Old 04-22-2013, 01:28 AM   #43
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Originally Posted by enjoyminutemaid View Post
I just had my konis, rce springs, and WL com-c's installed professionally and there's definitely some clunking and noise that wasn't there before. I have to check some things (sway bar endlinks etc.) but I'll report back here when I figure out what's up.
I had some clucks realized my sway bar was loose oops.
jdzumwalt is offline   Reply With Quote
The Following User Says Thank You to jdzumwalt For This Useful Post:
enjoyminutemaid (04-22-2013)
Old 05-08-2013, 11:25 PM   #44
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Update: I'm still getting some slight clunking, but moreso there is creaking/squeaking from the front. I'm not sure what's causing it, but it mainly happens when I turn the wheel from full lock right back the left (makes the noise when the wheels are just about centered again). Any ideas? How hard is it to swap the stock tophats back on?
enjoyminutemaid is offline   Reply With Quote
Old 05-08-2013, 11:38 PM   #45
OrbitalEllipses
Drives: Attitude
There's a DIY on how to do shocks without compressing the springs. If you follow that it should be fairly easy.
enjoyminutemaid (05-09-2013)
Old 05-09-2013, 12:43 PM   #46
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I'm getting this sound when backing up out of my drive way. Not sure if its the cmounts or the rce springs and Konis.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-09-2013, 12:52 PM   #47
cnk
Drives: '13 DGM BRZ Limited
Spring pop? I only say this because the noise didn't appear until you turned the wheel.
Old 05-09-2013, 12:53 PM   #48
feldy
feldy's Avatar
Not quite sure. It only does it in the morning when leaving the drive way. I tried to make it happen in a empty lot doing dumb things.
Old 05-16-2013, 01:08 AM   #49
feldy
feldy's Avatar
So for the last week now mine have been just like this. Same issue and all. I took them off tonight and the bearings are pretty rough to turn with your finger. Stocks are back on. Emailed whiteline. Will see what happens. Have the koyo bearings.
Old 05-16-2013, 02:07 AM   #50
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Damn, I was going to get these... this thread has me thinking twice :/
OjiGeorge is offline   Reply With Quote
Old 05-16-2013, 05:23 PM   #51
enjoyminutemaid
Did the noise go away with the stock tophats?
Old 05-17-2013, 12:30 AM   #52
feldy
feldy's Avatar
Yep!
Whiteline is sending me a new set tomorrow.
Old 05-17-2013, 12:31 AM   #53
wootwoot
Drives: FRS
I have not installed mine yet but the bearings turn smoothly by hand. I know many of the people with the updated hats are having good luck with them. Will be interesting to see what happens here....
Old 05-17-2013, 12:41 AM   #54
feldy
feldy's Avatar
who knows... we will see soon enough.
Old 05-17-2013, 01:03 PM   #55
onefasazn
Drives: Chevrolegs
What way are you assembling the spring and strut assembly with the top hat? Are you using a spring compressor? I had a buddy who installed his using the "drop the car on the strut" method and he ended up with the same type of clunking noise. Re-did the suspension with a spring compressor properly and it was gone.
onefasazn is offline   Reply With Quote
Old 05-17-2013, 02:33 PM   #56
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I used a spring compressor with my new Com-C's with the Koyo bearings and have no noises at all, running them with RCE Yellow springs. I think using a spring compressor is important to getting the geometry right on the top of the strut shaft and bearings when tighetning down the top nut.
The Following User Says Thank You to ATL BRZ For This Useful Post:
console_cowboy (08-02-2013)
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
