#113 |
Drives: Subaru BRZ 6MT LTD
I actually installed the AEM tuned intake today.
The process took A LOT longer than I expected...2 hours. And, I'm still not done because the intake doesn't even fit correctly. I am trying to decide if I should return it or what. The inlet tube seems too large to fit through the airbox housing. It fits with about 2 mm of space, and they want you to fit a 10+mm rubber seal between that and the box. Needless to say it did not fit. I am kind of disappointed with this intake. I took it for a spin and the intake sounds nice, although it does feel like the car lost torque in the lower powerband and gained noticeable amount in the 5k-7.5k range |
#114 | |
Drives: FRS 2013
#115 | |
Let me be clear, the inlet tube barely fits in the airbox hole. The problem arises when I fit the rubber seal on the airbox hole. Since there is only 1-2mm of space, if that, on the inlet tube - there was no way in h e double hockey stix this thing was going to fit with the seal. It is physically impossible. I tried the mild soap and water, tried wb40, tried every single way for 2+hours to get this one piece to fit. My fingers are so torn up. I even had a shop look at it, they concurred there was no way it would fit bc either the inlet tube is too large, the hole too small or the seal is wrong.... so I hope to get this resolved. The intake installation, besides this misfitment of pieces was super easy and super quick... |
#116 |
Drives: 2013 Scion FR-S White Out
Did anyone get a real dyno of this AEM intake? Those of you that have ran the AEM intake for a while, how do you feel about it?
#117 |
fastest frs in sbg
Drives: sick ass ultramarine frs
So if I have a unichip. What do I run with. The unichip or the module provided by aem. I would like an unbiased opinion.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#118 |
Drives: 2013 Asphalt FRS
I installed my AEM intake few day ago, its seem like it lower the MPG down. I use to run avg 28.5, now im running 22-25. Is it suppose to be like this? Does anyone had this problem or is normal?
| The Following User Says Thank You to benlaz88 For This Useful Post: | LXXXV1 (04-13-2014) |
#120 |
Drives: toyota mr2/ Toyota GT86
Thing is chaps we all know that the car runs pretty rich as standard and likes to run leaner
so this test has to be done with the same AFR between the stock intake and the AEM as any fiddling with the MAF signal to lean things off will artificially make a gain on top of any airflow gains I've yet to see any intake make more gains than a drop in filter when all things are equal although I do like the look of this one |
#121 |
Drives: 2013 BRZ Limited WRB
Any update from those that have it installed? Happy with it?
#122 |
Drives: 2013 Scion FR-s
I got mine from Pep Boys and it cost me $340. I installed it the next day. Done in a hour. I just applied a little vasoline and the tube fixed just fine. I just had to cut a bit of the gasket. I also applied a small amount of silicon where the gasket met to seal that area. Plus it was a great day in South Florida.
#123 | |
#124 |
Drives: Pavement MT GR86
@USMC what's the foam on your wires and air conditioning for?
GR86 MT premium
#125 | |
Drives: frs
#126 |
Drives: Ultramarine Frs
Still no dynos on this intake? I'm interested in picking one up but still would be nice to see some numbers !
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 03:53 PM |
| Invidia N1 - VIDEOS and Installed Photos ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 200 | 05-16-2017 07:07 AM |
| Fortune Auto - SpeedFactory Review - Video / Pics - Tracked / Autoxed / Drifted | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 01-29-2015 10:15 PM |
| ***Invidia N1 FRS / BRZ SALE*** Videos and Photos - FT-86 SpeedFactory does it again! | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 33 | 10-24-2012 11:11 PM |
| aFe Intake - SpeedFactory Style - Pics and Video | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 0 | 10-18-2012 12:54 AM |
