Old 05-03-2013, 01:12 PM   #1
regal
Drives: Scion FR-S/Toyota Yaris
Explain catless header/catalytic converter/O2/losed Loop
Say I want a nice catless header, and downstream from the overpipe a high-flow cat.
Now I understand with a tne I won't get a CEL, but where do I put the O2 sensor, the highflo cat pipes don't seem to have any O2 bungs. And it would seem with a tune that disables the CEL there would be no closed loop.
What is the best way to handle this, I personally don't wantcats in the headers, too close to the engine reminencent of the MR-S, but I want closed loop for economy right?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 05-03-2013, 04:58 PM   #2
wparsons
wparsons's Avatar
There's two cats, one in the header and one in the front pipe. The Factory O2 sensors are around the cat in the header, so no catted front pipes need bungs.
If you're not worried about the CEL (or will have it tuned out), just get the header with bungs in it. You only need pre-cat O2 for closed loop, the post-cat O2 just tells the ECU how well the cat is working, and has no effect on how the car runs.
flickr
scary alien (07-12-2015)
Old 05-03-2013, 05:53 PM   #3
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Even you run a catless header and with a catted front pipe, you still will get a CEL because you need the secondary oxygen sensor located after the catalytic converter (so it will measure the exhaust flow between Primary O2 sensor to secondary O2 sensor). You will probably needs to weld a bung after the cat and extend the harness in order not triggering the CEL.
AJ PwR is offline   Reply With Quote
Old 05-03-2013, 11:12 PM   #4
regal
Now that makes sense. Thankyou!
Mods:
Old 05-03-2013, 11:37 PM   #5
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
The second O2 sensor does determine how the car runs if the second o2 is telling the ecu that that certain elements are more than others such as CO it will give the engine less fuel and vice-verse.
alex_86 is offline   Reply With Quote
Old 05-06-2013, 10:51 AM   #6
wparsons
wparsons's Avatar
Nope, that's the first sensor's job. The only thing the second sensor does is tell the ECU how effective the cat is.
flickr
Old 07-12-2015, 12:22 PM   #7
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Sorry to bump an old thread - but there's something I might not be understanding. If the primary O2 sensor determines how well the car runs - does that mean that I can't install my (catless) header in my driveway, then drive it to get tuned?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 07-12-2015, 02:36 PM   #8
DM7
Drives: '13 FR-S Argento
On a stock header the primary O2 sensor is the one closest to the engine between the engine and the header cat. The secondary O2 sensor is located right after the header cat and in front of the front pipe cat.
In an aftermarket catless header, the primary O2 sensor will see the same exhaust gases that come right out of the engine. The secondary O2 sensor will now see gases straight out of the engine as well.
As far as the primary O2 sensor is concerned, nothing has changed. It will continue to feedback AFR information back to the ECU.
The secondary O2 sensor will see that the exhaust gases have not been cleaned by a cat. This is what will cause a cat efficiency CEL. As far as I know a cat efficiency CEL will not effect the way the engine runs. (see steve99's post below for correction to this comment.)
Put an O2 spacer or defouler in the REAR 02 sensor this should eliminate the P0420 car efficiency cel code due no cat in header .
some headers it shows up quickly some it takes a week or so, just be prepared to reset cel occasionally with andriod torque app or obd scanner reader or pull a battery terminal for 30 secs or so.. If you get cel other than P0420 investigate.
P0420 wont force ecu into limp mode but it will disable cruise control and may drop you to safe afr and timing maps reducing power.
it wont blow up without a tune it just wont generate optimium power due fueliing ignition and cam timing not being optimal for your setup.
stock tunes run rich
your more likely to get issues by changing intake and upsetting maf scaling
The engine will run just fine without a tune optimized for an aftermarket header. It may or may not gain any power. The ECU will throw a cat efficiency CEL.
A tune that is optimized will adjust the intake and exhaust cam/valve timing to take advantage of the exhaust evacuation characteristics of the new header. A well designed header will allow exhaust gases evacuate the cylinder at a higher speed. Adjusting the exhaust cam/valve timing takes advantage of this.
DM7 is offline   Reply With Quote
The Following 2 Users Say Thank You to DM7 For This Useful Post:
D_Thissen (07-13-2015), scary alien (07-12-2015)
Old 07-12-2015, 08:22 PM   #9
AznKirby
Are you 20/20?
AznKirby's Avatar
That is an awesome response. Thank you, Sir.
2014 FR-S Monogram
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Old 07-13-2015, 11:34 PM   #10
DM7
Clarification from steve99
MOTIV Concepts Scion FR-S High Flow Catalytic Converter Akired86 Engine, Exhaust, Transmission 20 01-16-2015 03:38 PM
FS/FT: Motiv Concepts Front Pipe w/ High Flow Catalytic Converter TyperRspec789 Engine, Exhaust, Bolt-Ons 4 02-27-2013 12:16 AM
FS: Motiv Concepts Front Pipe w/ High Flow Catalytic Converter- local sale preferred TyperRspec789 Mid-Atlantic 0 02-24-2013 11:35 PM
SRT header back exhaust catless w/ tip A serial gixxer Engine, Exhaust, Bolt-Ons 6 12-04-2012 11:00 PM
