Old 05-08-2013, 06:41 PM   #15
the_colombian
the_colombian's Avatar
Drives: Red FR-S
Let us know how it works with the mini PC. I might be interested in doing this as well.
the_colombian is offline   Reply With Quote
Old 05-09-2013, 02:17 AM   #16
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
is hawaii's frs different then ours (mainland) firmware wise???
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 05-09-2013, 04:06 AM   #17
cruzinbill
Drives: Argento 6spd FR-S
he has a different HU, notice it doesnt say powered by Zephyr on the bottom right.
His is the same that is avail for the Scion IQ, from what I remember it doesn't have all the features of the FR-S one. No ipod control as well as other things, cant remember for sure tho.
cruzinbill is offline   Reply With Quote
Old 05-09-2013, 09:18 AM   #18
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I'm going to give this a shot this weekend with the US spec bespoke.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
lbroskee (05-09-2013)
Old 05-09-2013, 10:08 AM   #19
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
mind added some more pix of this, like how you'd connect things to it?
lbroskee is offline   Reply With Quote
Old 05-09-2013, 10:33 AM   #20
post_break
post_break's Avatar
Yeah I'll take some pictures, I'm going to see if I can find some other wiring diagrams too.
The Following 2 Users Say Thank You to post_break For This Useful Post:
Lanbaldo3 (05-09-2013), lbroskee (05-09-2013)
Old 05-09-2013, 06:00 PM   #21
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I'll have to try that. We don't have the bespoke here, but just the pioneer..which is basicly the same shit without the bespoke app thingy...It should work I hope.
Rayme is offline   Reply With Quote
Old 05-10-2013, 03:46 PM   #22
UbSaMrC
UbSaMrC's Avatar
Drives: 13 FR-S Asphalt AT
I twerked my phone kernel and couldn't get my tapatalk working.
I forgot to mention my HU was pulled from a 2012 Scion XB when it was totaled. I assumed most settings were the same since the connectors are the exact same. I matched our 28pinout to a standard toyota pinout and found the similarities; mic, vss, steering, audio in and to my surprise video on slot 13.
The standard connectors worked from the frs to the premium audio (not bespoke) so I assumed it should work. Seeing that the screens are different, I am not sure where the video feed will trigger in the HU.
The process is simple that anyone with bespoke can try and undo as long as you don't splice the vss and slot 25, instead remove the pin using a needle and insert a loose wire then ground that.
Parking brake bypass is should be grounded during the reverse cam install.
Disclaimer: This is solely based on my digging around the net and what I did, try it if it works then you just found a reason to enable inputs available in a cheaper deck.
Sent from my SPH-D710 using Tapatalk 2
UbSaMrC is offline   Reply With Quote
The Following User Says Thank You to UbSaMrC For This Useful Post:
lbroskee (05-10-2013)
Old 05-20-2013, 02:19 AM   #23
UbSaMrC
UbSaMrC's Avatar
Final testing done. Front usb and audio still works independently as long as back audio rca is not used.
Photo of the 28 pin, yellow rca to #13 and audio rca direct. Name:  uploadfromtaptalk1369030381385.jpg
Shows the wiring attached to a 3contact 35mm connecter that will connect to a MK812
Everything back connected
Photo of the label on the top of stereo
Lonewolf (05-22-2013)
Old 05-21-2013, 09:56 AM   #24
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Can you play movies from USB using this method?
YamahaR86 is offline   Reply With Quote
Old 05-22-2013, 12:18 AM   #25
lbroskee
lbroskee's Avatar
did you ever try this
Old 05-22-2013, 09:28 AM   #26
post_break
post_break's Avatar
I spent two whole days getting the backup camera to work. I need to try the AV menu sometime this weekend.
lbroskee (05-22-2013)
Old 05-28-2013, 05:26 PM   #27
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by UbSaMrC View Post
You can stop at this point if all you need is a video input since you can still connect to the AUX port in the by the USB slot.
Optional -
(6) Tap the slot 28 (Left+), 27 (GND) and 26 (Right+) and connect it to a pair of female audio connectors
Anyone know if the front USB still works with step 6 done? Not the aux port under the usb, but will the head unit still read from the a usb drive if 6 is done?
Old 06-03-2013, 03:54 AM   #28
UbSaMrC
UbSaMrC's Avatar
Sent from my SPH-D710 using Tapatalk 4 Beta
lbroskee (06-03-2013)
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 10:11 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
FS: Pioneer Premium Upgraded Head Unit (Not-Bespoke, Canadian option) pheoxs Audio/Visual, Electronics, Infotainment, NAV 1 03-22-2013 05:47 AM
I suppose this is an option....for someone. Pscylo Cosmetic Modification (Interior/Exterior/Lighting) 11 06-21-2012 11:34 PM
