Old 04-29-2013, 12:54 PM   #15
2forme
I vote to get a CAI.
Old 04-29-2013, 07:14 PM   #16
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
i had the same problems with stalling, i used to have an injen intake. i recently swapped to TRD intake and the car runs much better, and seems to idle better. more smooth. i also have fa20clubs stg. 2 tune, but id try going back to the stock airbox with a drop in filter. i never thought my injen caused the issue, because ive had the idle issue since new, but looking back i think it could be related to some minor driveability issues.
Jesse is offline   Reply With Quote
Old 04-30-2013, 11:48 AM   #17
ozne99
Drives: GBS BRZ Limited
The ECU is not prepared for the turbulent air that is being created by the intake while coasting. Then when the RPM drops it is not able to hold it at idle. No amount of ECU resetting will fix this. Either keep a little throttle to keep it from stalling, get an ECU tune, find a way to modify the intake to straighten the air, or put the stock airbox back in.
Thank you for this explanation.
Kinda pisses me off that I either have to live with this annoyance or go back to stock.
ozne99 is offline   Reply With Quote
Old 04-30-2013, 04:29 PM   #18
Razz
Razz's Avatar
Drives: Fast
Reasearch in aftermarket parts is your friend.
Also, time. Wait for the item to be on the market long enough to get feedback on the product.
Razz is offline   Reply With Quote
The Following User Says Thank You to Razz For This Useful Post:
Marchy (04-30-2013)
Old 04-30-2013, 04:38 PM   #19
Mikem53
Drives: FR-S 6MT
Originally Posted by deedz View Post
Would it most likely be installer error? or is it just because the ECU is not flashed to know the intake is there?
Sounds like the intake is modifying the air flow which is causing the MAF to misread..
Mikem53 is offline   Reply With Quote
Old 07-21-2013, 03:27 AM   #20
mas3oodi
mas3oodi's Avatar
Same issues here. Not very happy with the Injen intake..
mas3oodi is offline   Reply With Quote
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 02:36 PM
Engine problems Gerri Engine, Exhaust, Transmission 2 08-14-2012 08:14 AM
Anyone else having bluetooth problems? Scooter Style Electronics | Audio | NAV | Infotainment 8 08-03-2012 07:38 PM
Problems with detailing Nezz AUSTRALIA 23 06-28-2012 10:08 AM
Do you think this car is going to have some problems? Huss Scion FR-S / Toyota 86 GT86 General Forum 45 03-21-2012 02:48 PM
