noise past 4k?
ScottDRFT is offline   Reply With Quote
Old 05-15-2013, 01:01 PM   #359
Hawaiian
That guy
Hawaiian's Avatar
Do you have a resonator on your exhaust? This header can add some rasp above 4k rpm depending on your exhaust setup. I'm having another resonator added to mine to clean that up.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 05-15-2013, 01:06 PM   #360
mad_sb
Drives: 2013 Asphalt FR-S
That sounds like metal on metal vibration to me, check where the over pipe crosses over the subframe.
Old 05-15-2013, 03:14 PM   #361
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Haha that's not my video xD though I did just jump on the recent group buy! I was just wondering, I am planning on running the perrin catted front pipe and resonated catback. I hope that should tone down some of that weirdness.
Old 05-15-2013, 03:15 PM   #362
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Old 05-15-2013, 03:19 PM   #363
Hawaiian
That guy
Hawaiian's Avatar
Gmookher has an exact same setup on his car. He was initially unresonated, but added a resonator and loves it.
Ultramarine mt FR-S
P&L stage 1 turbo
ScottDRFT (05-15-2013)
Old 05-15-2013, 03:34 PM   #364
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Thanks, good to hear! Do you think it is subtle enough to be a DD setup?
StopTech BBK Prototype Install benjoke Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 03-31-2013 11:31 AM
WGP Looking for a BRZ For LS Swap Prototype Doug@WGP Announcements, Contests, Giveaways 25 10-10-2012 05:20 PM
How come Toyota has 2 prototype and Subaru has none? moda3 BRZ First-Gen (2012+) — General Topics 30 09-06-2011 01:39 PM
Different wheels on the prototype ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-20-2011 05:00 PM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
