#211 |
Drives: '13 BRZ, '06 997, Other Things(TM)
Not surprised that the car got another negative review from "that guy" who did EVO's Nice --> UK BRZ video. He seemed to hate on the car the whole time for not being powerful enough, complaining that he couldn't pass people on highways etc.
I'd be curious to drive that Renault-- I'm absolutely shocked that they could prefer any kind of front-drive car to the BRZ. Sure, you could comment on how the BRZ is a little sterile at low speeds (Motortrend did an interesting comparison with the MX-5 along these lines), but a front-drive car? Really? v0v To each their own, I guess. Personally, having driven rear-drive cars with way more power/torque on tap than the 370Z I just don't agree with them that lack of torque is as big of a problem in the BRZ as they make it out to be. Yeah, if you wanted to go around doing great big Chris Harris-y skids (which-- notably-- Chris Harris manages to do in this car just fine) you might find that it's a little short on power: IE, you can't just punch the throttle and induce wheel spin. On the other hand, how often do you get the chance to drive sideways through corners on the street? Almost never. I find the car has plenty of torque for playing with the car's balance in corners. Yeah, I might not be able to punch the gas and send the back end sideways whenever I feel like it, but there are plenty of awesome sportscars that don't have the oomph to induce wheel spin on command. I don't find myself shying away from the throttle while driving our 993 on the street, and that's a superbly entertaining vehicle. Much like the BRZ, the 993 can be driven into corners in ways that will let you hang the tail out, but it doesn't feel like a muscle car. That doesn't mean it's not a ton of fun to drive (and, IMHO the perfect road car). I've also driven cars that do have the torque to kick the rear end out from a standing start in third gear, and guess what: while it's always fun to have the power on tap, you almost never, ever get to use it on the road. That, in my opinion, similarly frustrating to not having tons of power on tap in the first place: you can usually make up for lack of power with proper weight transfer, but you can't make up for a bad chassis with an oversupply of power. The car I have in mind here happens to have both a nicely sorted chassis/suspension and tons of power, so it's a lot of fun at most any speeds, but the car was nowhere near as fun with the stock suspension, where it felt like it had a lot of power that was sloppily applied and largely un-usable, which is pretty much what the 370Z sounds like from that EVEO review. I simply don't understand how you could rank a car like that above the BRZ. I found Chris Harris' appraisal of the 86 much more accurate: slow, but with a really sweet chassis. I won't weigh in with a final verdict until I've finished break-in (150mi to go!) and run my BRZ on the same roads in California that I've driven extensively in other cars for a more direct comparison, but my initial reaction to the BRZ certainly isn't that it makes fun inaccessible. If anything, it reminds me a bit of the Lotus Elise: not wildly powerful, but superbly balanced and very communicative. |
#212 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
First off, they fail by comparing a slushbox auto to manual cars. Automatic disadvantage.
Second, the brz looks better. Third, miatas are for women, gay men or broke guys in a midlife crisis. (No offense) Fourth point, penis envy. Lastly, let me cost correct the brz to as much as I'd pay for a 370z and none of those cars could keep up enough to read the license plate.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
#213 | |||
Drives: TBD
Fact is though that most of the Brit reviewers have raved about the Megane's handling, despite it being burdened with all the disadvantages you list and more - wrong wheel drive, height, weight. I'm agnostic on the commonly held supposition that "it [insert RWD sports car here] has to a priori be better because it's...", which is why I am tempted to wait until I can test both the Toyobaru and the GTI MK7 on the same day before dropping my cash down. Quote:
Sure you can probably break the rear end out a bit in the twins through most corners by using the "momentum" method of riding the edge of grip through the apex and then stomping on it, but let's face it - for most drivers in most conditions that's a pretty dangerous way to be cornering on public roads. It would be far safer if you could go through the corner at 7/10ths and then get the rear end to slide a bit on exit with a deeper nudge of the gas pedal (maybe leaving your TC in sport mode to protect yourself should you overcook things). Last edited by Sport-Tech; 05-04-2013 at 03:11 AM. |
#214 | ||
But putting aside my disagreement with Evo's assessment, perhaps the greater point is, why are the BRZ/GT86 being criticized by Evo for that when neither the Megane nor the mk7 GTI are able to throttle-oversteer at 7/10ths in a corner either? In the twins, punching the throttle at 7-8/10ths will at least get you a bit of tail wag. In the Megane or mk7 GTI or Focus ST (or insert FWD hot hatch here), you would simply induce copious amounts of understeer. Again, seems like a biased perspective by Evo to try to hold that against the twins.
2022 BRZ Build 2013 FR-S Build Last edited by DarkSunrise; 05-04-2013 at 06:00 PM. |
#215 | |
Drives: TBD
Interesting to hear your experience on the autoX track!
From what I've read in the early reviews of the MK7, the new LSD is trick enough that you can't really induce on-throttle understeer. Of course we are all familiar with "junket review disorder" in which initially rosy reviews based on flyaway junkets get moderated or outright contradicted in later testing (especially comparison tests), so we'll have to wait a bit longer for more definitive commentaries on the new GTI's handling. Some other reviewers are now souring a bit on the BRZ - this from R&T's long-term test: Quote:
#216 | |
![]() Yeah I liked that BRZ review (and other long-term reviews) because I don't think the twins make as much sense if you're not into track or autocross, or at least frequent spirited drives on backroads. As pure daily drivers, there are more commuter-friendly options. To me, that's where the GTI's forte lies because it does have that element of refinement. Also under 7/10ths driving, a lot of the blemishes in its driving dynamics stay hidden.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Superhatch (05-06-2013) |
#217 | |
Drives: FR-S MT & FJ Cruiser
I'm approaching a year of ownership, still love the car, but it's underpowered imo...
