Old 04-13-2013, 09:30 AM   #57
qmbrz
http://sphotos-a.ak.fbcdn.net/hphoto...15640598_n.jpg
2013 BRZ - Tein Street Flex Coilovers - AVO Turbo - Perrin Cat Back Exhaust - Rays 57Xtreme - AVO8
qmbrz is offline
Old 04-27-2013, 11:58 AM   #58
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
I'm quite lost guys, can someone please advise me why some people are running front +33 offset and some +45 ?
What is the correct or recommended offset for front ?
Sookainian is offline
Old 04-27-2013, 01:30 PM   #59
jflogerzi
jflogerzi's Avatar
Originally Posted by Tye300 View Post
Some more pics.
Camber settings...
Gotta say your car looks sick! nice setup.
jflogerzi is offline
The Following User Says Thank You to jflogerzi For This Useful Post:
Tye300 (04-28-2013)
Old 04-27-2013, 02:22 PM   #60
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
a number of factors (someone more knowledgeable will probably add to the list) -
- wheel (rim) width
- tire width
- inside clearance (to suspension components)
- outside clearance (usually fender)
- desired 'flushness'
- hub/bearing loads
front/rear offset is +48 for OEM wheels/tires
shiumai is offline
Old 04-28-2013, 02:56 AM   #61
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Originally Posted by Sisi View Post
What did you use to correct the front and rear camber?
My BC racing coilovers came with camber adjustable mounts in the front. For the rear, I used Cusco lower control arms.
Tye300 is offline
Old 04-28-2013, 02:58 AM   #62
Tye300
Tye300's Avatar
Originally Posted by qmbrz View Post
Hey Tye I've gone with gunmetal 57Xtreme's also - 225/40/19 on front and 255/35/19 rear offset 45 with Tein Steet Flex coil overs. my brz is deep grey so they're like your setup. Look bad ass - super low. just fit inside wheel arch.
I saw your pic! Looks great with the deep grey color! Great drop man. What did coilovers did you use?
Tye300 is offline
Old 04-28-2013, 03:00 AM   #63
Tye300
Tye300's Avatar
Originally Posted by kioton32 View Post
So with a 1.2 inch drop on 19x9.5s on the rear and 19x8 up front should be fine without any camber right... 215/35 r19 up front, 235/35 r19 out back
Yeah you should be fine with that. My advise would be to fit wider tires though. If you like the stretched look, you should be alright.
Tye300 is offline
Old 05-03-2013, 02:38 AM   #64
hendryhendry
Drives: hot lava FR-S
Hi guys, Im torn between 18'' & 19'' for this rims. Anyone can help me to decide which one should i get? I only use my car for street.
Thanks in advance.
hendryhendry is offline
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-19-2014 12:28 AM
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 MVJ1975 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 10-05-2013 02:29 AM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +33 / 19x9.5 +43 bacon_cheese_beer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-16-2013 06:01 PM
Ray's Gram Light 57Xtreme Wheels - 19x8.5 / 19x9.5 (Set of 4) * IN STOCK * Enjuku Racing Wheels and Tires 1 07-20-2012 08:15 AM
