Old 04-29-2013, 02:01 AM   #225
Darren Orange
Drives: Cadillac CTS Sport 2003
The term "Fuel economy" can be based on either money OR consumption. Its not exclusive to cost.
Economy is not a term reserved for "money".
There is no reason why not to base fuel economy in fuel used per mile. after all, every car manufacturer and their ads use it
Well based upon these numbers if we are talking costs...I think being able to run E85 even at lower MPG would likely be far cheaper.
E85 is normally about 15% cheaper plus the difference from having to run 91 or greater octane anyway with the car and you wind up with pretty much the difference.
My point being that I think our conversation about E85 is a mute point due to the cars requirement of high octane anyway. It's cars that run on 87 that don't seem to make up the difference.
Darren Orange is offline   Reply With Quote
Old 04-29-2013, 02:26 AM   #226
s2d4
s2d4's Avatar
@Darren Orange
Please at least read the wiki stuff you ninja edited into your previous post.
Old 04-29-2013, 07:17 AM   #227
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yeah, it has been documented by people running E85 on our cars that its basically a wash between E86 lower MPG and E85 lower price, so its no benefit or advantage to either fuel type price wise. My point was not to keep debating the merits and cost savigns/money waste was E85, but that quantity of fuel can be measured as "fuel economy".
Old 04-29-2013, 10:48 AM   #228
Darren Orange
Originally Posted by s2d4 View Post
@Darren Orange
Can you explain the point you are trying to make?
Old 04-29-2013, 10:49 AM   #229
Darren Orange
Right agreed with you on all points. I just wanted to get everyone back on point that running E85 makes realistically no difference in cost of operation.
The Following User Says Thank You to Darren Orange For This Useful Post:
Sportsguy83 (04-29-2013)
Old 04-29-2013, 10:55 AM   #230
2forme
Well, as of right now, sure. But we don't know how the motors will handle it long term. That could definitely raise the cost of operation, especially since it won't be covered under warranty.
The Following User Says Thank You to 2forme For This Useful Post:
Old 04-29-2013, 12:49 PM   #231
jamesm
The obvious problem with elevating boost for e85 on a supercharger is that it requires hardware to be changed out (the pulley). So, no easy switching between fuels. Better take a toolbox if you wanna drive anywhere that doesn't have e85, and don't plan any road trips lol.
Old 04-29-2013, 01:06 PM   #232
Foobar
SLO NO MO
Foobar's Avatar
You just need to reflash to a pumpgas compatible tune - no need to swap pulleys out just to go back to pumpgas.
There is apparently little gain to be had using the smaller pulley with pumpgas, but that's not to say it doesn't work with it.
Old 04-29-2013, 01:19 PM   #233
Sonolin
Yea, either that or you could use a boost limiter. So if your running like a 20psi pulley and had to run 91 crap gas, you could theoretically just limit boost to 10psi. More torque early in RPMs too, because your 20psi pulley would hit 10psi a lot faster than a 10psi pulley would.
This is just based on speculation & random bits I've read on this forum, so I could be wrong. But I don't see why it wouldn't work if you limited boost lower for pump.
Sonolin is offline   Reply With Quote
Old 04-29-2013, 01:26 PM   #234
jamesm
People in the miata community have been trying at limiting boost on superchargers for a long time, with various valves, restricors, even one I saw with a wastegate-looking setup. None actually work well that I know of. The proper way to control boost on a supercharger is by using the correct pulley.
The Following User Says Thank You to jamesm For This Useful Post:
Sonolin (04-29-2013)
Old 04-29-2013, 01:50 PM   #235
Sonolin
Damn. If somebody could figure it out that'd be a great setup. My bad it sounded possible but just hearsay I guess.
Old 04-29-2013, 03:22 PM   #236
sw20kosh
Drives: 2013 Black FR-S
but E85 is a high performance fuel, with an octane rating of about 94–96, and should be compared to premium.
This is terribly wrong.
E85 is not equal to 94-96 octane. lol
Old 04-29-2013, 03:22 PM   #237
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Better option is to use a constant speed drive between the crank and the supercharger. That would allow you to run the supercharger at max rpm at any engine speed...
pheoxs is offline   Reply With Quote
Old 04-29-2013, 04:07 PM   #238
Sonolin
I've never heard of this, sounds interesting...
Is that like a CVT? Sounds expensive?
When in doubt, shop around.. Jigga AUSTRALIA 9 09-06-2012 06:47 PM
Can anyone read Dutch? Buggy51 BRZ First-Gen (2012+) — General Topics 14 12-28-2011 09:48 PM
without a DOUBT how i want my BRZ to look dorisaru BRZ First-Gen (2012+) — General Topics 33 12-15-2011 07:31 PM
