Old 05-02-2013, 12:35 PM   #15
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Kartboy's stuff is awesome and he's 100% classy about the way he does business. I was making a short shifter for my car as a project to teach me some CNC coding and he helped me confirm some of the measurements I needed even though it meant there wasn't a chance I was going to be buying his shifter because of it. I'll always get the Kartboy version of parts I need to buy if they exist because of that.
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Sportsguy83 (05-02-2013)
Old 05-02-2013, 03:40 PM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've had both. Get the Kartboy pulley. It's cheaper, lighter, looks better, and doesn't have spokes to collect dirt to potentially unbalance it.
Old 05-02-2013, 04:28 PM   #17
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
I would have gotten the Kartboy if I it was available when I purchased it.
This.
Smudgeous is offline   Reply With Quote
Old 05-02-2013, 04:35 PM   #18
Visconti
Drives: 05 STi
Kartboy FTW
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Old 05-02-2013, 04:44 PM   #19
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
This
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
The Following User Says Thank You to akuhei For This Useful Post:
Old 05-02-2013, 05:29 PM   #20
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I have perrin only because I got it cheap. Either way it is night and day with throttle response.
post_break is offline   Reply With Quote
Old 05-03-2013, 09:31 AM   #21
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
is there any point of getting this if you have AT?
Obja is offline   Reply With Quote
Old 05-03-2013, 10:12 AM   #22
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Go Fast Bits: .75 lb
they have a 3 piece set that saves more weight with other pulleys too.
Edit: Rally Sport Direct has them here
EvilBeaverFace is offline   Reply With Quote
Old 05-03-2013, 10:13 AM   #23
OrbitalEllipses
Drives: Attitude
It won't feel as dramatic. Couldn't really tell on my WRX, but this is a different car. YMMV.
Old 05-03-2013, 10:19 AM   #24
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Not really unless you just want some additional "bling" on the front of your engine really. Since in the auto, the transmission is always in various states of "connected" to the engine, you won't see the benefit.
Scott
naikaidriver is offline   Reply With Quote
Old 05-03-2013, 10:21 AM   #25
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
I thought the pulley needed enough weight on it to prevent a CEL.
jordanrw260 is offline   Reply With Quote
Old 05-03-2013, 10:32 AM   #26
ramiram1984
Drives: 2016 STi DGM
I have tamioka's pulley set. Lighter than perrin's. no CEL.
ramiram1984 is offline   Reply With Quote
Old 05-03-2013, 10:46 AM   #27
OrbitalEllipses
Drives: Attitude
That CEL occurred haphazardly, but usually with a lightweight flywheel. Didn't affect everybody in the Impreza world, but enough for there to be concern. Too light a flywheel with too light a pulley would cause it usually; I wouldn't be concerned if you're not going for a super light flywheel.
EvilBeaverFace (05-03-2013)
Old 05-03-2013, 11:06 AM   #28
s2d4
s2d4's Avatar
why isn't anyone looking at this first?
AVO DBW Controller
http://www.ft86club.com/forums/showthread.php?t=16200
Isn't it important to make sure that you are actually matching your pedal movement to the actual throttle applied?
It doesn't matter how light your pulleys are if the car isn't applying the amount of throttle you think you are applying?
Kartboy crank pulley Turn in Concepts Engine, Exhaust, Bolt-Ons 5 05-22-2013 10:51 AM
perrin pulley perrin intake tube Area51 Engine, Exhaust, Bolt-Ons 4 04-05-2013 06:11 PM
FS: Kartboy Lightweight Crank Pulley OrbitalEllipses Engine, Exhaust, Bolt-Ons 6 03-21-2013 08:21 AM
KARTBOY Lightweight Aluminum Crankshaft Pulley! RallySport Direct Engine, Exhaust, Bolt-Ons 0 10-29-2012 02:55 PM
