Old 05-12-2013, 01:01 AM   #463
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by killerkid08 View Post
Ive heard anything below 80% is good, and above that is pushing it. Its just interesting trying to find a way to interpolate that percentage off of the ecutek log.
Im working on it
Old 05-12-2013, 01:02 AM   #464
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
You mean the fuel pump or injectors? The fuel pump does. The injectors, why not go with Visconti ones?
I don't know enough about any of them to make a final decision. Lol.. Carts stay full, checkout never gets completed in reference to the injectors.
I know the fuel pump is the closest to OE out of all of them from what ive read.
killerkid08 is offline   Reply With Quote
Old 05-12-2013, 01:03 AM   #465
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Im working on it
i cant wait to see your dyno numbers on this thing with all the work going into it
lbroskee is offline   Reply With Quote
Old 05-12-2013, 01:05 AM   #466
killerkid08
Cool Stuff
Drives: Cool Car
Im working on it
I also want to figure out what the difference in DI modes are? 1-4 is what I've seen.
Old 05-12-2013, 01:08 AM   #467
Sportsguy83
Drives: Limited BRZ
Yeah I saw it too, have no idea what each mean, but probably means off, on and general things like that.
Found an online calculator for duty cycle, and taking one number got that at 6000 RPM, Duty cycle for my injectors is 55%.
Will try more and see the differences.
Old 05-12-2013, 01:14 AM   #468
Sportsguy83
Drives: Limited BRZ
@lbroskee @killerkid08
6600 RPMs, 62% Duty Cycle
7479 RPM, 66% Duty Cycle
So yes, because of the DI system, we have lotsssss of room.
Calculator: http://www.stealth316.com/2-calc-idc.htm
ECUTek log gives you IPW in mS and obviously engine RPM
Old 05-12-2013, 01:14 AM   #469
lbroskee
lbroskee's Avatar
hey i know this is back to an old discussion in here, but the boost controller....when u adjust it is it just guess work and then ur datalog tells u wut it's currently at? if so theres gotta b an easier way
Old 05-12-2013, 01:17 AM   #470
Sportsguy83
Drives: Limited BRZ
It depends on what controller you get. I have Perrin's. The way that one works, is every turn adds about 1.5 psi of boost, so its not total blindsided guesswork. After adjustment, you drive it in 3rd or 4th gear to make sure you added about the amount of boost you wanted. The gauge will also tell you, no need to wit for the log.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lbroskee (05-12-2013)
Old 05-12-2013, 01:19 AM   #471
lbroskee
lbroskee's Avatar
lower the duty cycle the higher the injector size needed it looks like tho
300 at the flywheel at 80% needs 640cc, while at 65% needs 787cc
Old 05-12-2013, 01:20 AM   #472
lbroskee
lbroskee's Avatar
ah ok. i wonder if i can get 1 i can adjust from inside the cabin. i'd love to screw with ppl then jus up my boost
Old 05-12-2013, 01:21 AM   #473
killerkid08
Cool Stuff
Drives: Cool Car
http://www.fr-sforum.com/forums/fr-s...lkthrough.html
I found this helpful. Google a powerful thing.
Old 05-12-2013, 01:24 AM   #474
killerkid08
Cool Stuff
Drives: Cool Car
Go with an electronic boost controller.
Nothing like making them feel good running straight WG, and at the press of a button pushing X psi the next run.
The Following User Says Thank You to killerkid08 For This Useful Post:
Old 05-12-2013, 01:25 AM   #475
killerkid08
Cool Stuff
Drives: Cool Car
Grabbing the netbook as we speak.
Old 05-12-2013, 01:25 AM   #476
Sportsguy83
Drives: Limited BRZ
I think you don't understand what Duty Cycle means. Duty Cycle is a value that tells you the amount of time the injector is open when compared the amount of time it takes the engine to complete a revolution. That time will vary with each RPM. A lower duty cycle only tells you that the injector is opening very little time, which is a good thing. So to paraphrase your statement, To lower the duty cycle, you need bigger injectors.
With that in mind, from your statement, what that means is, to be at 80% duty cycle you need 640 cc injectors and to be at 65% duty cycle, you need 787 cc injectors. And again, those numbers do not apply to us because the DI system injects fuel at a high pressure, and takes the bulk of work off of the port injectors.
That same post is in this site too
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
