Old 05-04-2013, 02:40 AM   #29
forzajuve
Drives: Ultramarine 86 - 6MT
You make a strong point
forzajuve is offline   Reply With Quote
Old 05-04-2013, 03:06 AM   #30
reeves
Originally Posted by campy View Post
Originally Posted by Foobar View Post
Header/Overpipe/Frontpipe will give you more gains than the catback.
It will also add noise and drone, which will get old quick if it's a DD.
My car's a DD, and I have all 3 and there's no drone, and not that much noise (sounds like a really quiet aftermarket exhaust).. as long as you get a cat on the header & a resonator on the front pipe. You'll still gain ~20 whp too if you get it tuned.
The Following 2 Users Say Thank You to reeves For This Useful Post:
forzajuve (05-04-2013), Sonolin (05-04-2013)
Old 05-04-2013, 03:10 AM   #31
Sonolin
Good to hear! I'm looking at this combo eventually. What brand exhaust and header do you have?
Sonolin is offline   Reply With Quote
Old 05-04-2013, 03:15 AM   #32
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Originally Posted by forzajuve View Post
What is this BRZedit you mention?
Anyone?
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 05-04-2013, 03:21 AM   #33
reeves
I got all 3 from FA20club.. along with their CAI. Cat-back is still stock.
Old 05-04-2013, 06:48 AM   #34
YDNA
YDNA's Avatar
Drives: Raven FR-S
is there a specific catback you're looking at or waiting for? i was planning to go with the fa20club set up too. pretty much exactly what you've done. how much have you spent in total for everything?
YDNA is offline   Reply With Quote
Old 05-04-2013, 07:08 AM   #35
NickFRS
Drives: 2013 Asphalt FRS
I have a BRZedit tune.... It's basically like open source for our cars. @epifan makes it.... I love it. It's also like a cobb protune. No license require. No special cable required. You can try to find a local dealer..... PREracing in portland is where I go for my tunes. I paid $300 bucks for my tune when they have the intro 50% off going.... Now its $600. Basically they put the car on the dyno. Put a BRZedit map on the car. Then tweak it for the mods on the car on the dyno till everything looks good.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-04-2013, 08:58 AM   #36
regal
Drives: Scion FR-S/Toyota Yaris
It is a great alternative, but right now there are very few local tuners who have it, but there are also very few local tuners willing to deal with Ecuteks cost so I think it will spread like wildfire.
Its much less expensive for both the tuner and the customer, hopefully eventually we will have the option to share opensource basemap tunes for things like headers/exhaust so our money goes to the skilled welders instead of european software developers.
The cost of the tune is holding back a lot of smaller innovative companies from entering the competetion.
I'm waiting out on all mods till all this is settled, these aren't Porche's and shouldn't require $900 worth of licensing, cables, for a basemap, just to bolt on a header, the market just won't bear it long term.
As far as reliability of turbo vs supercharger, the biggest issue folks are facing is heat. A FM intercooler and boost takes its toll on the stock cooling system. I think its too early to tell which is most reliable, a cenrifugial super charger takes more boost than a turbo for the same Hp, but of course a turbo can heat up the oil faster.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following User Says Thank You to regal For This Useful Post:
Old 05-04-2013, 10:02 AM   #37
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
Originally Posted by BRZPDX View Post
save all that money, buy Vortech or Avo. HP/$ ratio is better this way. And you probably won't blow your motor with those 2 if installed correctly. Unless you are going N/A all the way.
Even with this you'll need the tune. Plus it'll still be quiet with the vortech and stock exhaust. I'd go with the header, nameless over/front pipe and a proven exhaust.
fender9530 is offline   Reply With Quote
The Following User Says Thank You to fender9530 For This Useful Post:
Old 05-04-2013, 11:29 AM   #38
stockysnail
Just the tip
stockysnail's Avatar
Catback and intake won't do much at all for hp. I know as I'm at just about the same hp as stock vs with headerback and intake swap. Stick to headers and a tune and use leftover for overpipe and exhaust, then intake last if you have money left.
The Following User Says Thank You to stockysnail For This Useful Post:
NickFRS (05-04-2013)
Old 05-04-2013, 11:52 AM   #39
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Is drone common on all headers? or just the UEL headers?
gatorbushmen is offline   Reply With Quote
Old 05-04-2013, 11:57 AM   #40
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
The headers will only amplify any existing problems within your current exhaust setup. If your exhaust is properly resonated then you will get no drone regardless of who's headers you put on.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 05-04-2013, 12:26 PM   #41
Xdragonxb0i
Drives: ex500r
As people said before. Get headers. Front pipe /over. And a tune. Save up for a cat back. The stock one will aiffice
Xdragonxb0i is offline   Reply With Quote
The Following User Says Thank You to Xdragonxb0i For This Useful Post:
Old 05-04-2013, 12:37 PM   #42
regal
what is the difference between a front and an over pipe?
Also if you buy headers do you have to replace the stock front and overpipe?
Mods:
Wheel Directory: 5Zigen FN01R-C 18x8.0 +35 jma Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-26-2013 03:15 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
New tires on a budget jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-23-2013 06:32 PM
BALLIN ON A BUDGET Obja Scion FR-S / Toyota 86 GT86 General Forum 10 10-22-2012 10:17 PM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
