Old 05-10-2013, 12:11 AM   #1
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
Any issues running Stance LCAs and GTSPEC toe rods/trailing arms?
Does anyone know if there are any issues in running Stance lower control arms in conjunction with GTSPEC toe rods/trailing arms?
I bolded the important parts.
It seems as if they might clash in design if one lowers and one raises the rear because of the bends in the arm.
I thought they would go together because of these bends but another thread brought it to my attention and I wanted to verify this information before picking up more parts.
THREAD:
http://www.ft86club.com/forums/showthread.php?t=33706
From their descriptions:
"GTSPEC rear control arm is used for track or street cars that require rear camber adjustment as a result of coilover installed or wider wheel fitment. In addition to camber adjustment, we redesigned our rear control arm brace to include a +30mm bend.
When cars are lowered it creates a positive camber, which will generate extra stress on the stock control arm. Our new rear control arm is designed with a +30mm bend to compensate for the extra stress that was caused by lowering the vehicle. The +30mm bend is suitable for "1 to 1.5" drop vehicles. A stock control arm or stock like aftermarket control arm is mainly designed to adjust camber only and does not have this added feature.
In addition, we have upgraded the end joints of our control arm to forged 7075 aluminum for extra strength and durability, unlike other competitive products.
*NOTE:*
Not recommended for stock vehicle (non-drop). The rear of the car will be higher than the front."
"Stance Adjustable Lower Control Arms are made from billet aluminum for strength and durability. The Lower Control arms are used to adjust camber and the range achieved with these is negative 1deg - 6deg. Stance also implements Aurora Rod ends on these arms. The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA Applications, so their quality pretty much speaks for itself.
Stance actually uses Aurora's 3pcs billet rod end bearings to be exact. Aurora bearings use a sintered steel ball to handle extremely high loads. The Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability as well.
The Stance Lower Control Arms are designed to raise the hub mounting point about 20mm when compared to stock, which lowers the car about 25mm. This allows for longer stroke dampers found on the Stance FR-S application, and have more height adjustment range. This design is especially helpful for 1-way height adjustable coilovers like KW, which lose stroke as you lower the car."
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 05-10-2013, 09:15 AM   #2
YDNA
YDNA's Avatar
Drives: Raven FR-S
dont get either and wait for the whiteline ones. if you really need it, i'd go with cusco, then stance.
YDNA is offline   Reply With Quote
Old 05-10-2013, 11:44 AM   #3
wparsons
wparsons's Avatar
The bend faces down, so it gives you more shock travel at the same ride height. If you don't have coilovers it will lower the rear more than expected, so probably not too desired. They also mention that lowering increases positive camber, which is also backwards. Lowering increases negative camber.
IMO, it's poorly translated, but that doesn't reflect the product.
flickr
Old 05-10-2013, 10:33 PM   #4
FTEIGHTSIX
FTEIGHTSIX's Avatar
I have coilovers.
I dont like cusco.
Their parts are expensive because they are blue
and their rod ends suck and dont last.
CUSCO IS FOR JDM ***S. Quote me on that.
I like the Stance LCAs because they use Aurora rod ends.
Old 05-10-2013, 11:51 PM   #5
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Whiteline rear lca are vapourware. I have been told 3 times, approximately 1 month apart, to call back in a month's time.
RacerX ftw.
http://www.ft86club.com/forums/showt...ghlight=racerx
Old 04-01-2014, 12:15 PM   #6
eseboner
Drives: scion frs white
THREAD:
*NOTE:*
hey did you end up going with the gt spec toe arms? I also have stance suspension.. my gt spec control arms are on the way.? gtt
eseboner is offline   Reply With Quote
■■ Stance Lower Control Arms & Stance Coilovers ■■ FREE SHIPPING - Photos and Video. FT-86 SpeedFactory Brakes, Suspension, Chassis 338 09-30-2016 03:46 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
Cusco vs Stance (Rear Control Arms) Funky Fresh AUSTRALIA 41 05-22-2013 10:02 PM
Cusco vs Stance (Rear Control Arms) Funky Fresh Australia Classifieds 0 04-15-2013 12:35 AM
Running a Stagger stance? Xdragonxb0i Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-09-2012 12:14 PM
