Old 04-30-2013, 02:52 AM   #1
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Gap between Fog light & Bezel FIX
For those of you that installed the subaru outback foglights in your FRS and had a gap between the housing and the bezel...
...here is a quick fix (30 min tops) that will give a watertight seal for your fogs.
What you will need :
Universal Weatherstripping - $9.99
Black RTV $7.99 (or any black gasket maker)
Diagonal Cutters
Cotton Swabs
Remove bezels from car. After bezels have been removed, cut a piece of weatherstripping out that will go around the housing and place it with half the width sticking out over the edge of the housing:
On the bezels, cut the excess plastic off the edge of the hole to make it flush:
Reinstall bezels. Readjusting of the weatherstripping might be necessary to make it flush with the bezel:
Fill in the remaining gaps with the rtv sealant/gasket maker.
Clean with cotton swabs and let cure 1 hour before driving.
After 3 hours:
The RTV fully cures in 24 hours. I would wait that long at least before a car wash. Good luck!
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 04-30-2013, 08:09 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
The gap is there to provide you freedom of movement when adjusting the fog lights.
infinite012 is offline   Reply With Quote
Old 04-30-2013, 09:07 AM   #3
PineappleFriedRice
Truuu
Adjustment of the fog lamp aim is done internally in the housing. the gap is there due to the housing being for a Subaru outback not the FRS.
Old 04-30-2013, 09:29 AM   #4
infinite012
orly? I kinda figured all Subarus were like my STI with a threaded adjustment that moves the fog lamp as an entire unit. Oh well. I still don't see a point to filling in the gap.
Old 04-30-2013, 11:14 AM   #5
PineappleFriedRice
Truuu
My buddy's mustang is the same way where the whole assembly moves rather than just the bracket holding the bulb.
Its just personal preference. I always find bugs lodged in the gap and it bothered me so I did something about it.
Old 07-27-2013, 12:59 AM   #6
phloozy
phloozy's Avatar
Drives: Scion FR-S
I just got toyota fog lights and the gap is there. It has nothing to do with the outback fogs
phloozy is offline   Reply With Quote
Old 07-27-2013, 04:08 AM   #7
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
do you think it will work fine without the rtv sealant? i want to be able to remove the bezels
mrlewistan is offline   Reply With Quote
Old 07-27-2013, 04:44 AM   #8
suaveflooder
Good work! Although, every car I've owned with fog lights has always had a gap there similar to that. Come to think it of, the FRS is my first car WITHOUT them.
suaveflooder is offline   Reply With Quote
Old 07-27-2013, 12:12 PM   #9
PineappleFriedRice
Truuu
Yes you'll be alright
Old 07-27-2013, 12:20 PM   #10
PineappleFriedRice
Truuu
Yea I've seen the toyota fogs and there is a gap. But like I said on a previous post, its your preference if you want that gap or not, this is just an option for those that don't like having the gap between the bezel and housing.
Old 08-07-2013, 09:28 AM   #11
Tofu driver's Fr-s
Tofu driver's Fr-s's Avatar
Drives: Whiteout Fr-s
All kits have that gap. although this looks nice I dont see the point since air can no longer flow through to help keep the temp down. At some point the heat from those h11 bulbs are going to distort the assembly.
Noticed your using leds so I guess it no longer applies.
"The Dream"
Tofu driver's Fr-s is offline   Reply With Quote
Old 08-13-2013, 06:20 AM   #12
coachzizi
Drives: 2013 scion FRS
it works fine for your led bulb, but my h11 hid bulbs runs extremely hot. Although i would love the look without the gap, i have to leave it for ventilation :\
coachzizi is offline   Reply With Quote
fog light, gap, seal
WTB: FRS Radio Bezel Piece NoLeftHere Interior Parts (Incl. Lighting) 0 02-23-2013 11:30 PM
Carbon Fiber Foglight Bezel JonMotoring Exterior Parts - The Rest 0 02-10-2013 04:51 PM
Removing the HU Bezel Xdragonxb0i DIY (Do-It-Yourself) Guides 1 02-05-2013 07:20 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 05:34 AM
Air Vent Bezel NSV Cosmetic Modification (Interior/Exterior/Lighting) 0 06-16-2012 02:29 PM
