Old 05-11-2013, 07:03 PM   #15
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
That video is great except the comparison is horribly done... Reminds me of the top gear episode where they "prove" modding your car is useless.
There was no logging or tuning done...both are bad examples....lots of cars have restrictive intakes but not a turbo subbie.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-11-2013, 07:06 PM   #16
wbsrazzle
Drives: Subaru BRZ 6MT LTD
Yeah I mean the aem one, literally almost is like a vtec situation. At 5k RPM the engine revs to the redline quicker, and there is a surge in torque/hp coupled with the sounds. Is it worth it? Hard to tell, spent almost 400$ on this. The reason I got the AEM is because it comes with a tuned chip to plug into the maf. I am worried about the AFR and being too lean or rich, I am trying to preserve my engine.
If I sell this, I will take a loss most likely and I have had it in for 2 hours lol.
wbsrazzle is offline   Reply With Quote
Old 05-11-2013, 07:51 PM   #17
jflogerzi
jflogerzi's Avatar
Only reason I got my aFe was sound(remove noise generator), clean up engine bay, and a bit more performance.
Old 05-11-2013, 07:52 PM   #18
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
god damn the sounds from intakes are so nice makes everything worth it haha i got the Injen intake and loving it
Minovsky is offline   Reply With Quote
Old 05-11-2013, 11:55 PM   #19
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Originally Posted by campy View Post
The guys on the youtube show Mighty Car mods made a couple videos about this.
TL;DW: Keep, the stock airbox and just use drop ins. An aftermarket intake in the engine bay will cause you to lose power, and you will see slight gains if the intake is outside of the engine bay, but you won't really notice it.
Except in their example, the engine is a turbo. Of course a cold air intake isn't going to do much... as soon as the air passes through the turbo it will heat up. That's what intercoolers and such are for. They have big advantages on most NA cars. The reason why it's not THAT MUCH better than our stock cars is that the factory intake already pulls cold air from the front bumper via a snorkel. It does it pretty efficiently too. So much so that you can gain 90% of the performance of a full intake with just a drop-in filter. Some non-cold-airs actually lose power because of the warm engine bay temps.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 05-12-2013, 02:35 AM   #20
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
I personally got a AFE intake, it took a few days for the ECU adjust. At first, it didnt do much. Then it started having more low end torque before the torque dip and more torque after 5.5k to redline. BUT the torque dip is much more noticeable, once you put the AFE intake in. BE WARNED!
CSI:86 is offline   Reply With Quote
Old 05-12-2013, 02:41 AM   #21
#87
I usually post drunk
#87's Avatar
If you want bang for your buck, HP per $ you have to go FI or engine swap. Bolt ons for small NA engines not gonna do ____
#87 is offline   Reply With Quote
Old 05-12-2013, 08:35 AM   #22
StormTrooper
Yes but the price of admission is much higher... Like $3500 for the most basic kit. 5-6k for a good turbo kit and supporting mods
GR86 MT premium
Old 05-12-2013, 10:27 AM   #23
#87
#87's Avatar
Yes the cost is much higher but I'd rather save for that than spend 2k on I/H/E and get almost no gains.
If anything I'd go for E85 and tune over IHE.
Old 05-12-2013, 10:44 AM   #24
StormTrooper
30hp and tq is very noticeable.....a lot of people don't have access to e-85. I want linear power and for my car to last.
It is a toy but it's also my DD.
GR86 MT premium
Old 05-12-2013, 10:50 AM   #25
#87
#87's Avatar
I dont have access to e85 thats why I'm saving for FI. Not going to waste time or money with bolt ons in the meantime
Old 05-12-2013, 11:08 AM   #26
CSI:86
86 = First New Car
Is your car a DD? I personally wouldnt FI a DD car.
I have a AFE intake and perrin pulley so far.
Plan to put Perrin headerback and stage 2 tune. It will give about 25whp, which will be noticeable and importantly it keeps it reliable in the long term.
Old 05-12-2013, 11:08 AM   #27
wbsrazzle
But you need i/h/e for the F.I too!
Also, I think this car is nearly tuned to the bleeding edge. I am worried about engine reliability with these tunes that raise the RPM and lean out the engine.
I am doing intake and exhaust and suspension, and that's IT until the new 2014 BRZ comes out to see if they get any more HP out of the engine and hopefully buy/replace the part(s) that do it. I'd rather have 225hp that is reliable from the factory than 250 from tuning and questionable after market accessories.
Old 05-12-2013, 11:28 AM   #28
StormTrooper
i'm not sure about timing but the AFR's on the car are not "on the edge"
12.5:1 is not what i'd call designed for FI so i'm staying away.
GR86 MT premium
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
Intakes MemphisR Engine, Exhaust, Transmission 2 03-03-2013 08:40 AM
Aftermarket intakes & tunes... zooki Engine, Exhaust, Transmission 5 12-19-2012 02:18 PM
So those of you with intakes... come in here please... v.MPG seven Engine, Exhaust, Transmission 22 12-04-2012 09:35 PM
