Old 04-29-2013, 08:17 PM   #29
jmaryt
Drives: 2012 honda civic ex
Originally Posted by CBR600RR View Post
if your mirrors are properly adjusted you will not have a blind spot
Originally Posted by whaap View Post
This is the most common mistake made by drivers. If you fan out your side view mirrors enough you will be able to see the car approaching you from behind. As he starts to pass you (on either side) you will see him in your side view mirror before he leaves the rear view mirror. Before he leaves the side view mirror you should see him with your peripheral vision, if not a slight head check. It will seem strange at first but try it for awhile and you will wonder why it took you so long to figure it out.
this is correct!
jmaryt is offline   Reply With Quote
Old 04-29-2013, 08:18 PM   #30
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I hate driving around Vegas with these blind spots.. I've tried properly adjusting the mirrors, the proper way, and I just can't.. I use them to back up and them facing the side and not down the side ruins that.. My e I just need more "drive time" but driving 20+ years and never having a real blind spot until now, it's hard to go to properly adjusted mirrors.. It feels very unnatural to not see behind you and looking off to the side
Gixxersixxerman is offline   Reply With Quote
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Ben_G (04-29-2013)
Old 04-29-2013, 08:19 PM   #31
jmaryt
Originally Posted by Ben_G View Post
I've been able to do this for all my previous cars, but I still haven't found the sweet spot for the BRZ/FRS.... no matter where I set my mirrors, there's always this one spot that I can't quite get rid of....I may have to resort to one of those stick on convex mini mirror dealies..... =(
if this is helpful to you,then by all means do so,however if you keep adjusting your mirrors,and checking visually,eventually you WILL eliminate the blind spot...just sayin'
Old 04-30-2013, 04:21 PM   #32
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Originally Posted by Sacs View Post
After a near miss 15 years ago (with properly adjusted mirrors!) I've learned never to rely totally on the mirrors. It is now habit to physically turn my head and visually check/clear any potential blind spots.
Properly adjusted mirrors and a shoulder check is the best.
Demandred7 is offline   Reply With Quote
Old 04-30-2013, 05:04 PM   #33
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by jstans84 View Post
I picked up a set of convex mirrors from @FT-86 SpeedFactory they basically eliminate the blind spot completely.
Same here these helped a ton and well they look good to ?
Old 04-30-2013, 09:48 PM   #34
jmaryt
wow! this guy! just can't? prior posters have explained how! you NEED to "trust" WHAT you see in your mirrors.IF you adjust them properly,then you WILL eliminate the blind spot(s)...just sayin'
Old 04-30-2013, 10:49 PM   #35
slowbrz
Drives: '13 black BRZ MT
I lean my body forward to look left
slowbrz is offline   Reply With Quote
Old 04-30-2013, 11:06 PM   #36
Demandred7
Demandred7's Avatar
Originally Posted by mackdaddytran View Post
Today is my third day with this car. I just realized how horrible the blind spot is when you're trying to do a uturn.
I was under a bridge doing a uturn and i seriously could not see 5hit. I had to be sure that oncoming traffic was at a red light before i could go
Maybe I am not visualizing what you are saying, but, how does a rear blind spot affect you in a u-turn? It sounds like you have turned too far before committing to the completion of the u-turn. If my rear is facing the oncoming traffic, I am already well committed and my foot buried in the pedal (preferably with VSC Sport mode on to rotate the rear faster).
Old 05-01-2013, 03:49 AM   #37
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
i check my mirror, then make sure i have plenty of room in front of me, then crank my head all the way over to the left to check the target lane, then i slowly merge while keeping an eye on my side driver mirror. Thank goodness i do things this way cause that last part saved my frs a week ago from a bad situation.
i will mostlikly get the little stick on peripheral mirrors that i also have on my camry. those help out a ton but they dont look too fantastic on the car
mrlewistan is offline   Reply With Quote
The Following User Says Thank You to mrlewistan For This Useful Post:
mackdaddytran (05-01-2013)
Old 05-01-2013, 12:20 PM   #38
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I've noticed with this car that even with the mirrors all the way out there is still a slight blind spot between rear view and side mirror. I'm guessing due to rear view mirror size and location of seat. It's quick and easy to adjust when parking.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 05-01-2013, 12:22 PM   #39
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
The front of my car was about as far out as I could be without sticking out into their lane.
I couldn't see out the passenger side around where the quarter glass is. Now I don't pull up as far so I am able to see through the passenger window.
mackdaddytran is offline   Reply With Quote
The Following User Says Thank You to mackdaddytran For This Useful Post:
Demandred7 (05-01-2013)
Old 12-25-2013, 09:57 AM   #40
ID86
Drives: FRS
Sorry for the long bump but couldn't find any results..
Just a question for you guys with blindspots or shoulder checking.. What window do you look at for the driver side?
Is it okay to look at the end of the first window of the driver side for blind spots? (I look at the first window looking all the way back) I tried adjusting my mirrors all the way out, but I'm not confident with that.
ID86 is offline   Reply With Quote
Old 12-25-2013, 10:05 AM   #41
FR-S Matt
Originally Posted by FT-86 SpeedFactory View Post
Just for reference on the convex mirrors.
+1 to this. These mirrors are outstanding. No blindspots on either side. By the time the car is out of the mirror it's already on my side.
The Following User Says Thank You to FR-S Matt For This Useful Post:
ID86 (12-25-2013)
Old 12-25-2013, 10:15 AM   #42
ID86
Drives: FRS
Cool. So that eliminates the blind spot completely right, even with my mirror seeing just like 1% of my car.
To the people checking over their shoulder (Driver), is it okay to check blindspot from the first window instead of the triangle window or does that provide not enough vision?
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 12:42 AM
Blind spot mirrors? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-11-2012 02:29 AM
spot cleaning jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-26-2012 06:12 PM
People having a hard time with the FR-S blind spot driver01 Scion FR-S / Toyota 86 GT86 General Forum 28 06-16-2012 03:27 PM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 03:17 PM
