Old 05-11-2013, 09:55 PM   #1
Racecomp Engineering
STI MOTOR and TRANS mounts released.
Pics of trans mount to follow shortly.
makes a HUGE difference if you have headers and full exhaust and or close fitting exhaust parts. STi uses group-n durometer rubber but UNLIKE when you would add these to the WRX or STI, there is NO extra NVH. Yes simply revving the motor you see no more drastic engine movement.
Installing these DOES Require raising the motor about 2 inches. We finally had to remove the rack bolts to get them in. Other wise its a half hour install.
Myles
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
Bu-Tang (05-11-2013), Calum (05-11-2013), LeeMaster (05-12-2013), mad_sb (05-11-2013), mokinbird87 (09-16-2015)
Old 05-11-2013, 10:02 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Will you guys be selling these, Myles?
Sent from mission control
Old 05-11-2013, 10:40 PM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Myles
if only somebody would do a DIY of this
Old 05-11-2013, 11:05 PM   #4
mrk1
Drives: Sterling BRZ Ltd
Ive had a set of these in for a few weeks. Both motor and trans, absolutely love them. I found install pretty straight forward for a motor mount. Motor has to go up, I did not touch the steering rack.
With an aftermarket over pipe and catless front section the passenger side engine mount comes out over the rear of the cross member. The driver side mount came out the front of the cross member. Ive done a handful of engine mounts on STI's and would rather do the BRZ mounts given a choice.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-11-2013, 11:23 PM   #5
mrk1
I wrote a bullet point type DIY on another thread about these. I did the install at a leisurely pace on the floor and found it straight forward. I guess it may depend on different people mechanical experience.
http://www.ft86club.com/forums/showthread.php?p=927895#post927895
The Build Thread
Old 05-12-2013, 12:34 AM   #6
Good tip ! I guess Dan was in a rush and removed the rack bolts.
Mw
Old 05-12-2013, 12:34 AM   #7
yup.
Mw
Old 05-12-2013, 12:36 AM   #8
WOW, never saw that thread ! (FAIL on my behalf)
Myles
Old 05-12-2013, 08:35 AM   #9
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How much
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 05-12-2013, 11:28 AM   #10
Calum
That Guy
Originally Posted by DriftEightSix View Post
How much
http://www.racecompengineering.com/i...rivetrain.html
The Following User Says Thank You to Calum For This Useful Post:
DriftEightSix (05-12-2013)
Old 05-17-2013, 11:59 AM   #11
FastWhite
Drives: Subaru BRZ Limited M/T
Anyone know what the difference is between the MT & AT tranny mounts. The engine mounts should be the same.
FastWhite is offline   Reply With Quote
Old 05-28-2013, 11:21 PM   #12
Ingen
Drives: Ultramarine FR-S 6MT
Will these mounts fit the frs? Question seems dumb, but I want to be sure.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 05-29-2013, 01:26 AM   #13
Turdinator
Señor Member
Turdinator's Avatar
They should but if you are really worried TRD japan make the same parts...
Use google translate on this link HERE
From what I can tell the STI parts are easier to get than the TRD outside of japan.
1974 TA22 Celica
2013 86 GT
Trans/Motor Mount question DanoFA20 Engine, Exhaust, Transmission 5 03-02-2013 04:16 PM
PERRIN MOTOR MOUNTS FR-S & BRZ Just arrived PICTURES gmookher Engine, Exhaust, Transmission 43 01-17-2013 04:30 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
How many hp more can the AT trans handle? K-R Scion FR-S / Toyota 86 GT86 General Forum 1 08-18-2012 02:21 PM
