Old 12-04-2011, 12:58 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by LSxJunkie View Post
It'll pull enough timing. Most NA cars these days are so good on knock retard that you'd be hard pressed to grenade a motor. Liability issues and all. HOWEVER, the money that you saved by putting regular in the car instead of premium, you lose in fuel economy because the car is going to burn that much less efficiently and you'll be using more throttle to get the same result. It ends up being a wash.
Glad I read the rest of the thread first so I didn't have to type that again
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 01:08 PM   #16
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
I think it's just a momentary "win" if you buy regular gas. Sure you save like $0.10 per litre but it also means that it's not going to be very efficient in your engine. Plus as stated above it might be bad for your engine in the long run. I'm sure they wouldn't tell you to buy the more expensive one unless they did some tests, it's not like they gain revenue from gas stations lol
Ikaros is offline   Reply With Quote
Old 12-04-2011, 01:14 PM   #17
Giccin
Giccin's Avatar
Originally Posted by st162celica View Post
If you are NOT going to keep the car for long a time and don't care about the marginal performance decrease, then use 91.
Feel slack for the guy who buys a car that has been filled with 91 when the engine needs a higher octane. I would be very unhappy knowing this if I was to buy it 2nd hand.
Unfortunately, in some States 91 (or I think it was 93) is the highest we can get. If we want the pricy stuff we have to go out of our ways to get it... whether it is at the track.. or 50miles/80km away from us. Other than that it starts going to the mid-high 80s.
Saying that some of us won't keep our cars (might be true for those possibly upgrading down the line or like you said those who completely don't care) is a bold statement for someone who hasn't really put the situations of people in different parts of the world into consideration; however some of us do take care of our cars really well and that's what we're limited too.
Am I calling you out on this? No. I'm giving you a "heads up" on what some of us have what we use to make-do with.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 12-04-2011, 01:25 PM   #18
Dark
Elite Padawan
Dark's Avatar
the US rating differs from other places around the world. And if one car company want to sell cars in the US, they need to tune the engine to suit the US graded gas, no?
Dark
Dark is offline   Reply With Quote
Old 12-04-2011, 01:34 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Correct. All cars in the US that recommend premium specifically recommend 91 octane.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 02:02 PM   #20
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
If the recommended is the 91 [AKI] premium gas, is there any advantage/disadvantage of adding 93 [AKI] gas?
Want.FR-S is offline   Reply With Quote
Old 12-04-2011, 02:34 PM   #21
ryude
Drives: Volkswagen GTI
Not unless you tune for it. I'm sure you could get an extra 5-10 hp out of a 93 tune.
ryude is offline   Reply With Quote
Old 12-04-2011, 06:18 PM   #22
coyote
coyote's Avatar
Drives: Slowly
That's another ignorant guess, the kind that is so common on this forum.
Do you know how Subaru knock management works?
coyote is offline   Reply With Quote
Old 12-04-2011, 08:20 PM   #23
coyote
coyote's Avatar
Drives: Slowly
I take your point on the blow up thing. NA cars can ping for years and years and hold together. Anyone who ever owned a Subaru Brumby knows that.
However, the way the Subaru knock strategy works, there's no guarantee the car can pull enough timing to prevent knock on crap fuel.
What that means with this engine 12.5:1 compression, I don't know. No-one does.
Old 12-04-2011, 08:23 PM   #24
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Drives: Infiniti G20 / FRS
Send a message via AIM to Ak1m0to
I love it when these threads come up.
Don't buy the car if you are going to skimp out on something as frugal as gas.
I'd rather spend a couple more dollars everytime I go to the pump then to have problems later on.
Slowmatic Drfiterz, from P to D in a heartbeat.
Ak1m0to is offline   Reply With Quote
Old 12-04-2011, 08:26 PM   #25
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
The ECU in the car is likely a Toyota, since they're the only ones with D-4S experience. Whatever sub-par knock strategy Subaru may have had in the past likely isnt relevant for your argument.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-04-2011, 08:29 PM   #26
ahausheer
Re-member
Drives: Toyota camry
Required = Car can't pull enough timing in all situations, but probably could in some (ie gentle driving), damage may result at some point.
Recommended = Engine damage will not result from low grade fuel, enough engine timing can/will be pulled at the expence of Hp and possibly mpg.
Nothing decays like progress, and nothing preserves like neglect.
Last edited by ahausheer; 12-05-2011 at 10:05 PM. Reason: I made an incorrect assumption
ahausheer is offline   Reply With Quote
Old 12-04-2011, 09:30 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ahausheer View Post
These companies spent tens of millions of dollars on this car and they know better than we do. If it was cabable of using low grade fuel for its entire life without any significant degradation then premium fuel would be RECOMMENDED not REQUIRED. Don't think that some guy on some forum that has a lot of racing experience or comes off as being ''car'' knowledgeable knows better than Subaru/Toyota. Believe me, in this economy I'm sure Subaru would love to be able to save to consumer money by allowing low grade fuel. If you are going to spend 25K plus on anything follow the instruction manual. The required fuel was studied by real scientists who actually know stuff.
They do label it as recommended btw... personally I have no intention of doing so. It's pointless, what you save in money you lose in fuel economy, making it completely pointless not to spend the money up front.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 11:05 PM   #28
brillo
Drives: 2013 Firestorm FR-S
Your not going to damage the engine running 87 or 89, it will just cut the timing back to compensate and you'll get less HP and likely crappier gas mileage.
Given the car already gets pretty good mileage for the performance, I would just suck it up and pay for the premium fuel.
brillo is offline   Reply With Quote
