Old 04-28-2013, 10:30 PM   #1
dawgchow33
Drives: 13 BRZ WR Blue
$10 matched set of autocross magnetic car numbers (img heavy)
Total cost ignoring ink, paper and tape was $9.99 for a 12" x 24" roll of vinyl magnetic sheet from the local Michael's art supply store. They sell printable and sticky-face versions if that's your thing, but I was going for high contrast and completely waterproof.
imgur album containing more pictures
I picked a relatively simple font with a lot of straight lines for easy cutting. Text was just typed into MS word and adjusted for height using the on-screen rulers. These are simple 8" high characters, printed out and then taped in negative (on the back) for contrast.
You could probably just trace with a pen, but I found that the change in texture going from cutting vinyl to cutting vinyl + paper let me stay closer to the lines. A straight edge, some curve templates and an xacto knife would probably help here but a good pair of scissors seems to work well enough.
When you've been assigned multiple fat characters it's going to have to turn into a game of tetris to keep everything on one sheet.
I wasn't able to fit 100% of my characters onto the one sheet, but ultimately it shouldn't really be all that noticeable
Courtesy tabs (tape partially folded over onto itself) greatly simplify trying to line up all of the numbers on the side of your car.
Lessons learned:
  1. Courtesy tabs can probably be fully behind the characters to give a clean look, as long as you give your finger an edge to catch onto
  2. Put any such tabs on the trailing edge of your numbers so they don't get peeled off by the wind
dawgchow33 is offline   Reply With Quote
Old 04-28-2013, 10:33 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I would just like to warn anyone thinking of doing this
cars get dirty, the stickers get dirty, esp if you're putting them on in a hurry or after a long drive.
make sure that the surface is clean and the numbers are clean, otherwise there is a chance to introduce micro scratches to your clearcoat/paint
it's ridiculous how easily these numbers/decals can get all dusted up. Esp after a rain day etc.
Old 04-28-2013, 10:53 PM   #3
dawgchow33
that's part of the reason why I'm willing to put up with the ugly tabs on the edges - I probably didn't emphasize this enough but you do not want to be dragging the magnets across your door while lining them up. lift and reapply.
Old 05-01-2013, 06:21 PM   #4
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
Thanks for the idea bud. I picked up that 1'x2' roll of magnetic adhesive vinyl. I cut it into two 8.5"x11" pieces (there was a spare ~7" wide piece). Then I made up some numbers in photoshop, printed them to another piece of paper, adhered it to the mag-vinyl, then cut out the numbers. Done one side so far. Takes a while, but I think it looks nice. Dunno how long it'll last, but maybe next time I'll do it out of some heartier glossy paper. Anyhow, here's some pics.
MmmDieselFumes is offline   Reply With Quote
Old 05-01-2013, 07:39 PM   #5
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
No offense to OP, but Why do this? What benefits do these bring? =) I'm just wondering because I don't get it. If you can indulge my curiosity that would be nice.
CamryDS is offline   Reply With Quote
Old 05-01-2013, 07:51 PM   #6
TM
TM's Avatar
Drives: DGM BRZ 6MT
For those that take there cars to autocross, you get assigned a number that you need to put on your car when you sign in. I'm not sure if there are other reasons.
TM is offline   Reply With Quote
Old 05-02-2013, 12:18 AM   #7
CamryDS
Ahh thanks. Why not just use painter's tape for temp and not risk screwing up the paint?
Sent from my PG86100
Old 05-02-2013, 02:42 AM   #8
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Because these would take less effort each time, are very clear and they look great as well.
Good ting to do if you go to autocross regularly
BRAWL is offline   Reply With Quote
Old 05-02-2013, 11:08 AM   #9
CamryDS
Understood -- Just wanted to find out why -- thanks guys.
Old 05-02-2013, 11:13 AM   #10
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Great DIY!
To give others an idea of the cost-savings of doing this yourself, my autocross numbers that I ordered from autocrossnumbers.com cost me $87 for the set!
NEVER AGAIN!
Scott
naikaidriver is offline   Reply With Quote
Old 05-02-2013, 11:32 AM   #11
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Could you paint the magnetic vinyl? Doesn't seem like white paper will hold up very well.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 05-02-2013, 12:46 PM   #12
dawgchow33
I imagine you could paint it with the same sandpaper/deglosser/primer/enamel type setup used for painting vinyl flooring, but a better option might be to spend the extra few dollars to order it pre colored online.
also, if you want to be really fancy you could get a sign shop to cut it with a laser cutter.
Old 05-02-2013, 01:11 PM   #13
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
After using magnetics for autox for about 10 years, I have found that the Michael's magnetic material will get 'roughed up' and tend to fly off cars when aged a few years. I have also used magnetic material I scored from a sign shop for about the same pricing as nationwide Michaels, but with much greater quality, about twice as thick, and these decals/numbers have never come off.
If a person is going to autox any more than once a year, one should leave the blue tape for novices/first timers. This was the first 'mod' I did to my car when I started autocrossing. Besides the pics look better with true numbers, unless one is uber-meticulous, and at that point it may be better time-wise to create semi-permanent numbers from magnets
+1 to cleaning up both car surface and magnetic surface before sticking them on. Just sitting on the shelf, the magnets seem to attract (pun intended) all sorts of dust and debris.
Eric G
mkiisupra is offline   Reply With Quote
Old 05-02-2013, 01:45 PM   #14
Biggins
Drives: Yes
Eric G
I completely agree. The Michaels magnetic material is WAY too thin. It lasted 2 events before they were flying off... I sourced mine from a custom sign/mom-and-pop art store. Their material is at least twice as thick as the Michaels material and still sticks every time.
Biggins is offline   Reply With Quote
Autocross Numbers? Black Tire Tracking / Autocross / HPDE / Drifting 24 02-16-2014 06:45 PM
Nice matched set of FT86 shoes whataboutbob Scion FR-S / Toyota 86 GT86 General Forum 33 12-14-2013 09:59 PM
JDM Paint Matched Foglight Surrounds OmarGC Cosmetic Modification (Interior/Exterior/Lighting) 0 04-14-2013 07:57 PM
Color Matched Roof Spoiler? DNAPoPo Cosmetic Modification (Interior/Exterior/Lighting) 4 03-19-2013 01:00 PM
Color matched splash guards JoeBoxer Cosmetic Modification (Interior/Exterior/Lighting) 1 12-03-2012 12:09 AM
