Old 04-26-2013, 07:54 PM   #211
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by WRXGuy1 View Post
Love it! Where's the best place to order it from?
JSCSpeed.com
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following User Says Thank You to Simmons For This Useful Post:
WRXGuy1 (04-26-2013)
Old 04-26-2013, 09:54 PM   #212
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I ordered through Kaizen but you can order directly through Perrin as well.
-Sony
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 04-27-2013, 06:05 AM   #213
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Circuit
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 05-03-2013, 12:22 AM   #214
Sensisnow
Drives: 05 TSX & 13 BRZ
Looking from the back of the car, my left tip extends about an inch further than the right one, which is almost flush with the bumper. I tried aligning it with the bushing tools, but that did nothing. I'm guessing I need to adjust the s-clamps somewhere? Any tips?
Sensisnow is offline   Reply With Quote
Old 05-03-2013, 01:11 AM   #215
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I would loosen the vband clamps and try to rotate the midpipe a bit. That worked for me.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Sensisnow (05-03-2013)
Old 05-03-2013, 12:00 PM   #216
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
Mine is the same. No one but me notice though. After the down pipe was put on there was no getting it perfect. But yeah it is something only I notice cause it is my car.
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 05-03-2013, 12:31 PM   #217
Sensisnow
Thanks, I'll give that a try this weekend.
Old 05-03-2013, 01:06 PM   #218
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
You can fix this by loosening the V-band at the muffler and the S pipe. But do not loosen it too much, just enough to where you can twist the S-pipe a little. Take a look at the tips and twist the S-pipe, you will see the tips move in and out as you rotate it. Move it into place and snug down the muffler, V-band first, then the S pipe one.
That should allow it to work perfect.
PERRIN_Mladen is offline   Reply With Quote
The Following 4 Users Say Thank You to PERRIN_Mladen For This Useful Post:
EvoXDD (05-03-2013), Noli (07-21-2013), Sensisnow (05-03-2013), SilverlightPony (07-11-2015)
Old 05-08-2013, 10:23 AM   #219
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
Do I need a torque wrench for this install? My exhaust is shipping this week and I want to make sure I have all the tools necessary.
quicksilver30 is offline   Reply With Quote
Old 05-08-2013, 10:45 AM   #220
tennisfreak
Drives: 2018 BMW M240i
Yes you need a torque wrench. One that can go as low as 75 inch pounds if I recall correctly.
Old 05-08-2013, 11:14 AM   #221
quicksilver30
Old 05-08-2013, 02:07 PM   #222
Sensisnow
It would be nice to have a torque wrench, but I wouldn't consider it a necessary item for this installation. I have one, but only used it on the larger bolts for this install because I didn't have a deep socket for the v-band bolts that would fit my 1/2" torque wrench and everything works fine with no leaks.
Old 05-12-2013, 10:12 PM   #223
Oburn
Anyone know any CanAdian sites that sell perrin cat back exhaust?
Oburn is offline   Reply With Quote
Old 05-13-2013, 03:17 AM   #224
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Does anyone know the actual weight of both resonated and non-resonataed versions? It's indicated as 39.5lbs for both on the official web site.
At the same time last year DSport magazine weighted the version w/o resonator and got 29.2 lbs - the question appears: did they get some special improved "press" version or what? The resonated version was 33.6 lbs according to DSport - so, does resonator weight 4.4 pounds?
Efferalgan is offline   Reply With Quote
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Review of ISIS Street Catback exhaust sirhc Engine, Exhaust, Transmission 24 10-29-2012 04:57 AM
