#29 |
Drives: ex500r
nameless dyno graph looks okay initially, but you see at 6500rpm the torque and hp start to dip. I say this due more to tuning then the header itself.
I made post about tge p&l header being loud, i contract my statements, it louder then stock for sure but pretty tame when DD. At 75mph , the noise start to bother me. |
#30 | |
Drives: UK GT86
![]() @Xdragonxb0i the reason it starts to lose power after 6.5k is that's where the limitations of the cams are. It was also posted earlier that header design places peak torque around a set area, which in Nameless' case is where I the original dip is (its quite obvious). You could design a header for more top end grunt but I doubt that it would improve on the lower dip.
.: Stealth 86 :.
#31 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#32 |
Drives: GT86
#33 | |
Drives: car
What about the blue line, between 3250 and 4250? That's a dip too. Or is it a "hump" at 4250? If you could provide the .drf file for the WinPEP7 dyno run, I could make your dip get bigger and smaller in about 5 minutes. You see this all the time on the WRX forums (NASIOC) when a tuner posts how "smooth" the power and torque curve are, by stretching it out like that. I realize that this sounds like sour grapes, s**tting in your cornflakes, etc. Engines with cam phasing typically have "dips" or "humps", unless you kill the scavenging effects. It's physics. You can move it around a bit, maybe change the shape some. It's unavoidable though. |
#34 | |
Drives: 2013 Raven FR-S
#35 | |
Add lightness!
Drives: 17' WRX
![]() Are you saying you can make this graph look flat by stretching it out or something? Wouldn't that be pretty obvious? ![]() ![]() Seems like the massive torque dip from the stock car is pretty much flattened out in Hawaiian's car. Not pancake flat, but significantly improved from stock. Unrecognizable even.
#36 | |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#37 | |
#38 |
Drives: car
those are good graphs, thanks
#39 | |
And are these 'P&L header dynos' also referring to just the header-swap with a stock exhaust? Back to topic: If one wanted a header which increased power equally over the entire rpm range, it would need to have variable length runners like a trombone. (For a similar reason Mazda had 'variable-length-intake-runners' on its 26B race car engine to improve fill factor over a wide rpm range. See picture below.)
#40 |
Drives: Scion FR-S
That was just my opinion lol worth a try...
#41 |
Drives: ex500r
No im not running stock. I have the p&l headers, the nameless front/over pipe combo, and AP mid pipe and muffler. My set up.is quiet and but j can tell that all the noise i get comes from the headers.
#42 | |
That guy
The second dyno chart with 3 lines shows the full P&L exhaust system on the stock tune as a baseline, then the next line is with just the uncatted header, and the last line is reflashing it with visconti's pump gas tune (it still needed tuning).
Ultramarine mt FR-S
| The Following User Says Thank You to Hawaiian For This Useful Post: | P&L Motorsports (05-02-2013) |
| Figured I would share this April 28th | celek | NY / NJ / CT / PA | 0 | 04-08-2013 01:57 PM |
| Apparently you can fit 4 wheels/tires in this car | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 03-31-2013 08:36 PM |
| Has anyone figured this out yet? | chrisrefaei | BRZ First-Gen (2012+) — General Topics | 16 | 10-26-2012 04:52 PM |
| towed at 717miles CEL severe shaking (apparently a huge issue) | gdi2290 | Issues | Warranty | Recalls / TSB | 45 | 08-31-2012 10:25 AM |
| Front seatbelt shoulder guides apparently an issue for passengers | Mr 286 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-01-2012 07:49 PM |
