Old 05-06-2013, 09:08 PM   #15
wparsons
wparsons's Avatar
Originally Posted by Wes B. View Post
How much power has the AZ6 withstood behind a built SR20DET? Anyone know?
It's not HP that breaks transmissions, it's torque. Since these engines don't have torque output like an SR20DET at the same HP levels they'll stand up much better.
flickr
ramiram1984 (05-06-2013)
Old 05-06-2013, 10:16 PM   #16
ramiram1984
Drives: 2016 STi DGM
Then you have to worry about axels and having stronger ones installed, etc etc. do some research guy before putting TTs.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-06-2013, 10:54 PM   #17
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
If I had a nickel for every time someone mentioned a small block Chevy swap...
Haha I'll be that guy then. How about a 572 aluminum block hemi to increase that low end torque.
Edit: there's no way it would fit though
Via my Note 2
Freeman is offline   Reply With Quote
Old 05-06-2013, 11:02 PM   #18
OrbitalEllipses
Drives: Attitude
Via my Note 2
Chevy 350
Old 05-06-2013, 11:09 PM   #19
xwd
Crawford was making a lot of torque down low and 475lb-ft at the same HP level. They popped a motor but the trans was okay.
The Following User Says Thank You to xwd For This Useful Post:
hmong337 (10-12-2014)
Old 05-07-2013, 12:08 AM   #20
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
The transmission lives a short life at that power level. I wouldn't expect AP to still be using the factory transmission. These transmissions look to hold around 400wtq for some time, but I suspect failures to be common once these start seeing higher miles.
Coheed is offline   Reply With Quote
Old 05-07-2013, 12:18 AM   #21
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Don said he was working on a transmission solution. Im assuming given the power levels hes making, he will be replacing damn near every part of that car.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 05-07-2013, 08:12 AM   #22
Wes B.
Automotive Enthusiast
Wes B.'s Avatar
I know. When I said "power," I was referring to the torque of the engine. Still, if these engine are boosted to 300+ hp, they'll be putting out more torque than an SR20DET.
Oh, I've done my research. I'll most likely be settling with FBM's 8.8 IRS rear differential conversion.
This is exactly why I would like to locate a suitable replacement before installing anything crazy. The W55 from Marlin Crawler seems to be just what I am looking for. Just wondering what you guys had in mind.
Wes B. is offline   Reply With Quote
Old 05-07-2013, 09:40 AM   #23
wparsons
wparsons's Avatar
Stock SR20DET's make 202-210 lb/ft stock, which is around the torque these engines seem to make boosted at around 280-300whp (obviously depending on turbo selection).
My point was simply that at XXX hp an SR20DET is most likely going to have a lot more torque than an FA20 at the same hp, and the transmissions seem to be fine with 300whp SR20's all the time.
flickr
Old 05-07-2013, 03:27 PM   #24
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
R154, used V160/161, look on the supra forums. Hell, if you want a W55, look on the other forums. Its pretty easy. But, you might have to become a member of the forums to see the sale threads.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 05-07-2013, 10:06 PM   #25
Wes B.
Wes B.'s Avatar
I gotcha. Thanks!
How does the R154 compare (strength-wise) to the W55?
Old 05-07-2013, 10:13 PM   #26
DavidV
Drives: WJ Cherokee 04
The only story where anyone reported breaking anything trans related was when someone caught air while full throttle on track driving a turbo car, this story occurred way back in the day during track testing. Might have been John Visconti or Don? ..Correct me if I'm wrong anyone
DavidV is offline   Reply With Quote
Old 05-07-2013, 10:47 PM   #27
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
And axles have been proven to be a weak point too
Old 05-08-2013, 11:10 AM   #28
Wes B.
Wes B.'s Avatar
Gotcha.
I'll most likely be settling with Full Blown Motorsport's 8.8 IRS rear differential conversion.
2jz, aisin, is300, lexus, twin turbo
Comparison with 944 taosracer FR-S / BRZ vs.... 51 06-10-2016 04:55 PM
The strength of an 86... Vic_RSA AFRICA 34 05-31-2016 03:59 AM
FR-S A/T strength/durability? 07stealth350z Scion FR-S / Toyota 86 GT86 General Forum 1 06-18-2012 12:58 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
