Drives: Ultramarine 86 - 6MT
Drag Coefficient
The FRS and BRZ have quite a good drag coefficient, which competes with high-end cars like Porsche, for example, which many might not expect.
The drag coefficient is used to quantify the drag or resistance of an object in a fluid environment such as air or water. A lower drag coefficient indicates the object will have less aerodynamic drag. The drag coefficient is always associated with a particular surface area. Examples: FRS drag coefficient = 0.27 Koenigsegg Agera (R) = 0.33 to 0.37 Mercedes-Benz CLA-Class = 0.23 Audi A4 = 0.29 Nissan GT-R = 0.26 Pagani Huayra= 0.31 Porsche 911 GT2= 0.32 Last edited by forzajuve; 04-30-2013 at 08:50 PM. |
#2 |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
I guess it's got a good one, but cd is really a meaningless measurement. It's kind of like the specific output measure that honda guys want to hang their hats on.
-Justin
#3 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
The only model that comes in .27cd is the GT86 Limited model equipped with a rear spoiler and flat under panels The rest are .28 & .29 respectively. Do the twins cross through air like any of those vehicles you listed? no, they don't. Those cars also produce good downforce while keeping a low cd. While the FRS/BRZ produce very little downforce to begin with. Among any of the newer vehicles under 30k, sure the twins are one of the most aerodynamic, but don't mistake that number as being equal to those high performance models you listed.
#4 |
I disagree. If only what you just said made logical sense and if you understood physics...but no matter. If you feel that way, good for you!
#5 |
Drives: 2002 S2000 2013 Carrera S 2013 FR-S
Don't know about you but my Porsche 991S feels a hell of a lot more stable than my FRS at high speeds.
#6 |
Señor Member
Drives: 2013 Raven, Drifty things
Downforce generally creates drag, but by focusing this drag only where it's needed (front and rear) and cutting it from places where it isn't (mirrors, wipers, bodylines, gaps, etc) you end up with about the same coefficient of drag but much more useable downforce.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
| The Following User Says Thank You to 6-Shift For This Useful Post: | forzajuve (04-30-2013) |
#7 |
Drives: '13 FR-S Ultramarine
The FR-S might not produce downforce like those other higher end cars with similar numbers. For us the lower drag just equals better fuel economy, these cars weren't meant to produce down force at high rates of speed (autocross/drifting).
2013 FR-S Ultramarine
![]() -TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ |
#8 |
A Honda Insight and Prius have similar cd, performance on those cars are close to a GT-R as well.
#9 | |
MODERATOR-SAMA
![]() So im going to assume you know more than me, about physics or about everything in the universe. Then educate me. I understand that cd is the product of the drag force, divided by the quantity: density r times reference area A times one half of the velocity V squared. or Cd = 2Fd/(Apv^2). To find the total resistance of the vehicle. I understand that drag force (a + bv + cv2) equals the variables such as rolling resistance from tires, brake pad and bearing drag and resistence, downforce, ect. I understand that as cd decreases, so does lift increase. I also understand that adding downforce increases cd since it affects the drag force directly. In a wind tunnel or CFD where all variables are controlled, sure a FRS could be just as resistant as a GTR. I also believe that if i took a GTR and 86, gave them equal power & equal weight, they would still not be equal in aerodynamics. Around a track a smaller more resistant FRS .27 will still be much slower than a GTR .26 regardless if it sports a larger cdA. To me, the 86 has low resistance tires, its got a small deck spoiler, it has a flat under panel. and still ONLY manages a .27 with very little downforce applied. vs a physically bigger GTR, with large resistant tires, a large wing for downforce, a low slung under panel, a more overall more drag resistant car still has a cd of .26 That would mean around a track, the GTR would be able to remain more stable, achieve more grip, and be bigger, and still be able to resist air as just if not more effectively than the FRS. Does that make sense?
#10 | |
#11 |
#12 |
Asshole? Says the guy who starts off with, "Welcome to 2 years ago....". Grow up, thanks.
Aw, someone is offended. I get what you're trying to say, but no matter....because what you are trying to say doesn't make much sense. Grats on understanding yourself though! ![]() Did you get all that information off wikipedia? Happy to know you are sticking to your logic (perhaps lack there of) and that this forum allows people like you to express yourself in a domineering fashion to fellow members. Shame on you. Peace and Love, I'm out. |
#13 |
Now w/ over 400 womprats!
Drives: BRZ LZR
^^^ lol
- The Ancient BRZ Sacrament by Zaku |
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 08:53 PM |
| Brz Drag Setup | Tansey86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-12-2012 11:24 AM |
| Coefficient Drag & Aftermarket Aerodynamics | FT-86GOD | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-28-2012 01:20 AM |
| Top speed vs Coefficient of drag | carbonBLUE | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 11-14-2011 05:02 PM |
| 86 Drag car?!?! | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 5 | 01-14-2010 06:35 PM |
