Old 05-10-2013, 05:53 PM   #15
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
My actuator was supposed to be a 10psi but it started moving at 8 when tested on the bench. After a couple of days it dropped from 8 to 6psi...
Silverdub is offline   Reply With Quote
Old 05-10-2013, 06:40 PM   #16
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
What PSI WG actuator are you using? It is expected for a MBC to produce higher values at higher gears when there is more load on the engine.
But aside from that and to give an example, a 5 PSI actuator will have more trouble holding 9 psi steady than an 8 psi actuator.
I will most likely be running the 7psi actuator from AVO.
gdrider77 is offline   Reply With Quote
Old 05-10-2013, 06:46 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Oh yes, I remember. I think it may be time to start exploring returning that spring and getting a new 10 psi spring.
Old 05-10-2013, 06:47 PM   #18
Sportsguy83
Drives: Limited BRZ
As a rule of thumb, should be good up to 14. I would say it should be good to 12 conservatively.
Old 05-11-2013, 07:25 AM   #19
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I have to change the complete actuator... Since its the 10psi model, i would need to try the 15psi one. But im waiting on my injectors and fuel pump then i might buy an EBC if its more precise
Old 05-11-2013, 08:20 AM   #20
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
What gauges would be needed when i go turbo, besides a boost gauge?
JackSmiley is offline   Reply With Quote
Old 05-11-2013, 10:15 AM   #21
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Wideband could be usefull and if you have room and budget egt and oil temp
Old 05-11-2013, 12:44 PM   #22
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Egt is a very very useful gauge that most people do not use
Old 05-11-2013, 05:54 PM   #23
Visconti
Drives: 05 STi
I like the AEM Boost/Wideband combo for Gauge side
Boost Control and fail safe should be done via ECU!
Did you AVO kit from with a MAP Sensor?
-John
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
King Tut (05-13-2013)
Old 05-13-2013, 02:47 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I agree with John.
Old 05-13-2013, 02:49 PM   #25
OrbitalEllipses
Drives: Attitude
Little word soup there.
Old 05-13-2013, 05:23 PM   #26
gdrider77
gdrider77's Avatar
-John
As far as what i am getting, its the avo stage 1 kit, with upgraded actuator, Breather tank kit with upgraded PCV, and 3-Bar Map Sensor, adjustable BOV, & stage 2 base tune.
I think that is what you were asking?
Ryan.
Old 05-13-2013, 06:55 PM   #27
Sportsguy83
Drives: Limited BRZ
Ryan.
He was asking for the 3 BAR Map sensor because that allows ECU Overboosting protection and probably also needed for ECU boost control.
Old 05-13-2013, 06:57 PM   #28
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
-John
Is gauge pillar on the brz-750 available?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
lower mounted turbo options? lbroskee Forced Induction 9 04-07-2013 03:46 PM
Scosche touchscreen A/C controller DIREWOLF Electronics | Audio | NAV | Infotainment 46 03-30-2013 07:42 PM
Turbo Kits: Rational boost threshold yet? Ryephile Forced Induction 88 01-22-2013 12:05 AM
Greddy New Profec Boost Controller Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 4 01-16-2013 06:12 PM
