Old 05-12-2013, 06:24 PM   #15
Splat
Drives: FR-S ultramarine
Originally Posted by NomoreNA View Post
Twin screw = low end torque, centri = linear power/torque, single turbo = big power on the top end "high rpms", twin turbo = worthless on our platform. That covers the basics
Thanks, that is why I want twin screw...I am happy with the high end revs and power.
Splat is offline   Reply With Quote
Old 05-12-2013, 07:03 PM   #16
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Also to note Turbos:
Lag
= Delay of boost.
When throttle position changes to the time of actual noticeable boost
when the engine is at an RPM that boost can be made.
Example:
Boost set at 10psi.
Cruising, at 4500 RPMs where 10psi can be made.
For now, no vacuum, no boost. Were just cruising.
Floor it.
Lag is the time it takes from here to build boost.
Boost threshold= The lowest RPM an engine can begin making boost.
Example:
Rolling 5mph 800 RPMs
Floor it.
Boost threshold is from here to the lowest RPM at which boost starts.
Boost threshold is often confused with lag.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following 5 Users Say Thank You to Floggin Tires For This Useful Post:
brufleth (05-14-2013), Freshfrs86 (10-15-2013), mitosis (10-04-2013), PineappleFriedRice (05-12-2013), SirBrass (12-01-2013)
Old 05-13-2013, 11:56 AM   #17
wparsons
wparsons's Avatar
^^ Further to that, you won't have lag with a supercharger. You'll get some delay because of boost threshold with a centrifugal blower, but no lag.
Superchargers are also more predictable in how they react since the amount of boost produced isn't dependent on engine load like a turbo is. In a straight line or drag racing this doesn't matter, but mid corner on a road course you'll sure care.
flickr
Old 05-13-2013, 12:32 PM   #18
nonicname
Drives: it has 4 wheels and a motor
twin screws for our cars are made by sketchy companies that lie a lot and have terrible customer service
nonicname is offline   Reply With Quote
Old 05-13-2013, 12:43 PM   #19
AVOturboworld
When you use a turbocharger from a drag setup, yes. But I'd think the sheer amount of turbochargers used in racing would indicate by now that they can be predictable in a corner. Especially when you use a turbocharger sized for road racing.
Turbocharging is not just for big hp, big lag setups. Look at the sheer amount of car manufacturers that turbocharge. They do that because you can size a turbo for low-end and mid-range torque, and still retain all the benefits of off-boost MPG efficiency.
The Following 7 Users Say Thank You to AVOturboworld For This Useful Post:
aagun (10-15-2013), Ammonia (10-03-2013), Freshfrs86 (10-15-2013), mitosis (10-04-2013), SirBrass (12-01-2013), sw20kosh (05-13-2013), usptwins (05-14-2013)
Old 05-13-2013, 02:56 PM   #20
sw20kosh
Drives: 2013 Black FR-S
This.
Old 05-13-2013, 03:02 PM   #21
wparsons
wparsons's Avatar
I realize it's not just for big hp setups, but they still aren't as predictable as a supercharger mid corner. Sure they're good, and more modern higher efficiency turbos are getting better and better at part throttle response, but they still depend on engine load which is an extra variable over rpm and throttle input.
flickr
Old 05-13-2013, 04:31 PM   #22
AVOturboworld
Mid-corner throttle response implies you are frequently stabbing the throttle mid-corner, at least that's the way everybody makes it sound. I know from personal experience that you are usually feathering the throttle to hold it at the limits of adhesion, and in those situations engine load isn't changing. There's no sudden surge of power just waiting to throw you into the run-off - unless you are running a large turbo that has it's spool-up point right at that rpm range you are cornering in.
Old 05-13-2013, 04:47 PM   #23
ptuning
ptuning's Avatar
Drives: White FR-S
I'm going to totally agree with Paul here. There are a lot of misconceptions about the power delivery of a SC vs. a turbocharger. If turbos were no good for road courses then the also RWD McLaren MP4-12C, Porsche GT2, and Pagani Huayra (amongst a sea of turbocharged supercars) would be the slowest cars on track and as we know that is not the case.
Keep in mind too that these cars run close to or higher than 20 psi of boost so the power sweep from off throttle vacuum to full boost is very wide, but this alone does not affect how the power comes in, that is dictated by your right foot. Formula 1, the absolute pinnacle of motorsports, is switching to 1.6L turbo V6 engines in 2014 and it's not because they want uncontrollable power delivery.
The mid corner and corner exit control is more difficult with a high powered turbo car because..... it makes more power. A lot of people are under the impression that this makes for a slower car around the track. This is simply not the case. Between two cars that are identically set up, suspension and aero-wise, the one with more power is going to be faster around the track with a good driver.
Most SC's allow you to smash the throttle on corner exit, because there will likely not be enough torque on tap to break traction, it's as simple as that. Mid corner control is no different. If you look at your boost gauge while you're going through the corner, you will most likely freak out and mess up your line, but if you feel out the corner with the feedback from the car, you'll be able to modulate the throttle correctly regardless of whether your car is NA, SC'ed or turbocharged.
For the novice just getting into HPDE's, the lower powered car will be the faster one around the track, initially. Turbo's and SC's both have their pluses and minuses, but to distinguish one as being road course worthy because of better power delivery would be incorrect. :happy0180:
ptuning is offline   Reply With Quote
The Following 6 Users Say Thank You to ptuning For This Useful Post:
aagun (10-15-2013), AVOturboworld (05-13-2013), mitosis (10-04-2013), MooKz (10-03-2013), SirBrass (12-01-2013), SkullWorks (10-15-2013)
Old 05-13-2013, 05:18 PM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I was wondering what direction this thread would take.
There are benefits to each type of FI, and ways to get around most of each's shortcomings. The right choice depends not only on application, but intended use AND driving style.
Old 05-13-2013, 07:54 PM   #25
Floggin Tires
AVO, PT, and Draco
I concur, good points.
Now to go off topic.
I was aware,
but read this again,
makes me
Originally Posted by ptuning View Post
Formula 1, the absolute pinnacle of motorsports, is switching to 1.6L turbo V6 engines in 2014:happy0180:
and raise you a :happy0180:
ZC6-CBS, is home
The Following User Says Thank You to Floggin Tires For This Useful Post:
ptuning (05-13-2013)
Old 05-13-2013, 11:17 PM   #26
wallace03
wallace03's Avatar
Drives: WRB BRZ
So does a turbo lag take away from the the NA throttle response that's already in the car? or is does it just "lag" compared to sc?
wallace03 is offline   Reply With Quote
Old 05-14-2013, 08:32 AM   #27
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That will depend on a lot of factors, more importantly how big or properly sized is the turbo. On a properly sized turbo, its really hard to notice the lag. On a BIG turbo, lag will be bad.
Old 05-14-2013, 09:03 AM   #28
s2d4
s2d4's Avatar
I don't think the way lag is used in this thread is correct.
That is unless you are dropping compression then add an oversized turbo.
JDL 5130 Twin Scroll Turbo Kit JDLAutoDesign Forced Induction 390 05-27-2021 01:14 AM
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 02:22 AM
Twin Turbo kit? enjoi23 Forced Induction 15 12-03-2012 08:53 PM
Silver FR-S sunset photos and... Twin turbo mod. CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 06-18-2012 02:37 AM
