Old 05-04-2013, 02:54 PM   #1
vtmike
vtmike's Avatar
Drives: Scion FR-S
Richmond VA Dyno Day Results 5/4/13
Dyno performed at Performance Autosport on a dynojet.
My car: nameless axleback, nameless downpipe, perrin inlet tube, k&n filter.
vtmike is offline   Reply With Quote
Old 05-04-2013, 03:16 PM   #2
DIM
Bad image?
DIM is offline   Reply With Quote
Old 05-04-2013, 03:28 PM   #3
vtmike
vtmike's Avatar
Drives: Scion FR-S
I'll see if I can get something better
Old 05-04-2013, 04:10 PM   #4
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Heres mine, even though I don't want to post it
Mods:
-Visconti pump gas tune
-SRT header back exhaust with high flow cat
As I mentioned at PAS, I'm pretty sure the issue is related to my missing snorkel. The car doesn't feel like a 157whp car though.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-04-2013, 04:18 PM   #5
xjohnx
Grip>Slip
xjohnx's Avatar
Mods:
I just noticed in the videos of your car it looks like there's some kind of smoke coming out of the exhaust. Is that water, or something to be concerned about?
Old 05-04-2013, 04:23 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
There's mine. Ignore run 3, that was from when I was there in October. Same mods both times, just different revisions of Visconti's tune.
Mods:
Nameless Performance Overpipe/Downpipe/Highflow cat w/ resonator and Axle-Back (Original style, non-offset, 4" mufflers)
Visconti E85 Tune
K&N Panel Filter
Old 05-04-2013, 04:30 PM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yep, I noticed it as well. When I installed the exhaust, I noticed more soot on the back bumper. I figured it was just the high flow cat, but Mike has a hfc too and didn't blow as much smoke as mine. I noticed some smoke from the other cars as well, but it looks like water. The smoke from my car looked black, so Im wondering if Im running rich. The O2 that PAS used was placed only on one exhaust outlet, so the gasses ran through two cats. I may very well have been running rich too.
I'm installing my AFR gauge this evening, so I'll see what the readings are from a wideband before the cats.
Edit - Does the smoke look black to you, or white/gray?
Parting out HERE
Old 05-04-2013, 04:48 PM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
looks grayish, checked the original video and it looks like the smoke starts around 6500 RPM
Dezoris (05-05-2013)
Old 05-04-2013, 05:02 PM   #9
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yep, definitely high RPM. I recently had to fill my coolant overflow tank. Im hoping its not a head gasket, I don't want the to have the dealer rip apart my engine.
Ill be sending a sample to Blackstone really soon, fingers crossed that its not coolant - but thats where the signs are pointing.
Parting out HERE
Old 05-04-2013, 05:12 PM   #10
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Videos:
[ame]http://youtu.be/bbpqSsF9m0s[/ame]
[ame]http://youtu.be/ReRXABkoido[/ame]
[ame]http://youtu.be/uIjIy-gtVT8[/ame]
[ame]http://youtu.be/2gmeZ_10kDQ[/ame]
[ame]http://youtu.be/baWAkpP2MXM[/ame]
John - I see what you mean about playing them all at once
Parting out HERE
Old 05-04-2013, 05:17 PM   #11
vtmike
vtmike's Avatar
Drives: Scion FR-S
[ame="http://www.youtube.com/watch?feature=player_embedded&v=xcpZ0EnMKME"]Mike's Dyno Run - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=6RAdhC1yzE4"]Civicdrivr's Dyno Run - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=uIp_fW_FAa0"]My dyno run - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=lgbfuKf4oFg"]Ninja's Dyno Run - YouTube[/ame]
[ame="http://www.youtube.com/watch?feature=player_embedded&v=Kcv3vyHlCCQ"]Swift996's dyno run - YouTube[/ame]
The Following User Says Thank You to vtmike For This Useful Post:
swift996 (05-05-2013)
Old 05-04-2013, 06:05 PM   #12
vtmike
vtmike's Avatar
Drives: Scion FR-S
That sucks man. Hopefully it's nothing serious.
Old 05-04-2013, 07:19 PM   #13
Lonewolf
Lonewolf's Avatar
Drives: Moped
@civicdrvr
If you're running super rich I could see why you seem to be down on power.
Grayish smoke is usually oil....and white like you said is usually coolant from a leaking headgasket...I hope its not either...
It is really hard to tell what color the smoke truly is on the videos from the way the light is shining at the back of you car from the outside...
Old 05-04-2013, 07:39 PM   #14
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Here's mine:
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Richmond va dyno vtmike Mid-Atlantic 102 05-20-2013 10:18 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
TRD cat back, any dyno results MTCRX Engine, Exhaust, Transmission 4 11-26-2012 06:26 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
