Old 05-01-2013, 11:43 AM   #43
markitect
Drives: Scion FRS
Originally Posted by Speedygonzales View Post
Changing the length of primary pipes generally affects the amount of torque produced above and below peak-torque rpm. For example, all else being equal, shortening primary pipes transfers torque from below to above the peak, not significantly shifting the rpm point at which peak torque occurs. Increasing primary-pipe length produces the opposite effect of shortening the length.
Based on this it seems like a UEL header should give you good(not the best) results through the entire rpm band, are there any disadvantages to UEL design?
Also with UEL design, is there a specific way that the firing order is matched to the pipe length?
markitect is offline   Reply With Quote
Old 05-01-2013, 01:20 PM   #44
rx3
Xdragonxb0i and Hawaiian thank you for your responses.
I guess the headers just increase exhaust gas velocity, which is subsequently muffled accordingly (less apparently). (And this is responsible for more noise).
Btw, is there also a sort of 'stealth' ceramic coating available, which would make the catted-header appear more stock? (Maybe grayish instead of shiny silver or black.)
rx3 is offline   Reply With Quote
Old 05-01-2013, 01:35 PM   #45
rx3
My guess would be, that each cylinder-bank could scavenge differently due to the UEL design (different fill factors in each bank), which then would lead to different AFRs in each bank. (This is just a guess though).
Old 05-01-2013, 01:44 PM   #46
Tainen
Drives: First SWP BRZ-L
I don't really see any advantage at all of a UEL system. People have this idea in their head that the UEL design is what causes the rumble, but... that's just not true. :P
Also, @Jason@Nameless has some awesome 3d model mockups of variable intake runner designs. I swear he dreams of that stuff in his sleep.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 05-01-2013, 01:53 PM   #47
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Glad to help. I don't know for sure, but I'll call and find out.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 05-01-2013, 02:02 PM   #48
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
Updated: The only two colors the header comes in is Black/Silver.
Dylan@P&L
P&L Motorsports is offline   Reply With Quote
Old 05-01-2013, 04:07 PM   #49
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
No, it is absolutely true. The rumble is caused by the exhaust pulses running into each other as they enter the collector. Depending on the application there may or may not be a serious performance detriment. But the sound is undeniably caused by the header design.
Can a car still have a nice deep tone that's "rumbly" with an EL? Yes. There are things you can do with the rest of the exhaust to make it deeper. But that signature "boxer rumble" that Subaru is known for is 95% because of the UEL headers. Just listen to any EJ engine that's had an EL twinscroll manifold put on it, or even a Honda with an UEL header. In each case the effect of the header design is very clear.
Cheers
Nathan
SubieNate is offline   Reply With Quote
Old 05-01-2013, 05:10 PM   #50
Tainen
Cheers
Nathan
ok. that's not what I've heard from Quirt Crawford. :P
(not trying to be an ass.)
Old 05-01-2013, 05:18 PM   #51
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Just an FYI, like Nate, I am also an engineer but Nate makes me look like an idiot child by comparison.
Just my opinion, but I would listen to him. :happy0180:
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
SubieNate (05-01-2013)
Old 05-01-2013, 05:25 PM   #52
Tainen
Scott
OK. I am not, and only know what I am told by other engineers, which is why I am definitely not trying to argue with anyone here.
Old 05-01-2013, 05:29 PM   #53
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
The problem with nameless is for all the buzz, all they have produced is a front pipe and muffler. I understand they are a small operation an probably want to release the headers when their rudimentary exhaust work slows down. But it still stands that at the end of the day, they produce a few exhaust bits that really don't matter who you buy from. And you have to wait a month for.
And the rumble does come from uel. Any sti guy that went to an el setup will tell you that.
industrial is offline   Reply With Quote
Old 05-01-2013, 05:37 PM   #54
naikaidriver
I'm sorry if it seemed like I was implying your were. I know you weren't. :happy0180:
I was just joining the conversation.
Scott
Old 05-01-2013, 05:40 PM   #55
SubieNate
SubieNate's Avatar
I wasn't either. My post may have been a bit strongly worded.
If Quirt has some explanation other than the headers as to why it completely goes away with every EL setup I've ever seen I'm all ears but the explanations I've heard line up 100% with the empirical data I've seen.
@naikaidriver-*Blush*
Cheers
Nathan
The Following User Says Thank You to SubieNate For This Useful Post:
naikaidriver (05-01-2013)
Figured I would share this April 28th celek NY / NJ / CT / PA 0 04-08-2013 01:57 PM
Apparently you can fit 4 wheels/tires in this car empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 03-31-2013 08:36 PM
Has anyone figured this out yet? chrisrefaei BRZ First-Gen (2012+) — General Topics 16 10-26-2012 04:52 PM
towed at 717miles CEL severe shaking (apparently a huge issue) gdi2290 Issues | Warranty | Recalls / TSB 45 08-31-2012 10:25 AM
Front seatbelt shoulder guides apparently an issue for passengers Mr 286 Scion FR-S / Toyota 86 GT86 General Forum 3 07-01-2012 07:49 PM
