Old 05-07-2013, 12:16 PM   #1
Deepmist
Drives: Honda Prelude
Left gas cap off and door open all night in heavy rain
So last night was the first time it rained in months, first time with my new FRS. I managed to forget to put the gas cap back on and I didn't close the door. It rained pretty hard for at least a few hours. Since the hole is angled up so much and nothing else seems to preventing entry of water I'm a bit worried.
Do you think I need to take any precautions?
Deepmist is offline   Reply With Quote
Old 05-07-2013, 12:24 PM   #2
SkullWorks
Drives: SSM LT MT BRZ
Wow this has to be a troll,
There is no reason to have your gas cap off at home...or anywhere except a gas station.
PREcaution the PRE means you do it before you do something stupid...not after.
if this is real you HAVE to get your fuel tank drained you do not want to run that gas thru your car.
Old 05-07-2013, 12:27 PM   #3
leon78
leon78's Avatar
Drives: 13 Whiteout
Prob got some deepmist in your tank.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 05-07-2013, 12:28 PM   #4
DieselxIndustry
Drives: 2013 Firestorm FR-S
yeahhh...... drain that tank, don't drive it. Remove rear seat to access it and suction out the fuel or drop the tank. IDK the difficulty of doing that though.
DieselxIndustry is offline   Reply With Quote
Old 05-07-2013, 12:28 PM   #5
Deepmist
I guess I should have mentioned I left it off after getting gas on my way home. My roommate noticed it this morning.
If I drain the tank, I have to get all 13 gallons out? From what I've googled so far, I was hoping there shouldn't be enough water to be a big deal.
Old 05-07-2013, 12:41 PM   #6
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
well, lt's think about it... ain't it hard to say if you don't even have any idea how much water is inside your tank, don't you think?
Walla Walla is offline   Reply With Quote
Old 05-07-2013, 12:47 PM   #7
Deepmist
I just figure because the hole is so small and it is mostly covered by the body of the car it probably didn't get much rain. I'm about to drive it to work and I just wanted peace of mind. I suppose I should be calling a mechanic. Thanks.
Old 05-07-2013, 12:50 PM   #8
infinite012
Drives: 13 DGM BRZ Ltd
You should be calling a tow truck.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
Ingen (05-07-2013)
Old 05-07-2013, 12:54 PM   #9
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
What you should be asking yourself if you decide to just drive it even if there is a lot of water in the tank... "Is it worth the risk?" Is roughly $40 of gas too much of a loss for you? It should be real easy to pump the gas out. The seats come off easy, and the tank is right there. Depending on the type of gas reservoir, you might be able to siphon the gas out of the gas cap area, I doubt this will be in option though since most if not all newer cars have defense mechanisms for that.
Lift the back seats, lift the hatch, open up the gas tank, and siphon it all out, this is the best way to do it. Tough lesson to learn.
Surakusa is offline   Reply With Quote
Old 05-07-2013, 01:00 PM   #10
B L U E S L A T E
Drives: BMW E84
Oh man... Had a good laugh reading this. What a great way to start the morning.
B L U E S L A T E is offline   Reply With Quote
The Following User Says Thank You to B L U E S L A T E For This Useful Post:
WRXGuy1 (05-08-2013)
Old 05-07-2013, 01:06 PM   #11
Deepmist
I know it's a stupid mistake, I feel like an idiot, but wow this forum can be pretty unfriendly.
Thanks for the response Surakusa. As for the logistics of emptying a full tank of gas, I'm not sure I have the tools or storage to do it so I guess I'm probably going to have it towed if the mechanic says something similar. What a nightmare.
Old 05-07-2013, 01:08 PM   #12
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
In case you remove the gas, this might be useful for you
Also accidents happen, don't feel bad.
http://www.ft86club.com/forums/showt...ing+back+seats
FR-S Hot Lava is offline   Reply With Quote
Old 05-07-2013, 01:08 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
give a break to OP. we all make a stupid mistake once. like others said, don't risk it driving it if you have no idea how much water in. if you don't know what you are doing, tow it to shop or bring a tech guy to take out gas even though it costs $$$$. better than spending over thousands dollars to fix your motor
Old 05-07-2013, 01:09 PM   #14
raptor87
Drives: 2013 DGM BRZ Ltd
Dont drink and drive
raptor87 is offline   Reply With Quote
The Following User Says Thank You to raptor87 For This Useful Post:
Laika (05-07-2013)
Door Open Switch Raz BRZ First-Gen (2012+) — General Topics 7 04-10-2022 05:07 PM
Door wont stay open cregor Issues | Warranty | Recalls / TSB 21 06-11-2013 11:43 PM
Any water drips from above door in rain? josby BRZ First-Gen (2012+) — General Topics 9 01-17-2013 06:22 PM
Visibility at night during rain Bleevin CANADA 11 10-26-2012 12:53 AM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
