Old 05-07-2013, 02:27 PM   #1
UbSaMrC
UbSaMrC's Avatar
Drives: 13 FR-S Asphalt AT
Bespoke A/V Hidden Option
This method will enable the A/V feature on your BeSpoke system .It replaces the "AUX" input from the sources screen to "A/V".
Useful for a DVD player, media player or whatever you want; I am doing this to add my MK812 android mini-pc to my stock car stereo. I will do a separate DIY for that to keep this simple.
If you already installed a reverse/backup camera, then this should be real easy to do.
REQUIRED:
1 - Female RCA connector
1 - SPST (ON/OFF) Switch for the Vehicle Speed Sensing (VSS)
Some spare wiring
*Optional: If you don't want to insert the wires in the 16pin and 28pin socket, you can use the connectors from an old CD player or floppy drive power supply connector. Better yet, but a Toyota 28 pin harness from Wal-Mart/BestBuy/car stereo place and cannibalize from there.
Below is a simple diagram outlining what you need to follow.
1) Cut the ADPG wire in slot 25 (This detects input from the AUX) from the 28-pin harness and connect it to the ground.
2) Insert a wire/connector in the 6th slot (Parking brake bypass) of the 16-pin harness then tap that to the wire from slot 25 in the 28-pin harness.
3) Cut the pink/green wire in slot 17 (VSS) and install a switch in between. This will allow you to continue watching the video while moving. Optional and I am not responsible if you get in an accident.
4) Insert the positive/red wire from the female RCA connector into slot 13 of the 28-pin harness.
5) Insert the negative/black wire from the female RCA connector into slot 14 or connect it to the ground tap in slot 25 in the 28-pin harness.
You can stop at this point if all you need is a video input since you can still connect to the AUX port in the by the USB slot.
Optional -
(6) Tap the slot 28 (Left+), 27 (GND) and 26 (Right+) and connect it to a pair of female audio connectors
(7) Use a relay to separate/switch if you want to retain the function of the front AUX connector.
When selecting sources, the “AUX” will now show as “A/V”.
Reinstall your head unit and enjoy!
Sent from my SPH-D710 using Tapatalk 2
UbSaMrC is offline   Reply With Quote
The Following 5 Users Say Thank You to UbSaMrC For This Useful Post:
lbroskee (05-07-2013), mad_sb (05-28-2013), post_break (05-08-2013), SloS14 (05-08-2013), Tama-Y (05-15-2013)
Old 05-07-2013, 04:07 PM   #2
UbSaMrC
UbSaMrC's Avatar
Video/gif
Old 05-07-2013, 04:34 PM   #3
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
More details??
hushypushy is offline   Reply With Quote
Old 05-07-2013, 04:38 PM   #4
Hanakuso
Originally Posted by hushypushy View Post
More details??
This. I have no idea whats going on and what's the benefit of it. Backup cam?
Hanakuso is offline   Reply With Quote
Old 05-07-2013, 04:39 PM   #5
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Cant wait for more details. Looks lik 1st step into it being useful
lbroskee is offline   Reply With Quote
Old 05-07-2013, 04:41 PM   #6
UbSaMrC
UbSaMrC's Avatar
Sorry if the pic is misleading, I replaced it with a gif file.
Image you see is from a camcorder/rca out I used to test the connection. This is separate from my backup camera.
The input can be used for dvd player etc...
This method replaces the aux source to a/v and enables the features in the pixs.
Old 05-07-2013, 04:56 PM   #7
lbroskee
lbroskee's Avatar
So it stops u from seein the reg features and just works as a tv screen basically?
Old 05-07-2013, 04:59 PM   #8
UbSaMrC
UbSaMrC's Avatar
It still works the same except instead of "AUX" you will see "A/V". This adds another video input besides the backup camera.
Notice the screen doesn't have the "check your surrounding" warning.
Old 05-07-2013, 05:01 PM   #9
lbroskee
lbroskee's Avatar
Wow, that's very useful. Cant wait for a guide
Old 05-07-2013, 05:18 PM   #10
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
How'd you access that?
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 05-07-2013, 07:50 PM   #11
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
AUX? I don't have AUX. On the second Source screen, it looks like you have AUX and SAT; mine shows CD and BT. Are there different Bespoke firmwares/operating systems?
btw if you have pics of your wiring, please post them! I'm somewhat of a visual learner.
Old 05-07-2013, 07:53 PM   #12
lbroskee
lbroskee's Avatar
USB is the aux if u use the headphone plug
Old 05-08-2013, 03:35 PM   #13
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
I'm sorry, I don't understand what you're trying to say.
The OP says "AUX" becomes "A/V". Well, I don't have "AUX" in the first place...nor do I have "USB" either. My second page is CD and BT, and my first page is this:
Another thing is that I remember reading in the Bespoke manual that if you have Bespoke, the 3.5mm headphone jack cannot be used on its own...only with an iPod connected with a USB + analog cable.
Old 05-08-2013, 03:57 PM   #14
lbroskee
lbroskee's Avatar
Im not sure y his is 2nd page but aux,USB,iPod is all the same thing. Unless this thing is wired weird so cd is aux and this disables CD player
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 10:11 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
FS: Pioneer Premium Upgraded Head Unit (Not-Bespoke, Canadian option) pheoxs Audio/Visual, Electronics, Infotainment, NAV 1 03-22-2013 05:47 AM
I suppose this is an option....for someone. Pscylo Cosmetic Modification (Interior/Exterior/Lighting) 11 06-21-2012 11:34 PM
