Old 05-10-2013, 04:23 PM   #1
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Estimated Max HP for a N/A setup.
Just like the title says, what do you think would be the max hp obtainable for a n/a setup on the FRS/BRZ.
kayoh is offline   Reply With Quote
Old 05-10-2013, 04:35 PM   #2
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Search. There is at least one 200+whp NA car.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following User Says Thank You to Wonderbar For This Useful Post:
scionfr_s (05-16-2013)
Old 05-10-2013, 04:35 PM   #3
ft_sjo
Drives: GT86
280-300 bhp or so. Good luck finding someone who can engineer that for you though.
Old 05-10-2013, 04:39 PM   #4
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
On ~92 octane gas probably around 195whp with I/E/H and a good tune. e85 gas probably higher. Keep in mind 195whp is a pretty liberal estimate, most people end up around 180-185, depends on the dyno.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 05-10-2013, 04:40 PM   #5
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
depends, do you want to do it with a FA20?
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
Ganthrithor (05-10-2013)
Old 05-10-2013, 04:46 PM   #6
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Estimated max hp NA....If a 12 year old Honda K20 can hit 280whp NA, then this one can go for 280-300whp (optimistic but edgy).
LeeMaster is offline   Reply With Quote
Old 05-10-2013, 04:49 PM   #7
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
I don't see these motors ever touching anything K series. 280-300whp is nothing for them. I know a few guys over 400whp
I just saw a 200+whp dyno from another BRZ today...I'm sure it will be up soon!
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
ATL BRZ (05-10-2013), LeeMaster (05-10-2013)
Old 05-10-2013, 05:00 PM   #8
kayoh
kayoh's Avatar
I'm asking because countless sources says that this car needs at least 40+ more hp. I'm wondering if this amount of hp (or even more) is attainable without having to go SC/TC and if so what type of modifications and how much $$ would it take.
(btw thanks for such prompt responses)
Old 05-10-2013, 05:06 PM   #9
Shangsta
Drives: E30 318IS
Definitely never going to reach k series power but for a max effort setup I can see 300
Shangsta is offline   Reply With Quote
Old 05-10-2013, 07:50 PM   #10
LeeMaster
Red wine
A couple of things I can think out of my head to increase NA power is find the best exhaust/intake combo. After that, you go internally through the engine upgrading the cams, block, head, increasing displacement, lightweight pistons and lightweight anything. I am no engineer nor an expert in engine so I'm just going to leave it at that as a starting point. But like everyone and including myself have said, this engine is too new to know what hidden gem there could possibly be.
But seeing as how high of a compression(12.5) we already have to start off with, and adding the Direct Injection to the mix and barely on an even ground with the K20 that dont even have any of these goodies. I am(for lack of a better word) scared, but hopefully future engineers can prove us wrong that this engine is a sleeping beast!
Old 05-10-2013, 08:54 PM   #11
Wonderbar
Driveway labs.
Wonderbar's Avatar
We def. need cams for this motor.
I need to get a spare set of heads so I can drop them to Delta Cams
Old 05-11-2013, 12:49 AM   #12
rainmonkey
Drives: BRZ - Dark Grey
always wondered... is it possible to swap to a k20? i thought I'd eventually find someone that did, but so far I haven't heard.
rainmonkey is offline   Reply With Quote
Old 05-11-2013, 02:53 AM   #13
Kilika
Drives: 1992 Toyota MR2
Anything is possibly with the right hands and amount of money. Practically wise, the motor might be too tall and you gotta find a gearbox that will allow the motor to be mounted longitudinally. If I had to go through all that trouble, I'd figure a way to put the transmission by the rear axle to get the weight distribution closer to 50:50 or even better rear weight bias which is better than 50:50.
Kilika is offline   Reply With Quote
Old 05-11-2013, 10:42 AM   #14
Whitigir
Drives: 450 awhp twin turbo vr4
I would be more concerned about the Torque first, not the HP. Generally, anything over 200 HP and More will bring you up to 130 MPH no problem.
However, the Torque is what will move your car. Think about it this way
Torque = Get moving
HP = Top speed.
Unfortunately, to change your Torque from an NA. You have no other options than swapping head, or cams. If not, then go FI such as Turbo or Supercharger.
These cars will be fast, if you can put down 250 Torque at 1300 rpm, and 200 HP
Whitigir is offline   Reply With Quote
The Following User Says Thank You to Whitigir For This Useful Post:
GT86_PRAGUE (06-03-2015)
max, setup
Scion fr-s options and estimated release date. Fantum's86 Cosmetic Modification (Interior/Exterior/Lighting) 20 09-29-2012 03:09 PM
Scion fr-s options and estimated release date. Fantum's86 Hawaii 1 08-04-2012 05:18 AM
Capitol Subaru-estimated arrival 6/8 SuperSatinBrz BRZ First-Gen (2012+) — General Topics 78 06-07-2012 08:42 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 06:14 AM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
