#57 |
Drives: GT86
Anyone with a vibrating knob running the oem exhaust?
#58 |
Drives: Scion FRS 10 Series AVO Turbo
I began hearing the audible rattle from the shifter approximately three weeks ago at 4500 miles. Took it in and sure enough they ordered the part. I took my FRS today to get the shifter swapped out. After having the shifter assembly swapped out the condition of the rattle worsened. After speaking with the Master Tech at the dealership I took it to, he stated he had to record a sound clip and send it to the regional engineer. As of right now, I'm just playing the waiting game. The engineer will probably be down to check the car tomorrow to examine the car. This is the only solution out their for this problem at this time. Will let you guys know what I hear from the engineer and the tech tomorrow.
#59 |
Drives: AVO BRZ
Mine rattled completely bone stock.
#60 | |
Toyota Master Tech
Drives: Whiteout MT
#61 | |
Thx for the heads up |
#62 |
Drives: 2013 FR-S whiteout
I've got an appointment with the dealer tomorrow for this issue, bringing the TSB with me.
#63 |
Drives: Toyota 86 ; Nissan 200sx
I have the same problem and even after they replaced the shifter it still does the same. Please help this is driving me crazy.
#64 |
I got the TSB done, still rattles, but less...and is now sometimes difficult to get into 1st gear.
#65 |
Drives: 2013 BRZ Limited - WRB, MT
i noticed mine only rattles in 5th gear. I thought it was my flossy shift knob (500g) but i put the stock one back on and it still rattles. only in 5th though. all other gears its nice and quiet
#66 |
Update: had the TSB done regarding the Audible Shifter noise. Field engineer came out and installed. Not to sure if he should be an engineer or not due to him cutting the shifter instead of removing it the proper way. Anyways had it replaced and got the car have two days later. Well it reduced the noise at first but I went back to dealer to advice them the noise is still their. Dealers service manager stated that he could no longer help me as the field technician installed the part and stated after still hearing the noise "that it was normal." I contacted scion corp following my dispute with the manager. Scion rep advices me that theirs nothing they can do. I advices them the noise is louder than the first time I took it in for. I'm currently in the process of going through Settlement program as they have denied to fix my car. Another reason I'm going through the settlement program is for the rear deck popping. Scion attempted to fix it three times and failed. Will see what happens. Not to sure why theirs a TSB when the FET stated the noise was normal even after he replaced the shifter assembly. :/
Bought my vehicle in January of this year and has been at the dealer well over 35 days for repairs or shall I say attempt to repair tsb's. I might as well go back to my reliable Honda instead of this. |
#67 |
First 86 Driver Baby!
Drives: FR-S, Flex
My car makes a rattle as well, but the noise happens while I'm crushing down the highway at about 3K in 5th or 6th gear. As soon as I push on the accelerator the sound speeds up then immediately stops. If I let off the throttle again it'll reappear.
#68 |
Drives: car
Curious, are you guys riding with any weight in the back? I noticed shifter rattle in 5th gear when i had ~80 lbs. of weight in the back, but not when the trunk is clear.
#69 |
Captain Cocoa
Drives: CBS BRZ MT
Why do I have a feeling that the cause is the reverse lockout? Someone go buy the perrin one and see if it fixes it.
#70 |
Drives: 2013 Firestorm FRS
Skip that, just replace the whole shifter with a kartboy shifter/bushings.
Support a forum vendor! See @tom@kartboy Direct link I have a kartboy shifter, and have NO rattles. |
| Flywheel Rattle? | CB762 | Issues | Warranty | Recalls / TSB | 119 | 11-16-2016 10:09 PM |
| Vibrating shifter fix! | Superhatch | Issues | Warranty | Recalls / TSB | 51 | 06-05-2016 10:56 PM |
| Flimsy shifter | chessplaya2010 | Issues | Warranty | Recalls / TSB | 1 | 07-31-2012 01:21 PM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 07:46 PM |
| FR-S Shifter Video | xravexboix | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 04-21-2012 08:20 PM |
