Old 05-03-2013, 06:52 PM   #1
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Scion FRS / Subaru BRZ HPS Silicone Radiator Hose Kit DIY Installation Guide!
Hi Guys!
Check out this DIY made by HPS for the Scion FR-S and Subaru BRZ.
HPS High Temperature Reinforced Silicone Radiator Hose kit installation instruction for the Scion FRS / Subaru BRZ
Here is a list of tools you will need:
  • 10mm socket with ratchet
  • 12mm socket with ratchet
  • 8mm wrench
  • Flat Screw Driver
  • Philip screw driver (for the bleed screw)
  • Needle Nose Pliers
  • Safety Glasses & Gloves
  • Drain Pan
  • Coolant Bleeding Funnel
Your first step is to put the car up on jack stand at its proper lift points. Then remove the aluminum under tray using a 10mm & 12mm socket. There are also some plastic clips which can be removed with a flat screw driver. By removing the under tray, you will have access to the lower radiator hose located on the driver side of the vehicle.
Before you drain the coolant, make sure the vehicle is cooled down completely. To drain the coolant you can remove the plastic cover located on the passenger side of the vehicle. Once the cover is removed you can see the drain valve. I attached a piece of hose to the drain to make less of a mess.
You can remove the radiator cap to speed up the drain process.
The lower radiator hose is located behind the air intake box. The intake box is held on by 3 bolts. To remove the air intake box you must remove the 3 bolts using a 10mm wrench or socket. The next step is to unplug the sensor wire and loosen the intake tube using a flat screw driver.
To remove the hose clamps, you simply pitch them using a pair of pliers. The hose should be pretty easy to remove on the radiator side. On the engine side the hose might be a little bit harder. I had to use a pick to break it lose.
Lower radiator hose view from the top of the engine bay.
Lower radiator hose view from the bottom once the alumium tray is removed
On the upper radiator hose I decide to remove it as one piece to make the installation of the silicone radiator hose easier. To remove it as one piece. you have to unbolt the radiator hose filler using a 10mm wrench or socket.
Once the hose is out, you can swap the radiator hose filler to the HPS reinforced silicone radiator hose and use the provide stainless steel clamps to secure it. Do not over tighten the clamps. (Recommended torque spec on the HPS stainless steel clamps are 35 inch lbs.)
The upper hose on the radiator side is kinda tricky. Its in a bad angle so i had to use a swivel and a8mm socket to tight the clamp. You can also use a open 8mm wrench as well.
Bolt the radiator hose filler back in place and double check the hose position to make sure the hose is not touching or kink.
The lower radiator hose go on pretty easy and a flat screw driver can be use to tighten the clamps
After the hoses are secure in place you can tighten the drain and begin filling the system back with coolant. Reinstall the intake air box and the under tray.
Remove the screw using a philip screw driver on the heater hose located on the fire wall to bleed air out of the system. Continue to fill the coolant till it flows out of the bleed screw.
Once its full, start the engine and turn the heater to the hottest temperature and set the fan to the lowest setting. Let the car idle and check for leaks. Once the car has reach operating temperature, turn the engine off and let the car cool down. Remove the funnel, top off the coolant system and put the radiator cap back on.
Drive the car around and re-check the coolant level once the car has cooled down. Remember to take away safety precautions when working on your car and use safety gear such as safety glasses and gloves.
Scion FRS / Subaru BRZ HPS Silicone Radiator Hose Kit is available in Black, Blue and Red. (Part Number 57-1226)
Thanks,
Mike
Corner3garage is offline
Old 05-07-2013, 05:32 PM   #2
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 05-08-2013, 12:23 AM   #3
Dezoris
Dezoris's Avatar
Thanks for this, what are the real benefits of the silicone hoses over the rubber in terms of heat stability?
Dezoris is offline
Old 05-08-2013, 03:11 AM   #4
sean1186
Love this, attention to detail and pictures are spot on, thanks man!
sean1186 is offline
Old 05-08-2013, 01:47 PM   #5
Corner3garage
Drives: FR-S & BRZ
  • Silicone hose is 3-ply reinforced vs rubber has 1-ply (silicone is way stronger)
  • Silicone temp operates up to 350F vs rubber 220F
  • Silicone hose life spans 10 X longer then rubber
  • Silicone hose has less chance of failure under harsh weather conditions hot or cold vs rubber
Old 05-09-2013, 03:00 PM   #6
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 05-10-2013, 12:36 PM   #7
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 05-10-2013, 05:05 PM   #8
qoncept
qoncept's Avatar
I think this thread would fit better here. Seriously, posting it is fine, but bumping it every day?
qoncept is offline
Old 05-11-2013, 01:31 PM   #9
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 06-05-2013, 01:27 PM   #10
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 06-06-2013, 01:31 PM   #11
Corner3garage
Drives: FR-S & BRZ
Bump!
Old 06-06-2013, 03:43 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You never mentioned when to reinstall the bleed screw on the heater hose.
King Tut is offline
Old 06-07-2013, 12:32 PM   #13
Corner3garage
Drives: FR-S & BRZ
This DIY was done by HPS, I just reposted it!
Put the bleed screw back after all the bubbles are out!
Old 06-11-2013, 12:30 PM   #14
Corner3garage
Drives: FR-S & BRZ
Bump!
Zeta Performance - 6 Pcs Silicone Radiator Hose Kit (Pre-order) ZetaPerformance Engine, Exhaust, Bolt-Ons 20 04-18-2013 12:26 AM
Venair Silicone Radiator and Heater Hose Kits- Red, Black, Blue!!! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 04-17-2013 03:20 PM
Enjuku Racing - ISIS Silicone Radiator Hose Kit - ** NOW AVAILABLE ** Enjuku Racing Engine, Exhaust, Bolt-Ons 0 01-08-2013 04:37 PM
Zeta Performance - 6 Pcs Silicone Radiator Hose Kit ZetaPerformance Engine, Exhaust, Transmission 1 09-18-2012 10:17 PM
New Product - ISIS Silicone Radiator Hose Kit - Scion FR-S / Subaru BRZ Enjuku Racing Engine, Exhaust, Transmission 0 09-17-2012 11:13 AM