Some will fall in love with life and drink it from a fountain That is pouring like an avalanche comin' down the mountain |
#218 | |
Drives: Scion FR-S/Toyota Yaris
People compare the twins to the E30 BMW's but its chassis is better. This car has a chassis that matches a E24 BMW with 600 lbs less weight. A new E24 cost $40k thirty years ago ($100k today.) It was an unsung Autobahn super-car that had amazing handling for its weight. The FR-S is faster in the quarter and 0-60 than that old $100k BMW supercar. Cars have taken a huge dramatic turn for the worse as far as chassis in the last 30 years, Heavy, FWD, Unibodies. appliances. Some with turboed torque but still appliances. As far as HP/Torque, the main revolutional "advancement" for torque/HP came with intercooled turbo charging engines, popularied with the '86 Regal/GN. The Buick engineers pioneered electroni FI + intercooler + turbo. Those cars had frames. Drag race solid axel cars. Slap the same concept into a FWD unibody econobox with 300 ft-lbs of torque is not a drivers car no matter how much weight they add to "tighten" the chassis and make it meet safety regs.. This Toyobaru car has the same price (inflation) adjusted as a the 1994 Civic Si from 20 years ago. A car that would have never become hugely popular/satisfying were it not for the double wishbone front which helped offset the wrong wheel drive matched with its bullet-proof under-powered engine. This Toyobaru has the COG so low as to not need DWB up front. The chassis is a blank canvas to add as much motor as one wishes over the next 20 years of ownership. If you buy cars and trade them in every 2 years, find something else. This car is a keeper, meant to be owned, personalized, upgraded. And I bet this 100hp/L low torque motor is as bullet proof as the old Honda motors proved to be. Its as revolutionary as the 54 vet or 64 stang. Not a debut magazine queen. On the roads I drive I ask what good more HP/Torque would give me? Less downshifting, thats it. Driving the same roads FWD I always get that rollercoaster pit in the gut WTF nausea, thats uncurable. Adding torque is very curable, unless you trade in every 2 years.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib Last edited by regal; 05-05-2013 at 10:49 AM. |
| The Following User Says Thank You to regal For This Useful Post: | Superhatch (05-06-2013) |
#219 |
Terrible review.. Automatic BRZ against a bunch of manuals? I'd rather drive a manual Corolla than an Auto BRZ/FR-S. Give them a manual with a good ECUTEK tune and a $500 set of good tires. Still way cheaper than buying a 370 and much more fun. I agree with the dude that said Miatas are for chicks and old broke guys trying to look cool. Oh, a FRENCH car? Come on now. That's just stupid to begin with.
#220 | |
#221 | |
Drives: '12 C63 P31, '23 GRC
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#222 | |
Drives: 2012 WRX Sedan
Even if I'm wrong and it costs Subaru $5k to add all of this stuff (on their end), my original point is that a 300hp FR-S/BRZ will be much closer to 40K MSRP than anything else. Why? For four reasons: 1. They can, because it would be very comparable (if not better) than a Cayman S at (still) 10k+ less. 2. It costs WAY more than you think to add a turbo (at this point in the development stage). Even if they add the DIT 2.0 from the Legacy GT, they still have to (again) make sure it passes emissions here, balance the car, strengthen/add parts (larger exhaust), provide a warranty, etc./in short you're paying for R/D time; at this point it would be an almost entirely different car. 3. It will most likely be an STI version. 3b. They wouldn't want to cannibalize other sales so they'd have to price the car at a premium. --- When I wrote this post last year I'll provide some context: In the beginning here people were all, "Oh the FRS/BRZ is going to be in the low 20's! There's nothing here that will make the car close to 30k" And obviously the car is selling for what it is now and people dropped like flies because they couldn't afford it. And very generally my point was that people think that more power is easily reliable and obtainable on the cheap, it isn't. The only way to "cheat" is to go aftermarket. And even then a Stage 1 kit + ECM + Tune + any extras (exhaust, wheels, tires, brakes) = 7k+. But we already covered this. Over time the cost of things like development will go down, and the longer the BRZ is in development the cheaper adding more power will be, however when that time comes (if ever) the car Subaru comes out with will most likely be an STI version which will be 10k+. So either way my ultimate point stands. TL;DR It's not cheap to add power, especially if it's reliable. And even if it's cheap for Subaru to do, they're still going to charge a premium for it. |
#223 | |
Drives: TBD
#224 | |
On another note, I went and carved some canyon roads today and realized that the BRZ reminds me a lot of the first-gen, base-level Boxster. After trying to sort out what car the BRZ reminds me of the most, I think I might have found the answer. |
| SoCal BRZ Group Buy | Giccin | Southern California | 1297 | 04-27-2013 02:29 AM |
| Houston Group Buy | BradBot | Southwest | 110 | 06-11-2012 02:20 PM |
| Australian BRZ Group Buy | coyote | AUSTRALIA | 20 | 04-19-2012 06:56 AM |
| Ontario (or whatever) Group Buy | no_name | CANADA | 6 | 02-05-2012 08:39 AM |
| FT-86 focus group | mokinbird87 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 11-11-2011 04:11 PM |
