Old 05-07-2013, 10:38 AM   #1
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Question Shift light for gt86
Hello, I have a Toyota GT86. My oem tachometer doesn't come with the shift light... Is there any possibility to install and adapt an external shift to it?
Can anybody explain how to it?
Thanks
Toyota GT 86 is offline   Reply With Quote
Old 05-07-2013, 11:03 AM   #2
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
I believe the shift light has to be turned on - at least it does on the US cars. Not sure about cars in other countries.
GTM_Challenge is offline   Reply With Quote
Old 05-07-2013, 11:47 AM   #3
Toyota GT 86
In peru toyota sell the full version with the shift light and the cheapeast one without the shift thats because i wanted to put one... But looks like there is no way to so it.
Old 05-07-2013, 07:34 PM   #4
OnionTou
OnionTou's Avatar
I'm also from Peru... and also own a red GT86. and from what I read we both have the same "cheaper" version. One of the major differences between the GTS86 (upscale version) and the regular GT version is in the instrument panel, our version doesnt have the digitial speedo which can be troublesome to read the analog speedo.
I installed a OBDII and connect my phone to it with bluetooth. Since I have an android phone I use the torque app, and also bought the racing meter skin, so I have my phone on the dash with it, I got a large digital speedometer and a shift light function active.
OnionTou is offline   Reply With Quote
The Following User Says Thank You to OnionTou For This Useful Post:
Toyota GT 86 (05-07-2013)
Old 05-07-2013, 08:54 PM   #5
OnionTou
OnionTou's Avatar
I found a video on youtube, similar to the setup I have in my car.
[ame="http://www.youtube.com/watch?v=k3UQpXZuCKg"]Racing meter for torque OBD - YouTube[/ame]
Old 05-07-2013, 08:57 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
My GTS in Guatemala has it
Old 05-07-2013, 08:58 PM   #7
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
Put the car in acc, push the disp button until you get to the 4th option (one the car won't cycle to if the ignition is on). Hold the disp button and it will go from off to on.
The car will now show you what gear you're in when the clutch isn't in, and a little arrow will appear next to the gear number to indicate shift time.
Gir is offline   Reply With Quote
Old 05-08-2013, 11:31 AM   #8
Toyota GT 86
Yes thanks, I've alreasy knew that. It's cool
Old 05-08-2013, 12:04 PM   #9
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
yep, same in here the basic version also doesn't have the shift light, only the gear position and the arrow to indicate the economic shifting.
But listening to the sound and sneak peak at the RPM is more than enough for me.
gzpermadi is offline   Reply With Quote
Old 05-08-2013, 12:42 PM   #10
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
If you don't have a shift light don't worry too much about it. A general rule to follow for what I would call "normal driving" on flat and level surfaces would be to down shift when you get as low as 2,000 rpm's and to up shift when you get above 26-2,700 rpm's.
whaap is offline   Reply With Quote
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
86 Shift Light Martin Donnon Engine, Exhaust, Transmission 7 08-17-2013 03:34 AM
JDM Fog Light Conversion FR-S > GT86 Wesley Cosmetic Modification (Interior/Exterior/Lighting) 127 05-25-2013 01:39 AM
Factory shift light/chime Wonderbar Electronics | Audio | NAV | Infotainment 29 04-05-2013 03:30 PM
Shift light. Style Scion FR-S / Toyota 86 GT86 General Forum 24 07-19-2012 03:19 AM
